Old May 06, 2007, 08:18 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
ewwwwwwwwwww a 60" park flyer with flaperons? whatis of that, and what motor/prop would you recommend? Since this is a slow, slow, slow flyer, I suppose you run 2S on most of these setups?
warhead_71 is offline Find More Posts by warhead_71
Old May 06, 2007, 08:24 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
I think you are posting in the wrong tread. War, This is about a 32" Blu Trainer
dekan is offline Find More Posts by dekan
Old May 06, 2007, 08:57 AM
nebuchadnezzar is offline
Find More Posts by nebuchadnezzar
gilford, new hampshire, usa
Joined Nov 2003
That 24 gm Hex is a powerful little motor. I have one on my IFO_T and my Bug and they work fine for that - more power than needed! Should work fine on this.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old May 06, 2007, 10:18 AM
nubee 1 is offline
Find More Posts by nubee 1
Joined May 2006
OK I just cut one out and cut out the KF pieces also. To do the KF you are putting it on top without any bend ? = Flat bottom foil ?
I might do both wings. Also I can't read the diheadril numbers.
But not ready yet got fuselage to build. Back to basement.
Ken
nubee 1 is offline Find More Posts by nubee 1
Old May 06, 2007, 12:37 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Originally Posted by Tony65x55
The Blu-Baby. Is this the World’s Greatest Primary Trainer?
...The Blu-Baby has been built in three different sizes, a 33” indoor and park flyer, a 40” park model with a GWS 350 for the Kid and a 60” AP plane with an accessory sport wing with no dihedral and full span flaperons. All three sizes have exhibited the same kind flying characteristics, super docile handling, very gentle stall and all around great manners....
Tony
Looks like a 60" park flyer is already a reality - I'd love to see some pics and plans and power options.
Old May 06, 2007, 02:02 PM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
I would like to see some more pics of fuse construction and radio installation...
Really nice plane!
Robert
willin is offline Find More Posts by willin
Old May 06, 2007, 03:59 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Tony....Great looking trainer plane. I llike the looks of the monobloc construction. What type and thickness of foam did you use?
FirstShirt...I really like the graphics you put on the second build of the plane. It looks like tape. What type of tape did you use...or is it paint? That would really help in orientation for a new flyer!
Any chance one of the more experienced builder can make a build guide of this plan. That would be great for a first time builder!
Now there is another possibility for my first foamie. Let's see STC.....TrainerOne...or Blu-Baby that is the question.
High Flyin' is offline Find More Posts by High Flyin'
Old May 06, 2007, 04:54 PM
Hllrsr is offline
Find More Posts by Hllrsr
Airframe Stress Tester
Barrie Ontario
Joined Apr 2004
".....The big AP bird flew nicely on an inexpensive BP21 and it now carries a ST Models 1000kv brushless for hauling around cameras......"
Personally, I'd run 3s direct or 2s geared, depending on whether or not it's on floats...
Go Tony go!! Another winner. You do realize, that now that you've been talked into posting another design, now it's expected that AT LEAST 1 a month gets posted???
ATB
Iain
Hllrsr is offline Find More Posts by Hllrsr
Old May 06, 2007, 07:10 PM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Really nice plane!
Robert
Here are some fuse pix. Mine is unnecessarily complicated because I used several layers of EPP to make a wider fuse. Tony's plan calls for a simpler technique. You'll find build pix for his SE5a, which also uses the monobloc design, here: http://www.rcgroups.com/forums/showthread.php?t=649178
Pat
FirstShirt is offline Find More Posts by FirstShirt
Old May 06, 2007, 07:23 PM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Glass,
Check Tony's SE5a thread. May answer some of your construction Qs.
The graphics on the wing are cheap, colored packaging tape. Works great!
http://www.fast-pack.com/colored_tape.html
You're right. Color and graphics can be critical when it comes to maintaining orientation. Check this site for some great help on this:
http://www.ultimatecharger.com/color.html
Pat
Old May 06, 2007, 08:43 PM
willin is offline
willin's Avatar
Joined Mar 2003
Now I understand the concstruction better, I was thinking the internal foam went solid from nose to tail, yet the radio gear is obviously mounted internally.
Thanks!
Robert
Old May 06, 2007, 10:42 PM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Originally Posted by brucej
thanks tony
will this fly on j250 direct drive, as a trainer
40 and 60 ? sounds great to
video plays well 5 meg is about limit on dialup
Good forward thinking on the KFm wing
Bruce, I haven't tried it but it should be fine. The IPS puts out the same thrust as a DD J250. Airplane Ed has a J250 (C) gear drive in his and truthfully, it's a bit overpowered for a primary trainer. That said, it handles the weight and thrust without any problems at all.
The 40" Version was built around the GWS 350 as a park flyer for "The Kid" (who has never seen an airplane he couldn't break). It flies the same as the little on, just bigger.
I built the 60" as a camera plane and it is smooth and stable. As well, I built a 52" accessory wing for it with no dihedral, clark Y airfoil and full span flaperons as a sport wing. It will also lift the camera no sweat but requires a bit more attention when you're flying it. I also mixed a bit of elevator with the flaperons so when you drop flaps the nose doesn't balloon. It rolls, loops hammerheads etc and is a lot of fun.
Here's a movie shot with the Blu-Baby 60" AP plane. It was pretty hazy out that day and the movie was shot with the old camera so the quality isn't awesome. It will give you a good idea of how smooth this plane flies though and it's rate of climb on 21 ounces of thrust. It reaches up over 1,000 ft on this movie. WARNING: It's a big movie. You probably don't want to do this with dial up. NOTE: At the beginning of the movie you can see the Kid's BB trying to follow me up. Look towards the right corner of the screen.
http://www.rcgroups.com/forums/showp...31&postcount=1
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old May 06, 2007, 10:43 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Coming...
Old May 06, 2007, 10:46 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Ken
Hey Ken! KFm is flat bottomed, step on top at 50%. Go ailerons, no dihedral and a little bigger motor and it should be a good aileron trainer too.
Regular wing dihedral is 1" on each tip (2" altogether)
Tony
Old May 06, 2007, 10:50 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
ATB
Iain
Yes to the 3S w/brushless motor. It's a big bird.
One a month huh? If I did that I would never get to build or fly any of them. I do however, have a few more I designed over the winter and so there will be a few more the next cople of months. Stay tuned!
Tony
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
