Old May 18, 2007, 09:28 PM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Originally Posted by raythomas
Well I finally got the time to try a second flight on my BB.
I reduced the throws half of what they were on the first try.
Also changed out the J250 for a SP280 dd.
The ole J250 has seen better days and multiple flights.
Anyway the plane flew great, smooth is a good word.
The only problem was a short "very short" flight time because of a weak Lipo combined with the sp280.
Anyway it was enough to see that it is a great plane.
Just need a newer lipo.
Thanks Tony for a winner.
Ray
Fantastic Ray. I'm so glad it flew so well for you, you really sweated the detail on this one. I'm glad it was worth it.
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old May 18, 2007, 09:55 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
Not to take away from the planes design at all.
Could those here who have had good luck with there BB please post
the motor, esc, and lipo combo they are using?
I'm curious to see what others are using.
I'm thinking if I gotta get a new lipo, I might try to upgrade to a brushless setup.
I have a BP21 but I'm afraid that would be overkill for my BB.
Thanks Ray
raythomas is offline Find More Posts by raythomas
Old May 18, 2007, 10:38 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Originally Posted by Tony65x55
Yea Mike! Slow and steady. That how a BB is supposed to be. It should loop with a little coaxing. Perfect. You could teach anyone to fly with it set up like that.
Bob, isn't it remarkable what passes for a primary trainer? If every beginner could get a properly trimmed Blu-Baby, or GPW's Trainer 1, or STC, or one of Gene Bond's floaters, we would have a lot more people successfully partaking in RC.
Pat has it right. Build a BB and give it away. Keep one for yourself as therapy, but give the others to newbies that need a plane to learn the basics on.
Tony
Tony... You are right about these designs and how their low cost and simplicity can make them available to a lot of people. I know there a several models described in this forum that would hook any novice on RC and foamies for a minimum investment. I am going to follow in Pat's footsteps and see how I can give some of this pleasure to some others. Bob
Foamenator is offline Find More Posts by Foamenator
Old May 18, 2007, 10:52 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Thanks Ray
Ray... My BluBaby has a 2712-12 outrunner from Heads Up Rc off E-Bay. My motor runs a GWS 9050 prop and uses a WOW 1000 mah lipo and a WOW 30 amp esc. This setup is probably overkill, but I have tried standardize my electonics as much as possible. It is supposed to deliver 18 oz of thrust (although I haven't tried to measure it) BB Birddog II weighs 11 oz AUW. Whatever the actual thrust is, the plane has has plenty of power and will loop from level flight. The plane doesn't seem to care for the extra power. Hope this helps.Bob
Old May 18, 2007, 11:54 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
The BP21 uses a 8x4hd prop with 3 lipos, pulls around 13amps static.
with a small lightweight lipo I could make it work maybe.
Anybody else want to post there motor, lipo setup??
Thanks Ray
Old May 19, 2007, 03:36 AM
nubee 1 is offline
Find More Posts by nubee 1
Joined May 2006
Theres an awfull lot of the Hextronix 24 gram $10.05 each motors
on them. I have a heavy battery in mine @ 68 gram = 800 Mah
Ken
nubee 1 is offline Find More Posts by nubee 1
Old May 19, 2007, 06:39 AM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Thanks Ray
Hey, Ray!
BB #1:
(From memory...hope this is right)
Custom CDR Single Stator
Thunderbird 9 esc
8040 Prop
2s 800 mah
(Friend I gave it to is using a 2s 1200 mah)
BB#2
Westport CDR 22.5mm/20T
Hextronic 10A esc
9047 prop
2s 650 and 2s 800
BB#3
(Still under construction)
Hextronic KA20-50 Kv 1088 (s/b equiv to Hacker's A20-50S)
Hexatonic 10A esc
9038 prop is recommened
3s battery is recommended
(I'll use a 3s 650 mah or a 2s 650 mah)
Haven't flown #3 yet, but it s/b an efficient little motor. I thought the little Westport motor and 9047 on BB#2 felt perfect. One thing I know is that I prefer the 9" props over the 8" props on the BB. I also like to use the light, low amp draw motors and lean toward the 2s batteries. In my experience, the BB doesn't need a lot of power.
Hope this helps.
Pat
FirstShirt is offline Find More Posts by FirstShirt
Old May 19, 2007, 07:14 AM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
BB #1: GWS IPS (A) w/9070 prop (Design motor)
GWS 5 Amp Speed Control
CommonSense RC 2S 800 mah Lipo
BB #2: J250 w/ GWS EPS-100 (C) gearbox
9070 prop
GWS 10 amp speed control
CommonSenseRC 2s 800 mah Lipo
BB #3 & 4 (under construction) IPS (A) as above
BB Park: GWS 350 (C)
1080 prop
GWS 15 amp speed control
Generic 1300 mah Lipo
BB-AP: BP-21 w/8043 prop, ST Models 1000kv Outrunner w/9050 prop
Towerpro 18 amp speed control
CommonSenseRC 3S 2000 mah Lipo
Tony
Old May 19, 2007, 07:21 AM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Ray, the BP-21 is serious overkill for the little Blu-Baby and is very likely to tear the wings off. As you can see from the above posting, it was the design motor for the 52" BB Aerial Photgraphy plane, which also carried 6 ounces of camera. It flew reasonably well with both the 52" Sport Wing and the 60" undercambered Heavy Lifter wing.
For a brushless motor choice, the little Hextronic Blue Wonder would be hard to beat in this plane and even it is overpowered. Remember, it was designed to fly with the little GWS IPS which only produces 4 ounces thrust.
Tony
Old May 19, 2007, 07:29 AM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
Whew
4ozs isn't alot of thrust!
So the BP21 is out.
Have to save it for the big BB.
Anybody else??
Thanks Ray
Old May 19, 2007, 08:34 PM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Just finished Blu-Baby #3 (except for a couple of graphics details). Maidened it just before darks. What can I say? If flies like a BB! Rock solid stability. Love this plane! Been working in the yard most of the day, so I'm beat. Will post pix and details in the next day or two. Thanks, Tony!
Old May 19, 2007, 09:16 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Pat congrats on BB 3. Looking forward to the pics. Oh... about that yardwork. Have you considered foamenating your lawn? It's great a little work with the heat gun and some cheap green latex paint and your ready to get back to flying BB's. Bob
Old May 19, 2007, 09:53 PM
nubee 1 is offline
Joined May 2006
I did a taxi test on my red & yellow Blu-Baby and real pleased with the power from the 24 Hex. Its broke down and packed ready for Fla. Also built a Slow Stick with a EMax CF 2822 39 gram and tested it also. Hit full throttle and it jumped off the grass in 2 feet.
You guys might want to check it out cause its STRONG. Cheap also
Ken
Old May 19, 2007, 10:33 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Ken
Taxi Tests My BB won't taxi, just takes off and goes. Have a great trip and don't forget the pics. We'll need to do a montage of all the BB's for Tony one of these days. Bob
Old May 19, 2007, 10:40 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
I swapped out the SP280 for a IPS-A gws drive with a 9x7 prop.
Using a 860ma thunderpower 2cell lipo,
Has good power, and I reduced the control throws but it wants to seem a bit tail heavy or sorta jerky when I give it up elevator.
How many mm from the leading edge of the wing are you fellows getting CG??
I may have to move my battery slot a tad farther forward.
Thanks Ray
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
