Old Jan 05, 2013, 06:44 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Hi Moray,
The 2213 would do well for the 42. The 2826 is a bit weighty of a setup for the 33.
Sorry,
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jan 05, 2013, 07:18 PM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Originally Posted by Freddie B View Post
I have built multiple BB 33's over the last 3 years or so. Also been scratch building and flying most of my life (about 50 years????)
If you give your BB some extreme 20-30 degree throws, it can be twitchy, especially since it is Short Coupled, AND has a shotr wingspan. But I like mine that way. Short coupled, and a short and wide wingspan is all an important part of the design, and thousands of users have had so much fun and success with it.
I can snap roll mine with rudder/elevator only. It happens so fast and in about 2 or 3 airplane lengths of flight doing it! But with the high wing, the pendulum effect when self righting is a definite "twitchy' recovery. Turn up your control throws and experiance a lot more fun! Watch adding floats if you do because when it self rights out of a sharp banking turn, it will swing the undercarriage the opposite direction coming out of the turn!
Any short coupled airplane witll fly a bit more tame with a longer moment, and often a longer and thinner wing is recommended. You could also shrink the tail section sizes, but then we start to come up with a complete re-design. Keep it simple, but nothing is hurt by some small adjustments.
Fred
My Kfm3 33" blu baby snap rolls in a heartbeat and rolls like a drill with full width ailerons. Short coupling means it banks like crazy with rudder. Loops are possible at 1/3 throttle with 1700kv blue wonder on 3s. My throws are large, close to 45 degrees everywhere except ailerons which I set up differential on via my Dx8. But - let off the controls it doesn't right itself because of no dihedral but it absolutely STOPS flopping around the sky. For what it is it's ridiculously aerobatic. It's a great plane, I love it.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Jan 05, 2013, 07:46 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Now we're talking! Tons of fun from one simple little foamie aircraft design.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jan 15, 2013, 10:25 AM
daza1895 is offline
Find More Posts by daza1895
Joined Jan 2013
what are the internal parts for this thanks ie the motor and how many servos it has
can some 1 plz give me a list of things i need thank you very much
daza1895 is offline Find More Posts by daza1895
Old Jan 15, 2013, 12:30 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
For a typical BB 33, right? Is that what you are asking?
These will work, as will anything like them:
motor (1) - http://www.headsuprc.com/servlet/the...trunner/Detail
ESC (1) - http://www.headsuprc.com/servlet/the...-10-Amp/Detail
battery (1) - http://www.headsuprc.com/servlet/the...mah-35C/Detail
prop - GWS 8043 slow fly prop - http://www.headsuprc.com/servlet/the...ler-ONE/Detail
9 gram servos (2 to 4) - http://www.headsuprc.com/servlet/the...9g-SG90/Detail
Two servos for RET and 3 or 4 to add ailerons also.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 30, 2013, 11:34 AM
andalosy is offline
Find More Posts by andalosy
United Arab Emirates, Ajmān, Ajman
Joined Jan 2010
Hello Guys, I'm totally a beginner and this is my first RC plane, I'm about to go for my maiden flight soon and would like to verify I made the right combination for my baby
Wing: 42" KFM3 2" dihedral
AUW : 580 gms
Motor: eflite 370 1200kv
Prop: APC 7x4
ESC: Hobbyking SS Series 15-18A
Battery: Zippy Compact 850mah,3S1P, 35C
The plane is tail heavy but I'm still trying to balance (so far it balances after adding dummy 25 gms after the motor!).
What do you think?
andalosy is offline Find More Posts by andalosy
Old Jan 30, 2013, 02:41 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Not familiar with the eflite motor, but if it's about a 40gm motor at 1200kv then you are in the ballpark, but the 7x4 prop sounds a bit small, the smallest I use on my 42" span BB is an 8x6, and more usually go to a 9". It'll fly with a lot bigger battery too, of course. depending on where you put the pack, that may help your balance as well.
springer is online now Find More Posts by springer
Old Jan 30, 2013, 02:56 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
I found a 7x4 to be sluggish on my 33" blu baby, using blue wonder 1700kv. I suggest a bigger prop as well.
Old Jan 30, 2013, 03:50 PM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
AUW : 580 gms
Prop: APC 7x4
What do you think?
andalosy:
One of the most common causes of crashed RC airplanes is the center of gravity, CG, not being properly placed. The weight you're adding is anoying but important.
Most importantly, make sure the CG is NOT AFT (rear of) of the recommended 3.44 inches (87mm) from the leading edge of the wing just next to the fuselage shown in the Blu Baby 42 inch KFm3 World Plan.pdf in post #107
In post #10600 and post #10601 are pictures of handy CG balancers.
- Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Jan 30, 2013, 05:49 PM
sixfins is online now
Find More Posts by sixfins
sixfins's Avatar
United States, FL, Sunrise
Joined Jul 2011
I use a 370 park motor on my 42", with a 10" prop. I maidened with a 9" and 3s 800marh battery. Which flew well, but the 10 is better and I prefer using 3s 1300mah batteries as well. It allows better penetration in wind, bigger might still be better, but that's all I have. As noted by others make sure you get your C.G. right and mark where your battery is placed so you don't accidentally change it when you change/charge your batteries.
sixfins is online now Find More Posts by sixfins
Old Jan 31, 2013, 07:51 AM
andalosy is offline
Joined Jan 2010
Thank to you all for this great advice, I bought today Great Planes CG machine, 9x4 Prop, and eflite 1350 mAh battery.
I balanced the plane at last after moving the new battery a little bit forward and vola everything seems OK. I attached the result.
Going to make the final power test for all the components.
Thanks again for all your support
Old Jan 31, 2013, 08:30 AM
treefinder
springer's Avatar
SE MI
Looks good, I think you're gonna like her! (I was gonna comment to not forget to consider skis and floats in addition to wheels for future activities with your new plane, before I noticed where you're located! - maybe floats if you're close to the ocean, but I doubt you'll need skis)
Old Jan 31, 2013, 09:05 AM
andalosy is offline
Joined Jan 2010
Well, I didn't find floats suitable for soft sands on rcgroups so far
Old Jan 31, 2013, 02:46 PM
andalosy is offline
Joined Jan 2010
Hi sixfins,
I just finished testing the park 370 with a 9x4 prop and it seems beyond the motor capability (Watt meter reads 11 amp at 85-90% throttle!). Would you please give more details about the type and pitch of the propeller you used?
Thanks.
Old Jan 31, 2013, 03:31 PM
sixfins's Avatar
Joined Jul 2011
I think it was a 9x6, can't really remember. What I use now are 10x4.7 and 10x6. I think they are GWS props, not sure. They're the cheapest ones at my LHS only $1 each. Really I only use about half throttle most of the time. With full throttle I have unlimited vertical and can take of with only a few inch roll out if any (well under 1'). With half throttle I can do loops and rolls, fly inverted and land after 8-10 minutes. The motor is always cool, not even warm, the esc and battery get warm, but not hot (about 95-97).
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
