Old Dec 19, 2012, 07:21 PM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Thats the nice thing about a throttle. You can always slow it down.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Old Dec 24, 2012, 01:47 AM
United States, FL, Key Largo
Joined Apr 2011
what size would i need to build the bb, with a park 480 and 10x7 prop?
minegun2 is offline Find More Posts by minegun2
Old Dec 24, 2012, 06:25 AM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
With that much power, nothing less than 42", but really you could go up to 60", and I'm not talking the AP version. I mean scaled up.
Ken
Old Dec 24, 2012, 06:59 PM
Joined Apr 2011
Ken
can u give me a link to the pds for thoes two? and whats the diffrence between the ap1 and ap2 and the other 42 inch?
Old Dec 27, 2012, 06:33 PM
I ask a lot of questions.
Canada, AB, Airdrie
Joined Aug 2012
subscribed (so I can find it again)
Disco Stew is offline Find More Posts by Disco Stew
Old Dec 27, 2012, 08:43 PM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
http://www.rcgroups.com/forums/showp...&postcount=107
Check the plans for differences. AP2 is more compactable. Fits into a case. Had the priviledge of flying Tony's bird.
Ken
Old Jan 04, 2013, 03:01 PM
The earth sucks! Thankfully.
Joined Jun 2003
Hi:
Has anyone lengthened the Blue Baby's fuselage aft of the wing (the tail moment)?
-Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Jan 04, 2013, 06:03 PM
More coffee, please!
sir_clive's Avatar
Austria, Wien, Vienna
Joined Jul 2011
Do you think there is a need for it? My bb42 is very stable and responsive with the standard settings, both laterally as well as longitudinally.
sir_clive is offline Find More Posts by sir_clive
Old Jan 04, 2013, 08:25 PM
Medicinal Foam User
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
Originally Posted by JimHSoars View Post
Hi:
-Jim
Would be hard to get the CG right if one did
Wilfor is offline Find More Posts by Wilfor
Old Jan 05, 2013, 12:06 PM
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Hi:
-Jim
Yes, I have. What I did was lengthen the nose also. Add 1 inch, to 1 1/2 inch to the nose and then 1 1/2 inch, to 2 inch to the tail moment. By placing gear forward in the under wing compartment, and the ESC in a channel in the mono-block, I did not have trouble with balance. Keep pushrods thin and light by placing .032" (0.8mm) rods in cocktail straw guide tubes helps.
Yes the fly good this way, a bit less twitchy and yer still ultra manuverable.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jan 05, 2013, 12:31 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Hi:
-Jim
You know, I thought of this....but the horizontal stabilizer is so large the tail volume is still quite adequate - and it flies that way. But it would look less stubby with longer moments (and smaller horizontal). I certainly wouldn't call it "twitchy" - at least the original 33 incher (which is the only one I've flown). It's my go-to plane to buddy box a complete neophyte.
BEC is offline Find More Posts by BEC
Old Jan 05, 2013, 12:59 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I have built multiple BB 33's over the last 3 years or so. Also been scratch building and flying most of my life (about 50 years????)
If you give your BB some extreme 20-30 degree throws, it can be twitchy, especially since it is Short Coupled, AND has a shotr wingspan. But I like mine that way. Short coupled, and a short and wide wingspan is all an important part of the design, and thousands of users have had so much fun and success with it.
I can snap roll mine with rudder/elevator only. It happens so fast and in about 2 or 3 airplane lengths of flight doing it! But with the high wing, the pendulum effect when self righting is a definite "twitchy' recovery. Turn up your control throws and experiance a lot more fun! Watch adding floats if you do because when it self rights out of a sharp banking turn, it will swing the undercarriage the opposite direction coming out of the turn!
Any short coupled airplane witll fly a bit more tame with a longer moment, and often a longer and thinner wing is recommended. You could also shrink the tail section sizes, but then we start to come up with a complete re-design. Keep it simple, but nothing is hurt by some small adjustments.
Fred
Old Jan 05, 2013, 04:57 PM
Joined Jun 2003
I wondered about this because I have seen so many videos with the BB33 porposing. From all of your responses the problem is solved by limited control throws.
- Jim
Old Jan 05, 2013, 05:34 PM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Hi:
-Jim
Jim,
This was the basis for the Oshkosh Special. Started with a Blu-Baby 33. Moved the vertical stabilizer/rudder assembly back 1.5" and stretched the wingspan to 40". Though this does not lengthen the moment between the horizontal stab and wing, it did give much nicer control harmony between the rudder and roll response.
Ken
Old Jan 05, 2013, 06:35 PM
Joined Jul 2012
hi all,
I have the following two motors, turnigy 2213 1050kv and a turnigy 2826 2200kv
i also have 3s 2200 mah batterys and 6x4 and 10x4.7 props.
would these be ok for a blu baby, and if so which size, 33 or 42. i'd prefer 33 if possible.
cheers
Moray
CyberSprite is offline Find More Posts by CyberSprite
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
