Old Dec 04, 2012, 05:24 PM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
Bright Green Wheels!
Hi guys:
Where can I get these bright green wheels in this jfhspike post? My excuse is that I'll be able to see them easier when they pop off the gear wires in a crash or otherwise.
- Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Dec 04, 2012, 07:43 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by JimHSoars View Post
Hi guys:
- Jim
Here http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
You get the idea! LOL
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Dec 05, 2012, 08:43 AM
PatricMichigan is offline
Find More Posts by PatricMichigan
PatricMichigan's Avatar
United States, MI, Hillsdale
Joined Apr 2008
Hi guys:
- Jim
lazertoys has them in one size.
http://www.lazertoyz.com/Foam-14-Wheels_p_395.html
bphobbies has
http://www.bphobbies.com/view.asp?id...2&pid=B2111389
http://www.bphobbies.com/view.asp?id...2&pid=D2118533
http://www.bphobbies.com/view.asp?id...2&pid=B2111390
http://www.bphobbies.com/view.asp?id...2&pid=D2118534
PatricMichigan is offline Find More Posts by PatricMichigan
Old Dec 07, 2012, 08:10 AM
Wally_in_NC is offline
Find More Posts by Wally_in_NC
Gravity: it's the law
Wally_in_NC's Avatar
United States, NC, Mooresville
Joined May 2011
Originally Posted by dz1sfb View Post
Of course another option for a monobloc is to laminate the FFF or MPF or Depron. Whatever you use. I did this for many Oshkosh Specials before going to an engineered structure. While the latter is more time consuming it has made for a more robust structure. Check it out on the Blu-Baby Classic 33 thread. Free plans and how-to there.
Ken
Thanks Ken
I knew your thread (subscribed to it) and I was this close to building according to your plans, but I figured there was a lot more to mess up when cutting the foam, so I decided I would do the layered white foam for now. I figured your plan will be much beter but only if cut with a Phlat printer or equivalent.
I will see how the performance of my baby is and maybe one of your kits is in the future! They look really nice!
Wally_in_NC is offline Find More Posts by Wally_in_NC
Old Dec 07, 2012, 08:48 AM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Originally Posted by Wally_in_NC View Post
Thanks Ken
I cut my monoblockless blu-baby, all the way from cutting the paper plans, gluing them to the FFF, transferring the outlines with a magic marker, cutting with a #11 exacto knife, and peeling the skins off, all in the course of one soccer match during the Olympics this year. It's much easier than you think
And I routinely plow my monoblockless blu-baby into the ground doing stupid stunts way too low and it's hardly bruised at all. I've also plowed it into football uprights doing 'field goals', and to JimHSoars' point I've bent the landing gear wire till they almost look retracted doing touch-and-gos (slam and stops), I use wheel collets from dubro, and the wheels have NEVER come off. It's my beater plane and I love it.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Dec 07, 2012, 08:51 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Have you tried leaving the skins on yet? It sounds like you would enjoy having the extra strength it can afford. I don't remove it unless I want to get better glue adhesion in that area. And I don't paint (only colored tape) so the skin it fine left in place.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 10, 2012, 10:15 AM
Joined May 2011
Thank you for the input.
I maidened it yesterday. It flew well, easy to control, you can slow down to a crawl and it can be quite fast too with the setup I am using (2000KV, 2S batt, 5 inch prop)
Thanks again for a great plane. Now to get my son to learn it.
Old Dec 12, 2012, 01:54 PM
Joined Jun 2003
Wheel and Airfoil Questions
Hi BB Fans:
I have 4 questions:
3 about wheels for the BB:
Shown in your 2nd pic in post #4813. are wheels that look fairly wide that I might like to use. Where can I get them?
In post #6369:
Originally Posted by BEC View Post
...As shown there's prop clearance for a 9 incher when using the 52mm GWS wheels I'm using. That means on moderate grass an 8 inch prop gets green tips, but the airplane gets up and down easily enough.
I can not find any of the 52mm GWS wheels you mentioned above. They look fairly wide. Could you suggest where I can get them please.
Finally in #5760 you mention DuBro wheels:
...Gear wire diameter: at least the .062 stuff (1/16 inch). Depending on how heavy your airplane is, the .078 might be better (though for that you'll have to ream out those DuBros).
I have a pair of Dubro's 2 1/4" ultra light park flyer wheels. They have axel holes significantly larger than the 0.078 (2mm) wire. Which DuBros wheels are you refering to above?
BB Airfoil:
You talk about the Rankin 4-40 airfoil and I have asked you directly about it. Did Tony actually use this airfoil or did you modify the 33 inch BB you made to the 4-40?
I appreciate you are very busy. I thank you for your time with my questions.
- Jim Holliman
Tulsa, OK
Old Dec 12, 2012, 03:15 PM
Rkapi128 is offline
Find More Posts by Rkapi128
United States, FL, Port St Lucie
Joined Oct 2012
need help
I am new to rc foam building and would like to give it a try. Found your plans and really need some step by step instructions on the build process. I have a motor, esc and servos from an indoor plane I crashed. I would like to rebuild it as an indoor 24" foam version of the Blu-Baby. Do you have build instruction and or a video that I could watch. Need specifics as to where to place everything. Thanks in advance.
Ron
Rkapi128 is offline Find More Posts by Rkapi128
Old Dec 12, 2012, 05:56 PM
Jack
USA, ME, Ellsworth
Joined May 2008
This thread has a summary of all of the Tony65x55 planes and planes and tons of other good info:
http://www.rcgroups.com/forums/showthread.php?t=997484
Browse that for links to a lot of good into on BB 33 (and other plane) building. If there is one single thread with a step by step build of a BB 33 I am not aware of it. But this thread on building the "Oshkosh Special" covers the process well. There is a list of the steps in the build and the build starts on page two:
**"Oshkosh Special" with video and plans** - http://www.rcgroups.com/forums/showthread.php?t=1040899
Good luck with the build, don't be afraid to ask questions here. When/if you start asking questions, mention the wing you intend to build (UC, KFm2, KFm3, etc.) and the material (FFF, Depron, Readiboard, etc.) you are using as it can make a difference
Jack
Old Dec 12, 2012, 08:21 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Hi BB Fans:
I have 4 questions:
In post #6369:
These don't appear as widely available as they once were. It took me three tries to find 'em. http://www.aeromicro.com/Catalog/gws...m__4906847.htm
I was erroneously referring to the DuBro park flyer wheels (http://shop.dubro.com/p/1-1-2-mini-lite-wheels-2) in response to the post immediately above.
BB Airfoil:
- Jim Holliman
Tulsa, OK
This post http://www.rcgroups.com/forums/showp...postcount=4820, not far from one of mine you linked to, contains the answer to this question.
I widened the monoblock to 2 inches. I made no other aerodynamic changes.
Also, the designer himself, in the very first post in this thread, says he used the 4-40 airfoil.
BEC is offline Find More Posts by BEC
Old Dec 19, 2012, 01:50 PM
Lutin is offline
Find More Posts by Lutin
Montreal St. Hilaire, Canada
Joined Feb 2002
hi guys,
looking for your input on the Blu-Baby 24...my question is what motor do you guys recommend for it.
thank you
Paul
Lutin is offline Find More Posts by Lutin
Old Dec 19, 2012, 02:16 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
I have one with the HK 1806 2500 Kv motor on it. 400-900 mAh 2S battery and GWS 6X3 prop. Tons of power (as in unlimited vertical) and will cruise around till you get tired of it. Oh Yeah and does it all on less than 10A, so a 10-12A ESC is fine.
bz1mcr is offline Find More Posts by bz1mcr
Old Dec 19, 2012, 02:18 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Hi Paul,
There are many suitable motors for the 24". What kind of performance are you after?
An E-flite Park 250 (2200 kv) is a real hoot on that plane and will haul it well with floats too. Though this is on the high cost end at ~$30.
Some motors that have got my attention lately are the Turnigy 2211 motors. Available in several Kvs, something near 2000 would be my choice. Plenty of pull on 2s while swinging a 7x3.5 prop. These motors are in the $10 range and really run smooth and quiet. 16g
1700 Kv
2300 Kv
Though out of stock at the moment this Turnigy Easy Match Park 250 with 2200 Kv is a strong runner as well.
Ken
Old Dec 19, 2012, 05:01 PM
Lutin is offline
Joined Feb 2002
thanks dz and bz for your input, i just went a slow performance plane to relax as this is going to be my first foam model, i like how he blu-baby is constructed so i went to have fun building and flying it.
thanks
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
