Old Oct 10, 2012, 08:17 AM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
My 42 flys fine with an Emax cf2822 (1200kv, 39gm) and a 8x6 prop on 3s. For 2s probably a 9" prop, or maybe a gws 1060dd (been a while, but I think I flew that combo) the beauty of the emax is it's only 6 bucks from hobbyking. I just bought two of it's cousin the cf2812 (1534kv or so). Nose bearings aren't the best on 'em, so doinks can be a problem, but bearings available at HK. But for the money ....
Your other problem is the big heavy 2s battery. The biggest pack I have is 1550 but I fly the BB with 1k or 1300mah 3s packs. You will get sedate flying and long flights with the 2s.
springer is online now Find More Posts by springer
Old Oct 10, 2012, 08:37 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by Chattercoma View Post
Hey guys, I am planning to build a 42" BluBaby and thought I should seek some expert advice. I am on a severe budget, however, and already have some gear to use.
This 20A ESC
This 1800mah 2S lipo
So the only real things I need are a motor, prop, and servos. I am planning to buy these 9g servos and a Blue Wonder 1500Kv. Can you recommend a prop and motor? Thanks.
Better deals on the servos are easy to find, here are two examples:
http://www.headsuprc.com/servlet/the...9g-SG90/Detail
http://www.headsuprc.com/servlet/the...g-Micro/Detail
I don't have any of the Power-Up brand but at $2 each when you buy two or more they are worth a try. I learned long ago that it makes sense to choose one brand of 9g servo and never buy any other. That gives you spare parts and full interchangeability on servo arms and retaining screws. My lifetime choice was the TP SG90 or HXT900 (same servo with different names).
If you can shop on eBay, do a search there for "SG90" and there are some good deals.
A 24g BW is not a good choice for a BB 42. You can get about 5A on 2S and that will put you trying to get in the air with 40W of power. Underpowered flight is an invitation to disaster and frustration.
You want a motor that weighs at least twice that amount and if you want to long term power for adding weight to the plane or flying in more trying conditions a 75 gram or so motor is not too much motor for a BB 42.
And for a BB 42 you don't want smaller higher RPM props, you really want larger and lower RPM props. For a newbie, even big slow fly props are a better choice.
But you already have 2S packs so now you have to buy a higher Kv motor to get the prop speed up a little. And that is narrowing your choice of props.
Here is a motor (46g 1350 kV) that will work and you can see from the prop tests there how the prop choices change as you go from 3S to 2S:
http://www.headsuprc.com/servlet/the...h-14%29/Detail
Here is a 71 gram 1100 kV motor that will work:
http://www.headsuprc.com/servlet/the...0-Sport/Detail
The sequence for making your power system choices should be in the following order to get the pieces matched up right:
1 - Plane
2 - Prop (sized to plane and of the right type for it)
3 - Battery (get cell count/voltage that is best)
4 - Motor (choose power level and kV to make prop work best)
5 - ESC (sized to handle the load)
We all went though the same learning curve probably. But if money is scarce and you have to get it right on the first try, you can do that.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 10, 2012, 12:27 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
haha lol id never buy that. you gotta get the clone. works just fine. its called: hacker clone 20-22l
yeah that should work too.
sirbow2 is offline Find More Posts by sirbow2
Old Oct 10, 2012, 01:16 PM
sir_clive is offline
Find More Posts by sir_clive
sir_clive's Avatar
Austria, Wien, Vienna
Joined Jul 2011
also sold as kda or keda.
sir_clive is offline Find More Posts by sir_clive
Site Sponsor
Latest blog entry: Wing Helper 1.0 Gone Live
Old Oct 10, 2012, 02:35 PM
Panoramix is online now
Find More Posts by Panoramix
Cheese eating monkey.
France, Bretagne, Rennes
Joined Jul 2011
If the nose of my blu baby tends to drop quite a lot in turns, presumably my COG is too much forward.
Am I right?
Panoramix is online now Find More Posts by Panoramix
Old Oct 10, 2012, 03:09 PM
sir_clive's Avatar
Joined Jul 2011
I'd say you are too slow in turns, or your turns are too steep. Some nose drop in turns is normal (that's why one always gives some elevator to compensate).
Too large fin can also be a problem, but if your build is true to the plans, I would not consider that option.
Where is your CG at?
Site Sponsor
Old Oct 10, 2012, 05:16 PM
Chattercoma is offline
Find More Posts by Chattercoma
United States, CA, San Diego
Joined Jul 2012
Sorry for changing my mind, but after reading your posts and doing some more research I decided that instead of buying a new ESC and an expensive motor, I would be better off buying a smaller 3s lipo and building a BB33. Sorry again for changing my mind, but I could still really use some gear recommendations. Thanks, guys.
Chattercoma is offline Find More Posts by Chattercoma
Old Oct 11, 2012, 02:57 AM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
My niece finished decorating her plane today. (Yes, it has a tongue.)
mclarkson is offline Find More Posts by mclarkson
Old Oct 11, 2012, 08:08 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
That is just too cute! Whiskers and all.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Oct 11, 2012, 09:27 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
That's awesome MC! You'll have to get us some close-up video of that one flying for sure so we can see that tongue flapping!
JohnsPop is offline Find More Posts by JohnsPop
Old Oct 11, 2012, 03:16 PM
sirbow2 is offline
Emress
Joined Nov 2011
mine isnt going so well:
BB42" flight fail (0 min 16 sec)
what do you think? i followed the bb42 plans pretty much exactly. motor is tilted a few deg down + right. the CG is pointing up slightly when held at 50% of the wing. sorry for the vid. someone else made it. does the same thing each time.
Old Oct 11, 2012, 05:02 PM
sirbow2 is offline
Emress
Joined Nov 2011
http://www.youtube.com/watch?v=ddBOsy0hlJ0
what do you think? i followed the bb42 plans pretty much exactly. motor is tilted a few deg down + left. the CG is pointing up slightly when held at 50% of the wing. sorry for the vid. someone else made it. does the same thing each time.
went to my LHS and they say its the CoG. will move the batt up
Old Oct 11, 2012, 05:22 PM
Jack
USA, ME, Ellsworth
Joined May 2008
With the plane supported on you finger tips at a distance of 1/3rd of the chord back from the leading edge, the plane should be level. If you hold it at eye level and arms length the bottom of the wing should be flat as will the horizontal stabilizer.
Being tail heavy is the worst possible situation for a maiden flight.
Hand launch and don't use full throttle. Run the motor up until you just feel the slightest pull in your hand. Then face into the breezes, and do a level, full arm forward push, from shoulder level with the motor at that speed. That should put it in level flight.
Use small control inputs and add throttle one or two clicks at a time and only if needed.
Good luck with it!
Jack
Old Oct 11, 2012, 05:31 PM
sirbow2 is offline
Emress
Joined Nov 2011
yeah thanks! i think that was the issue with my other one. ill just hollow out the foam a bit more and slide the battery up.
wow lol. mine is a good 30deg tilted back when at 3in (30% of 10in wing).
would the polyhedral change anything?
Old Oct 11, 2012, 05:38 PM
sir_clive's Avatar
Joined Jul 2011
jack, you are much more experienced then I am, but wouldn't 33% also be pretty far back? I think mine is somewhere at 28-30% and I felt very comfortable with that (kfm3 wing)
Site Sponsor
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
