Old May 15, 2007, 02:32 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Mayday, I think you need a little dihedral in those wings. Of course they may flex upwards during flight, at the moment they look to have a slight amount of anhedral which is bad for a rudder/elevator model.
The Dihedral will improve stability no end.
Del
Del-Dredd is offline Find More Posts by Del-Dredd
Old May 15, 2007, 05:52 AM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Mayday, you're right, the BB likes it slow. That's what it was made for! Are you getting good rudder response on your plane? I share Del's concern regarding dihedral. The Blu-Baby requires it to turn properly and to be the super stable learning machine a newbie needs. Are you planning on putting the dihedral in with the wing struts?
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old May 15, 2007, 06:37 AM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
MayDay,
On my first BB, I ended up adding a little nose weight also. On #2, I made sure that the servos, esc and rx were as far forward as I could push them. #2 is rock solid w/o any additional nose weight.
Love the EPP. Nice job on the wing. Dittos on the dihedral.
Pat
FirstShirt is offline Find More Posts by FirstShirt
Old May 15, 2007, 11:01 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Love the built-up wing - makes me wonder if I could build a wing with a flat bottom and ribs from 6mm FFF, CF spar, then Monokote the whole thing, so the ribs show through like a traditional built-up balsa wing. Would be a great method to build WWI planes to look more scale. Has anyone tried this?
warhead_71 is offline Find More Posts by warhead_71
Old May 15, 2007, 02:57 PM
nubee 1 is offline
Find More Posts by nubee 1
Joined May 2006
Well my Blu-Baby has red wings now. Krylon H20 works great.
Ken
nubee 1 is offline Find More Posts by nubee 1
Old May 15, 2007, 05:01 PM
Mayday!Mayday! is offline
Find More Posts by Mayday!Mayday!
Check my blog-updated
Mayday!Mayday!'s Avatar
Columbus,Ohio
Joined Nov 2005
Yeah the struts will add about 3/4 in dihedral on each side, and also help keep the wing from flexing up too much.
However, when we first flew this it was very windy and we crashed it maybe a dozen times. The wind even cartwheeled it over maybe 6-8 flips.
No damage at all.
After the wind calmed we flew it again and I can tell you the rudder and elevator are more than responsive. We are going to tame the throws down a bit.
The guy that we are giving this to is not a beginner, he's flown for many years. However, there will be a learning curve for him to get used to the new modified radio.
I liked the way the wing turned out too. Looks like if it was covered, it would look like a balsa wing.
Warhead- it should be easy to do. Make the ribs and slowly wrap the sheeting around.
I was planning on doing that for this wing, but I wanted that extra 9mm piece to help with damage control.
We pounded this plane in a couple of times, and it looks the same now as it does in those pics. The epp has the advantage over the FFF. Fanfold will tear off in big pieces or crush in, where the epp will hold it's shape after a crash and will tear but a little hot glue and your golden.
Thanks for the input and comments guys.
Now I have to work on my own Blu-Baby. Maybe 60in with floats. Yeah that would be nice.
Mayday!Mayday! is offline Find More Posts by Mayday!Mayday!
Old May 15, 2007, 09:20 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
I don't mean to ask a really stupid question
but since the wing is called a 4-40 I'm assuming that the
CG is 40 percent back from the leading edge???
Am I guessing right?
thanks
raythomas is offline Find More Posts by raythomas
Old May 15, 2007, 09:31 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Ray, the airfoil is called a 4-40 because it has 4% camber at 40% of the chord. CG is at 33% or 2.6 inches from the leading edge.
Mayday, a 60" with floats.. YES, I wanna see that!
Tony
Old May 15, 2007, 09:48 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
Thanks Tony
Man, I guessed way wrong didn't I.
Ray
Old May 15, 2007, 10:21 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Don't sweat it Ray. All the terminology can be confusing until you've been doing it a while. But you've come to the right forum to learn this stuff. There are lot's of very knowledgable folks in the Foamies forum that are only too glad to help out.
Tony
Old May 15, 2007, 10:49 PM
nubee 1 is offline
Joined May 2006
Tony Should I put some velcro in battery bay. I have it hinged with 2 nylon pin type hinge and magnets on other end. HA Maybe I should . Sometimes my landings are ??????? Its looking good. I'll
try to get some pictures of it while im in Fla. And post.
Ken
Old May 16, 2007, 12:03 AM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
I stuck a piece of skewer through the monobloc and wrapped an elastic band. Looking forward to your postings.
Tony
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Tony Help... I Shrunk the BluBaby
Well it was windy today and I had all these little pieces of foam laying around. WS 20", weighs 3.5 oz(100grams AUW). Midghty Midget Motor, Castle Pheonix 10 ESC, Futaba Micro Receiver and servos.Question is... Will it fly? Bob
Foamenator is offline Find More Posts by Foamenator
Old May 16, 2007, 02:19 AM
Del-Dredd's Avatar
Joined Aug 2004
Bob that looks great, BluBaby got a smaller twin brother.
Do not see why it should not fly, let us know how it goes.
Del
Old May 16, 2007, 03:03 AM
nubee 1 is offline
Joined May 2006
That is just to cute..
Ken
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
