I love my BB42 as well! I believe you can solve the turning left issue with a few degrees of right thrust on your motor/mount. Also if it climbs with a good amount of throttle you should dial in a little bit a down thrust as well.
You need one of these on all of your motors!! http://www.hobbyking.com/hobbyking/s...3%5Fbands.html Prop savers allow the prop to give if it hits anything and protects your prop and motor! (you just need the right size for your motor shaft) As far as landing gear goes...I personally don't like to use landing gear on my planes. Imo it makes it feel a little "dirty" in the air. Also because I have a very small paved driveway lined with trees, house and basketball goal. None of my planes seem to mind landing out in the pasture!
Buzz: for the students who want a different look, look at the BB variants thread (buried in the archives by now). It was a contest to morph the BluBaby into some other plane, and several guys contributed. Or, you can just turn the fuselage upside down, add new wing and tail surfaces and get a "sortof" P51: http://www.rcgroups.com/forums/showt...ighlight=bbp51
Low wing, looks like a fighter, flys like a BB (at least on 2s...). |
Latest blog entry: OSE One Sheet Edge 540 Video
USA, ME, Ellsworth
Joined May 2008
Do you have any downthrust and right thrust on the motor mounting? And you need something to save your shafts? How about saving the shaft and the prop at the same time with a prop saver? The tapered cone type of prop saver shown here works best and it also fits almost any and all props: Prop saver fitting - http://www.rcgroups.com/forums/showthread.php?t=1419378 Motor shaft replacing - http://www.rcgroups.com/forums/showthread.php?t=1240725 Order up a piece of that Thera-Band too, you'll not regret it! They work so much better than O-rings. Welcome to Blu Baby land! Jack |
Jody P.,
Jack is spot-on here. I made up the tool, and it works great. Instead of the Thera-Brand, I bought a slingshot rubber replacement at Wal Mart for about $4. A razor blade cuts the "donuts" very nicely from the tubing. For redundancy, I place two of the rings on the prop saver. I haven't had any snap, but from my experience you can get 8+ flights out of one before they start deteriorating (this is about an 8 month time-span, I haven't been able to get out as much as I want over the last year). One of the old-school guys in my club was still using o-rings; he really liked the setup, so I cut off several inches of tubing and gave him the razor blade. He uses these now. Welcome aboard! |
Joined Sep 2010
How's that for cheap? ![]() Bob |
USA, ME, Ellsworth
Joined May 2008
Jack |
United States, TX, Rockdale
Joined Jun 2011
| Thread Tools | |
| Video Blu-Baby Primary Trainer | Tony65x55 | Electric Plane Talk | 0 | May 05, 2007 06:05 AM |
| Chosing Trainer...Kit?Plans?RTF? | Seared Ice | Fuel Plane Talk | 49 | Aug 16, 2004 11:50 AM |
| Which SPAD Trainer to build?? Plans? | VBSuperMaxx | SPAD - Simple Plastic Airplane Designs | 12 | May 05, 2004 09:19 PM |
| Sold FS: Fireball 550 Trainer "PLANS" | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 4 | Dec 05, 2002 07:38 PM |
