U.K.
Joined Aug 2010
Ok,I've been going through this thread and have read through a few hundred pages and have printed out the plans for a 33" UC version.
Although I have some time on a Honeybee FP helicopter this will be my first fixed wing aircraft so I would like to ask for some advice on components. For the motor,from what I've read,the hexTronik 24g brushless outrunner 1300kv seems the most popular choice http://www.hobbycity.com/hobbycity/s...idProduct=2069 For an ESC I was thinking TowerPro 9g w12A Brushless Speed Controller http://www.hobbycity.com/hobbycity/s...eed_Controller as it's light. I already have some 2S 1000mah 20C LiPo packs so I'll be using them. What would be a good prop to match the above as I've no experience of choosing such things and have found many different types mentoned? Would this be ok? http://www.hobbycity.com/hobbycity/s...9mm)_(6pcs/set) as the numbers seem to be in the middle of the various ratings I've seen. Would 40mm wheels be about right? From what I've read it appears that Tony came up with the perfect trainer airplane and that everyone here is very helpful and innovative. Thanks in advance for any advice. |
Although I have never used them, I've heard of issues with those TowerPro Mag8 ESC's. IMHO, buy either a Turnigy Plush or Mystery Blue Series. Don't forget to buy a matching programming card if available.
HK is currently out of stock on the Turnigy Plush ESC's, you can buy locally (USA) at HobbyPartz. They sell Hobbywing and Exceed RC ESC's. Turnigy Plush, Hobbywing and Exceed RC are all the same ESC... just rebranded. IMHO these are the best bang for the buck in ESC's: http://www.hobbypartz.com/60atoproelbr.html The GWS 9x4.7 prop you have chosen is ideal for that motor on 2S. I have run the same setup on several planes and it works very well. |
The towerpro esc's have had issues with programming, (complicated and not the same # beeps between models) but for an easy flyer, you will probably just use it as it comes. The similar size Hobbyking SS model esc's are good too. For the motor/pack on a 33, I'd start with a GWS 8040.
Good luck! your assessment is right on, she's a great flyer! |
Latest blog entry: OSE One Sheet Edge 540 Video
U.K.
Joined Aug 2010
Thanks for the replies.I should've probably mentioned that I'm in the U.K.
Anyway,I've had another look at ESCs and come up with these two. First is Mystery 12A Brushless Speed Controller (Blue Series) http://www.hobbycity.com/hobbycity/s...idProduct=9485 I guess 1A BEC should be ok to power a receiver and 2 micro servos. Second is Hobbyking SS Series 18-20A ESC http://www.hobbycity.com/hobbycity/s...idProduct=6457 Bit bigger and heavier but higher current rating so could be handy for future projects and cheaper too. Any opinions welcome. |
Here is my 2 cents worth, based on my own experience with the great little Blue Baby.
http://unitedhobbies.com/UNITEDHOBBI...idProduct=4854 is great combo for it. But I changed the prop to a 10x8, and was much better. I started off using a 2s 1300 ma battery, but later switched to 3s 1300ma for much longer flights and more power. I am still using the same motor with well over 100 flights on it. Oh, and use a prop saver........well worth the $2 http://unitedhobbies.com/UNITEDHOBBI...idProduct=3738 Quote:
Ade: I have one of the Hobbyking ss 18-20esc's and it works fine for me. Didn't need to do anything to program it i.e. just soldered connectors and plugged it in. I think it autodetects the number of cells in the lipo pack, a useful feature.
Griff: try clicking on the hobby king header at top of this page. It always takes me there (and I think it makes some money for RCG) |
ade h,
I am still trying to get around to finishing assembly of my BB33 but have experience with setups with models of this type/size/weight. I have used several makes of esc with and without issues. The best smaller ones I have found are Himodel and Hobbywing. I have no experience of Turnigy but know people who have used them with good results. As you are in the UK no need to go to Hobbyking you can get all the suitable parts here for similar prices and you do not have to wait for a couple of weeks. ESC 10 Amp:- http://www.giantcod.co.uk/hobbywing-...-p-403317.html ESC 12 Amp:- http://www.giantcod.co.uk/hobbywing-...ler-p-327.html I have used several of these 12A units which appear to be clones of Himodel escs I have used and branded as WASP:- http://www.brchobbies.co.uk/?page=sh...ditem&item=404 Blue Wonder 1300KV motor:- http://www.giantcod.co.uk/blue-wonde...-p-402398.html Motor tube mount:- http://www.giantcod.co.uk/small-base...-p-402820.html Bulkhead motor mount:- http://robotbirds.com/catalog/produc...oducts_id=3549 Lightweight servos:- http://www.giantcod.co.uk/epower-mic...-p-403206.html 9x4.7 props:- http://www.giantcod.co.uk/slow-prope...-p-402389.html or:- http://www.giantcod.co.uk/propeller-...-p-402800.html prop saver:- http://www.giantcod.co.uk/30mm-prop-saver-p-402344.html and last but not least, wheels:- http://www.giantcod.co.uk/d40Ã93425...-p-403082.html I am sure this will see you good trust me. Hope this helps let me know how you go. Ash |
| Thread Tools | |
| Video Blu-Baby Primary Trainer | Tony65x55 | Electric Plane Talk | 0 | May 05, 2007 06:05 AM |
| Chosing Trainer...Kit?Plans?RTF? | Seared Ice | Fuel Plane Talk | 49 | Aug 16, 2004 11:50 AM |
| Which SPAD Trainer to build?? Plans? | VBSuperMaxx | SPAD - Simple Plastic Airplane Designs | 12 | May 05, 2004 09:19 PM |
| Sold FS: Fireball 550 Trainer "PLANS" | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 4 | Dec 05, 2002 07:38 PM |
