Old May 13, 2007, 01:14 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Ready for a Mission
BB Birddog II is ready for action... Used original gear, wing, and internal structure except for monobloc. Made a new tail section using Tony's L19 rudder and redrew a curved elev and stab. Also left the paper bacling on the foamboard for the tail section. Result is a lot stronger than plain stripped foamboard so I didn't use skewers for reinforcement as I did on my original. Weight is the same as before at 11 oz. Replaced the receiver with one with the full length ugly-assed wire. I hate long dragging visible antenna wire and rubber bands. Will fly tomorrow wind-gods willing. Here's some pics. Bob
Foamenator is offline Find More Posts by Foamenator
Old May 13, 2007, 03:06 PM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Gawd, that looks good Bob! The L19 fin and rudder look really natural on the BB. Good luck with the maiden. I'm in awe.
Madfisherman, thanks for weighing in with the J250 info. It's appreciated.
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old May 13, 2007, 04:55 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
Hey Tony
Yes I was talking about a SPORTWING for the smaller version.
I wasn't going to really come out and ask, just planned on reducing the
plans for the big one to fit the smaller one.
But if its not a bother, a PDF of a sportwing for the smaller BB would be great.
Thanks for the info on the j250 and sp280.
This is great.
Ray
raythomas is offline Find More Posts by raythomas
Old May 13, 2007, 06:08 PM
nubee 1 is offline
Find More Posts by nubee 1
Joined May 2006
SPORTWING ? I made a pair of wings 22 X 8" from FFF just to see how its done a couple months ago. I guess I need to hang them on something ? ? ?
Full flaperons. Huh ?
Ken
nubee 1 is offline Find More Posts by nubee 1
Old May 13, 2007, 06:30 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Ray, here you go. Here is a sport wing for the BB 33" although the wing is actually 32" (no tips). Just cut out the wing saddle flat along the marks on the BB Plans. Add an aileron servo in the centre joint. I would also glue a couple of 11" bamboo skewers inside the KFm strip for strength and away you go.
Tony
Old May 13, 2007, 06:32 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Ken
That should work. Of course, you need two servos for flaperons. Good luck!
Tony
Old May 13, 2007, 07:23 PM
nubee 1 is offline
Joined May 2006
I can handle the servos but now I have to learn how to work my Futaba 6EXA. Can you say Duh ?
Ken
Old May 13, 2007, 08:05 PM
nubee 1 is offline
Joined May 2006
Hey guys I'm puting a CF tube on my BB wing. Is 2 5/8" from leading edge sweet for CG ? Its a 2 piece wing joined with CF tubes in brass joiners. (like a Slow Stick)
Old May 13, 2007, 09:08 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
Hey Tony
Thanks a million.
I was just noticing that all the pictures of completed planes in this thread are using a single sheet of foam for the wings. So I take it that the KFm wing design is just for the sportwing version?
I appreciate the plans. Thanks Ray
Oh I forgot to ask, where is the CG on the sportwing version?
Old May 14, 2007, 06:51 AM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Originally Posted by raythomas
Hey Tony
Thanks a million.
Yes Ray, that is correct. The KFm wing is just for the sport version. That said, you could put a LITTLE dihedral in it and then it would float and roll too.
Remember, the BB is a primary trainer, not a pattern ship. If you want aerobatic, wait'll you see my next bird (BUWAHAHA)
The CG starting point is the same for both wings however, the KFm can tolerate a more aft CG and it will improve it's flight characteristics as well as it's aerobatic capability.
Tony
Old May 14, 2007, 09:09 AM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
OH NO!!!!
Next bird???
I haven't even finished this one yet!!!!!!!!!aaarrrrrggggggg
So much foam,
so little time!!:
P.S. So really the sportwing is just a reinforced flatplate like most of the indoor 3D planes going around today??
Are you still using PU glue on all your planes, and are you against using
hot glue?
Also, if I'm using a J250dd can I omit the slot for the motor stick in my block?
And nobody yet has posted any pictures on where there batt, servos, or rec are placed inside their plane.
Can you post some pics on that?
Thanks Ray
Old May 14, 2007, 12:45 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
hot glue?
Thanks Ray
No, the KFm is considerably more than "Just a reinforced flat plate". It has been the product of a huge amount of work. When built to the plan, you will be rewarded with a very good flying wing.
I use PU glue when I need structural integrity (like the LG slot), hot glue for most else. You can omit the motor mount slot. From the diagram you posted, bottom bay is for the battery, top bay holds the servos and receiver. Just lay 'em out as you like, there's lots of room and the placement is not too critical as long as it's relatively forward.
Tony
Old May 14, 2007, 01:44 PM
nubee 1 is offline
Joined May 2006
I'm happy ! I just put my suitcase Blu-Baby on the CG machine and its Spot On at 2.60 " & 11.78 oz.
Ken
Thats with 2 piece wing, removeable gear and elevator. 24 gram Hex 1300 & 800 Mah 20 C 3s. I might get crazy and spray some Krylon H20 on it.
Old May 14, 2007, 01:46 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
Tony
Sorry If I upset you by calling the KFm "a flat plate"
I was only going by the plans as I have yet to see one built.
I was unaware that it had been tested and used to such a high degree.
Please forgive me
Ray
Old May 14, 2007, 01:55 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Let's see Pics
Ken
Nubee... Are you going to post some pics? I'd love to see your BB and especially how you ended up with the wing attachment viewed from the bottom. Thanks... Bob
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
