Old May 05, 2007, 06:10 AM
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
** Blu-Baby Primary Trainer ** Plans, Pics and Fun!
The Blu-Baby. Is this the World’s Greatest Primary Trainer?
Well no, probably not. But after numerous requests from RCG’ers (and apologies to those who patiently waited for it), let me introduce you to the Blu-Baby, one of the sweetest little aircraft I have had the pleasure of flying.
It was developed for a specific reason; to provide a platform that my flying buddy, Airplane Ed, and I could actually fly inside an armoury without bringing home a bag of parts after every flying session. You see, we’re not very good pilots and concrete walls, terrazzo floors and steel beam ceilings are murder on our dumb thumbs. Every indoor session was followed by three nights of rebuilding and that was getting pretty thin. As we have a pretty long indoor season up here in Kanuckistan (nine months of winter, three months of road repairs) something clearly had to be done.
Enter the Blu-Baby. She is a 3-channel high wing monoplane of 33.5” span. She sports oversize tail surfaces for exceptional stability, moderate dihedral for tight turning and spiffy looks, a 4-40 undercambered airfoil wing with generous area for slow speed performance and pleasant stall characteristics and a simple taildragger gear with a rear landing skid. The Blu-Baby pioneered a method of construction I refer to as ”monobloc” construction, a technique I now use on many of my planes.
The monobloc method consists of sandwiching a solid pink foam block between layers of fan fold foam. The motor mount, battery bay and landing gear mount are all integral to the monobloc. The motor mount and LG are glued in place with PU glue and although I have had to redo the motor mount occasionally after impact with a concrete wall, I have never had a LG rip out. On large aircraft the monobloc can be reinforced with a couple of bamboo skewers PU’d into grooves cut into the sides of the monobloc.
As the fuselage sides glue directly to the perfectly flat monobloc sides, this construction method ensures the fuse is built perfectly straight and true. It also renders the forward fuselage “Brute Tough”, able to withstand abuse that would destroy a normal foamy. Best of all, this is done with little weight penalty as there is certainly not much glue (and no epoxy) present in the front end of the plane.
The Blu-Baby has been built in three different sizes, a 33” indoor and park flyer, a 42” park model with a GWS 350 for the Kid and a 60” AP plane with an accessory sport wing with no dihedral and full span flaperons. All three sizes have exhibited the same kind flying characteristics, super docile handling, very gentle stall and all around great manners.
The Blu-Baby can fly on several different power plants with great success. The first two 30” models used a GWS LPS and worked great. While they flew well, we dropped the LPS from the “recommended” list because of its fragility. One plane received a GWS IPS and the other got a J250 in a GWS “C” drive. The IPS is terrific for putting around indoors and the J250 is overpowered but fun. The 42” has flown on the J250 drive too but currently wears a GWS 350. The big AP bird flew nicely on an inexpensive BP21 and it now carries a ST Models 1000kv brushless for hauling around cameras.
This is a very easy airplane to fly. How easy you ask? Well, I’m glad you did. After two years of flying around indoors, dumb thumbs and all, both of the original planes are still in service and flying great. The Kid’s 42” is still in flying condition after innumerable contacts with the ground and two unplanned landings into the back of Airplane Ed’s pick-me-up truck. My AP bird still continues to click away over the skies of Oshawa.
Best of all, I have taught three different people to fly RC using the little Blu-Baby with the IPS in the nose. Time to solo: 15 Minutes. That’s right. Three different people who could successfully navigate the Blu-Baby across the skies in only 15 minutes of flight time! Easy to fly is an understatement.
* NOTE: Since the beginning of this thread, literally hundreds (maybe much more) of people have successfully built and flown this aircraft. For many, it was their first successful RC airplane. These pages are full of testimony to the simple build and easy handling characteristics of the Blu-Baby. Almost anyone can build and fly this aircraft.
Veteran RC pilots will likely be bored to tears with the Blu-Baby but it isn’t made for them. It is made for someone learning to fly, someone who want a nice docile indoor or cul-de sac flyer or someone who just wants to kick back and not have to think about it. It makes a Slow Stick or a GWS Moth look positively twitchy.
It is super strong to withstand those less than perfect beginner landings, built easily with a very low parts count (13 including control surfaces) and uses super cheap off the shelf components.
A friend of mine wants to learn how to fly RC and I will be doing this build for him. So far, he has completely destroyed a Slow Stick and an E-Starter but I think he will be able to fly this one. The plans below are presented with two different vertical stabilizers, a modern looking one and an old timey looking one. Both work well, so build whatever one spins your dials. As well, the wing mount has cut lines on it for both a 4-40 undercambered airfoil and a top step KFm. While the KFm has not been tried on this plane it should be fine for those that are looking for something a little different. The wing plan also outlines the piece necessary for the KFm top step. When rolling the camber into the 4-40 airfoil, the curvature should be rolled in parallel to the LE of the wing. This will automatically put the correct amount of washout into the wing tip.
I have not flown any airplane that was easier to fly. You can see the Blu-Baby flying indoors at:http://www.rcgroups.com/forums/showp...68&postcount=1
Try one and see if you agree.
Tony
PS: Plans for the 42" Park Model and the 52" Aerial Photography model are on Pg.8, post 107.
For a simple video lesson on how to roll a Blu-Baby 4-40 undercambered wing, click here:
http://www.rcgroups.com/forums/showp...23&postcount=1
Tony65x55 is offline Find More Posts by Tony65x55
Old May 05, 2007, 06:29 AM
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Nice one Tony, a good trainer is always worth it's weight in foam
dekan is offline Find More Posts by dekan
Old May 05, 2007, 08:30 AM
Redditch England
Joined Apr 2004
Thanks for the plans Tony
. It was well worth the wait
Now lets cut some foam up
PS will you be posting plans forn the 40 and 60" too ?
Don
donrecardo is offline Find More Posts by donrecardo
Old May 05, 2007, 09:23 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Always a worthy goal, Tony.
I know I continually look for the perfect trainer... every time I think I have it, a fresh idea comes along. That's why I'm working on the BluCub3 (EPP & KFm, yummy)
Gene Bond is offline Find More Posts by Gene Bond
AMA 14680
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
YaHoo... Tony
Subscribed... Thanks for the plans and info. I'm on the job. Bob
Foamenator is offline Find More Posts by Foamenator
Old May 05, 2007, 09:31 AM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
That sounds very cool. Is it posted yet? Gene, you gotta try one of these Blu-Baby's, tough, light, easy handling and that 4-40 airfoil is such a floater. You can bang one out in an evening or so.
Tony
Old May 05, 2007, 10:54 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I posted some pictures in the EPP thread and the KFm thread, aka EPPiper
Old May 05, 2007, 04:09 PM
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Tony, that's a very neat tariner! actually too neat to be given into the hands of a noob if you ask me
chara is offline Find More Posts by chara
Old May 05, 2007, 09:00 PM
AlexSv's Avatar
Savona,Italy
Joined May 2007
Very nice trainer, considering my flying skills......i'll go build SOME of them !!
BYe,
Alex
AlexSv is offline Find More Posts by AlexSv
Old May 05, 2007, 09:05 PM
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Guys, I can't say enough good things about Tony's trainer. To the degree I've flown this plane, I totally agree with his write-up. This is a very gentle flyer that seems incredibly durable.
The only difficulty I had with the BB was self-induced. On the maiden flights I found myself giving it far too much power. The BB likes to fly slowly and has excellent lift, so it only requires a little throttle.
The monobloc is a great innovation. I've yet to crash the BB (that's only because I gave it to a friend after a few flights), but it looks to me like the bloc will greatly increase the longevity of the plane in the hands of a new flyer. It also makes for a quick, easy build. This plane goes together fast.
I think the only place I deviated from the design is by making the fuse wider. No reason except that I wanted to make it look a little more scale.
I have a few more details and build pix beginning on post 174 of Tony's SE5a thread (another great monobloc plane!).
If you're looking for a good trainer, this is definitely a winner.
Thanks, Tony!
Pat
PS I have another BB in the works for a second friend.
FirstShirt is offline Find More Posts by FirstShirt
Old May 05, 2007, 10:28 PM
Joined May 2006
Great Job Tony!
If a beginner can feel ok after 15 minutes, you really have something there. Hmm, don't I still have some pink stuff left over?
Scott
Scott Crownover is offline Find More Posts by Scott Crownover
Old May 05, 2007, 11:04 PM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Bb #2
Yep, I really like the Blu-Baby! Here's a start on #2--for another friend who wants to learn to fly. I'm trying to make the wing "hi-viz." This is a great little plane! -Pat
Old May 06, 2007, 12:56 AM
Good glue is evil
melbourne australia
Joined Sep 2003
thanks tony
will this fly on j250 direct drive, as a trainer
40 and 60 ? sounds great to
video plays well 5 meg is about limit on dialup
Good forward thinking on the KFm wing
brucej is offline Find More Posts by brucej
Old May 06, 2007, 06:30 AM
Joined May 2006
So what does a J250 weigh ? Will a 24 gram Hex work ? I don't have any brush motors or 2s. I might try to make one with removeable stabiliser & wing so it would fit in a guncase.
Ken
nubee 1 is offline Find More Posts by nubee 1
Old May 06, 2007, 07:15 AM
Good glue is evil
melbourne australia
Joined Sep 2003
If my chinese j250's ever arrive i will weigh one for you
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
