Old May 02, 2007, 01:06 PM
beafraid8 is offline
Find More Posts by beafraid8
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
Best motor for T-Rex 600 on 6s?
Ultimately, I'd like the same performance I'm getting on my 450 with the Neu 1107h 1.5y on 3s, but I don't think that's possible.
What's the best motor? Is Steve Neu going to come out with one that's a bigger version of the 1107?
I've done plenty of searching and reading, but it seems most people are going 8s-12s for performance, but I'd rather not abandon my 4, 3-month-old packs.
Thanks!!
-Roman
beafraid8 is offline Find More Posts by beafraid8
Old May 02, 2007, 02:31 PM
bryguy17 is offline
Find More Posts by bryguy17
Joined Dec 2006
no clue on motors, but you could connect two of your 6s packs in series and go 12s
bryguy17 is offline Find More Posts by bryguy17
Old May 02, 2007, 02:33 PM
Tean is offline
Find More Posts by Tean
Tean's Avatar
Ross on Wye, UK
Joined Jan 2006
The Neu 1515 2.5d is the best 6s motor I've seen in a Trex. It's also one of the few that will fit easily. Most of the obvious motors are too wide to fit between the frames without cutting them away.
The low voltage is always going to be a barrier to getting really good performance from this size of model. I would think very carefully before spending money trying to tune up a 6s setup.
Tean is offline Find More Posts by Tean
Old May 02, 2007, 03:48 PM
Wheelhaus is offline
Find More Posts by Wheelhaus
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
^ very true. Using a 8s or 10s setup will allow you to use lower Kv motors. Higher voltage is inherently more efficient.
If you try to yank 2000 watts from a 6s pack, you'll hit 100 amp spikes (roughly)
However, if you want the same power (2k watts) from a 10s pack, you'll only pull about 57 amps (roughly).
This lets the motor, battery, and ESC all stay cooler (they are using less amps) and provide a longer life. The cooler these things remain, the less power (watts) are being burned off as wasteful heat. Higher voltage (to achieve a given watt output) means more energy is being turned into motion so you get more power, higher efficiency, and more consistency (lower amp draw so voltage doesn't sag as badly).
If you really must stick with 6s, the Neu motors are probably your best bet.
Wheelhaus is offline Find More Posts by Wheelhaus
Old May 02, 2007, 04:52 PM
kenmalecki is offline
Find More Posts by kenmalecki
Kings Park, New York
Joined Jan 2005
I'm curious too. What pinion would provide a h/s of 1950-2050 with a Neu 1515 2.5d on 6s in a Trex 600?
Thanks!
Ken
kenmalecki is offline Find More Posts by kenmalecki
Old May 02, 2007, 05:14 PM
raven_darkcloud is offline
Find More Posts by raven_darkcloud
Its up... Nope its not
Portland, OR
Joined Jun 2006
Also some are running madusa 36/50/1600 but the neu 1515 2.5 has more power I think.
raven_darkcloud is offline Find More Posts by raven_darkcloud
Old May 02, 2007, 06:18 PM
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
Yeah, I just can't fit the bill for the packs right now (or won't YET, anyway).
There's a ton of info here on the 1515:
http://www.thetrex600forum.com
Question Z Motor for the T rex 600 Southern T Rex Electric Heli Talk 10 Aug 22, 2007 03:29 PM
Discussion What motor for T-Rex 600 w/14s or 15s A123 dfrazier Electric Heli Talk 11 May 02, 2007 07:40 PM
Discussion Best Motor for T-Rex 450 SE HARRomeo Mini Helis 15 Apr 28, 2006 06:45 PM
Best Align Motor for T-Rex XL? theShark Mini Helis 6 Jul 22, 2005 11:28 AM
Advice on outrunner motor for t-rex rcmarty Mini Helis 8 Dec 25, 2004 12:56 AM
