What is litho plate?
There appears to be some confusion about using litho plate.
First of all, you don't need to anneal the material & it can be used for small intricate detail which is why it is used heavily for simulated riveted plate on the older warships & liners. It does appear to be tedious as hell to apply & I would consider using it in my own limited capabilities for only the most simplest applications for my own use such as a hull or superstructure with very flat sides. As you can see from the attached photos, some of these guys are wizards when it comes to using this stuff & you'll want to read their tips on preparation & what adhesives they use. If you want to learn more about litho plate, the Brits are probably the best source so I've included a few posts along with some photos from Modelboatmayhem. http://www.modelboatmayhem.co.uk/for...p?topic=3462.0 http://www.modelboatmayhem.co.uk/for...p?topic=3756.0 Of course, depending on your intended usages you can use other materlals such as thin brass, aluminum or styrene sheets & even heavy art paper to make the same effect. You'll see paper being used in the Darling hull build on one the links. Chuck |
Me thinks that gpzy meant .008" thick plate.
I found this tidbit on lithoplate https://www.alcoa.com/mill_products/...ctechsheet.pdf |
| Thread Tools | |
| Help with "litho plate" | Oian | Scale Electric Planes | 11 | Nov 28, 2005 09:27 AM |
