Old May 02, 2007, 07:27 AM
pmjass is offline
Find More Posts by pmjass
Team FlightPower AUS
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
SU-26MX 3D Full Fuz
Here is my latest. All 6mm Depron with the odd bit of ply and carbon here and there.
Still have a little bit of detailing to do. Model is painted in cheap poster paints.
Full fuz hollow laminated block core construction. This is the third model I have done this way and it works quite well.
See Post 8 for Link to the plans.
This is the second one I have built. I sold the first one and didn't get around to posting about it however it did make it into a pic in one of our australian modelling magazines.
Wingspan is 36"
AUW Around 16 oz.
Hyperion 2213/20
3S 1500 20C Flight Pack
Waypoint 84 Servos
JR 610 Rx
Hperion 30A ESC
APC SloFly 10x4.7 Prop
Hyperion Landing Gear (.10 size)
First one flew great. Expect the same from second. Model is largely profile scale.
Peter
pmjass is offline Find More Posts by pmjass
Old May 02, 2007, 07:48 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Looks good, how did you attach the landing gear? I have a problem with mine ripping out fairly regularly.
rmgmag is offline Find More Posts by rmgmag
Old May 02, 2007, 08:22 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
The fuz is a solid laminated block where the landing gear goes. A ply plate is expoxied in with a couple of blind nuts. Works well and quite strong.
I have also successfully used a ply landing gear plate inserted as a blade in to a solid section of the fuz.
Old May 02, 2007, 01:56 PM
Nigelp is offline
Find More Posts by Nigelp
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
SU-26MX 3D Full Fuz Foamy
Hi Peter,
Like the full fuz style 3D. With a 36" WS and only 16oz AUW that must fly well.
What sort of wing spar / stiffening have you used ?
Nigel
(p.s. The Fokker Dr1 in my avitar is one of yours, the big one (36" WS), lands like its got a parachute attached !)
Nigelp is offline Find More Posts by Nigelp
Old May 02, 2007, 05:30 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
G'Day Nigel
I recognize your DR1 Avitar. it is certainly one of the best renditions of my DR1 design that I have seen. It could also be adapted to the full block fuz design.
For the SU-26 I used a 6mm Carbon tube spar full span inserted into a slot cut with my dremel. It is stiff enough. I also have a 1.5 mm ply servo mount plate for the aileron servos that sits over the top of the top of the spar in the
centre section. This plate stiffens things up further.
Old Jun 24, 2007, 08:57 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Sukhoi 26MX
Finally put some video together.
For .wmv file:-
http://www.rcgroups.com/forums/showt...97#post7682068
OR
Sukhoi 26MX (1 min 51 sec)
Peter
Plans for this model will be available soon.
Old Jun 24, 2007, 09:19 AM
MadDuc is offline
Find More Posts by MadDuc
MadDuc's Avatar
Nice one! Great flying in the video as well.
We are looking forward to your plans
MadDuc is offline Find More Posts by MadDuc
Old Jun 25, 2007, 06:55 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
As promised plans should be available for download from the following (let me know if you have any problems:
http://home.iprimus.com.au/pmjass/G3R9L5/SU26MX.zip
The plans are free; however if you think a donation is appropriate then I'd be happy to receive it and put the funds towards buying more foam and preparing more designs. Paypal payments can be made to pmjass@iprimus.com.au
Next on the list is an Ultimate 10-300. I have a prototype half built and it is going together quite well.
Old Jun 25, 2007, 04:27 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
I'm certainly not expecting payment and I know a lot of people do not even use PayPal. If you do build one a post in the thread with a pic if you have one will keep me more than happy.
Old Jun 26, 2007, 02:29 AM
MadDuc is offline
MadDuc's Avatar
Thanks for posting the plans, I won't have time to start on this one now, probably after our summer holiday. When I have got pics, I'll show them here.
Old Jun 26, 2007, 05:46 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
I hope you like it.
Peter
Old Jul 02, 2007, 07:24 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
I have been considering offering short kits of all the foam pieces cut.
Let me know if you would be interested and what you think I should charge.
(Kits would be shipped form Australia).
If I get 10 or so interested I will give it a go .
Peter
3d foamy's su-26MX File help spacemanspiff 3D Flying 2 Oct 08, 2005 11:54 AM
3D/Sport Foamie Full Fuz Bipe pmjass 3D Flying 7 Mar 31, 2005 04:00 PM
Full Fuz Yak! edible_engine 3D Flying 8 Jul 14, 2004 01:34 PM
SU-31 3D powertrain? jerry426 Scratchbuilt Indoor and Micro Models 3 May 18, 2003 09:18 AM
Wtb Su-31 3d parrott Aircraft - Electric - Airplanes (FS/W) 0 Feb 05, 2003 10:45 PM
