May 07, 2007, 11:54 AM
United States, PA, Beaver
Joined Sep 2001
Originally Posted by Ron Williams
Store the Gorilla Glue (bottle) upside down or say bye bye in a month or so. I keep mine in a jar big enough to hold the bottle upside down within it and it lasts much longer.
Even doing that, mine used to harden. Then I read a post here ( sorry I forget who posted it) about using Silica gel in a closed jar to extend the shelf life of CA. I never had a problem w/ CA hardening, but tried it with the Gorilla Glue. Been using this storage method for about 6months now, and even upright the stuff is still runny was new (yea, runny is stretch).
For yet anther way..... When I need to fasten nyrod to something I make clamps out of balsa. I forget the dimensions, but I will route a strip in a small piece of balsa. The ripped notch is as wide and deep as the nyrod is round. Size of balsa strip is about 2 to 3 times as wide as the nyrod, and a little thicker. I usually make then an inch or so long, by ripping a longer piece and cutting it up. Just use that piece (those pieces) as a custom made clamp using any glue you normally would when gluing balsa to ply. I have yet to have fail like this.
