Old May 01, 2007, 01:32 PM
tioli is offline
Find More Posts by tioli
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
MS Composit Mini Swift
We've been flying the Swift II and the Maxi Swift for several months. Anybody tried the new Mini Swift? I have got one yesterday, but haven't broken it out yet.
tioli is offline Find More Posts by tioli
Old May 01, 2007, 02:30 PM
db1 is offline
db1
Find More Posts by db1
db1
don betz
db1's Avatar
United States, OH, Cincinnati
Joined Aug 2004
If it flies half as good as the SWIFT II it will be a winner. This it the first I've heard of it. Let us know how it goes. How do you intend to outfit it?
db
db1 is offline Find More Posts by db1
Old May 01, 2007, 03:37 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
The little wing has an interesting EPP motor mount. It also has pre-cut servo holes (the wrong orientation), and servo saver horns...We're using the Axi2203/52 motor with an 8A Brushless ESC, a AR6100. We're starting with an E-Flite 2S 800 battery (from the Blade CX).
Old May 01, 2007, 03:39 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Bob will maiden the little wing from the treehouse today...
http://www.rcgroups.com/forums/attac...mentid=1258903
Old May 01, 2007, 05:40 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Successful maiden at the end of the parking lot. Winds of 8, gusting to 12mph. The mini flies virtually the same as the Swift II. Not as stable as the Maxi, but what do we expect? The AUW is 160 grams, 44 of which is the 800mAh battery. (The recommended battery is a 2S 425 to 700mAh). Interesting to try a lighter battery. Flight time was way longer than we wanted. We made multiple launches for a total of 15 minutes of flying. It pitched up on throttle, but settled nicely on glide. Used HS-50 servos.
We mounted all the components, except the servos, on a centrally located strip of Velcro. Even mounted the motor mount with velcro.
The Mini Swift took several hard landings in lava (very sharp and hard), and didn't even scuff the EPP. The reason for that, of course is the light weight.
Old May 01, 2007, 09:28 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
More Mini Swift pictures...
Old May 01, 2007, 11:31 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Flew again this evening in gusty conditions. The wing doesn't have the LD that the others do. perhaps our next one will have to have more attention paid to weight. Or maybe she needs more boyant, less gusty conditions.
Old May 02, 2007, 01:30 PM
db1 is offline
db1
db1
don betz
db1's Avatar
Joined Aug 2004
Looks good!
What is the max prop diameter?
db
Old May 02, 2007, 06:54 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
I don' t have the wing in front of me, but I'd say the max prop diameter is 7 inches. It flies now on a 5.5x4.5.
Old May 02, 2007, 07:02 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Flew today at my buddies tree house. There were stellar conditions and the mini flew flawlessly. My first hunch that the little beast needs the right conditions was right. We launched without power and soared for as long as our necks would last. The mini soared as well or better than the maxi swift I was flying.
Lopakalolo also flew a Maxi Swift with no wing tips. It flew very well, more manueverable (less stable) than the stock Maxi. It has the added advantage of being easier to get out of trees without the wing-tips.
On one flight, Lopakalolo was flying my stock Maxi. He did an Immelman over head and the wind blew the wing over the tree we were flying from. Of course, he could no longer see it. He released the controls, ran down the steps of the treehouse, moved away from the tree, found the still flying wing, regained control, and came back up the steps of the treehouse to finish the flight.
Old May 02, 2007, 07:05 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Mini Swift ridge soaring...
Old May 02, 2007, 07:08 PM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Maxi Swift, no Wing Tips...
Old May 03, 2007, 02:01 AM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Built another mini swift this evening. Bone stock. It weighed in at 130 grams. a savings of 30 some grams. I'll fly in the morning. we'll see.
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Max prop size is no more than 6", without adaptation.
Old May 04, 2007, 01:52 AM
tioli is offline
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
The stock Mini Swift maidened this morning with great success. It torque rolls to the right with the application of power, but that's to be expected with the light weight. Lateral stability seemed better than its heavier sister we built yesterday. great glide ratio, indestructable due to the light weight.
Discussion MS Composit Maxi Swift Tamudoc04 Flying Wings 1080 Sep 11, 2016 04:58 PM
Discussion MS Composit Maxi Swift tioli Flying Wings 7 Sep 17, 2009 05:01 PM
Video [sub 4oz]MS Composites Mini SWIFT -=SLaPPiE=- Electric Plane Talk 0 Aug 17, 2007 01:04 PM
MS Composit SWIFT Delta Wing bobf Foamies (Kits) 25 Jun 30, 2003 06:47 AM
MS Composit Swift - PAINTING? Helicool Foamies (Kits) 4 Dec 30, 2002 07:38 PM
