Old Apr 30, 2007, 04:21 AM
ashvani is offline
Find More Posts by ashvani
aerobuddy
Joined Dec 2004
EagleTree Systems Pitot Tube ?
Hello,
Has anyone used pitot tube available with Eagle tree system http://www.eagletreesystems.com/Plane/plane.html ?
Is it good for medium sized models, like one with wing span 1.44m (<5ft)?
ashvani is offline Find More Posts by ashvani
Old Apr 30, 2007, 06:16 AM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Works great for me. I use 6" brass tube through the leading edge of the wing and a static reference flush with the fuselage. I've use it on two models about the same size as you mention.
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Apr 30, 2007, 07:18 AM
ashvani is offline
aerobuddy
Joined Dec 2004
Mr. Harper
Can u please share a picture of the assembly ?
Old Apr 30, 2007, 07:54 AM
d_wheel is offline
Find More Posts by d_wheel
Old fart. VAAATSP
d_wheel's Avatar
Deep in the Heart of Texas
Joined Jun 2004
Originally Posted by ashvani
Hello,
I first tested mine on an EasyStar . Used a 3" piece of plastic tubing for the pitot and left the static vent open inside the feselage. Worked great.
Later;
D.W.
d_wheel is offline Find More Posts by d_wheel
Old Apr 30, 2007, 11:33 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Ashvani,
Not much to see, but here it is.
Old Apr 30, 2007, 01:17 PM
ashvani is offline
aerobuddy
Joined Dec 2004
thanks!
Old Apr 30, 2007, 01:20 PM
clolson is offline
Find More Posts by clolson
Minnesota
Joined Sep 2004
This tip will cost $10. :-) But it is *really* easy to ding up your pitot tube when handling your wing. Even if you know it's there and are careful ... speaking from experience here. :-)
We use carbon fiber tubes because it's so easy to bend your metal tubes ... even when you are trying to be careful.
clolson is offline Find More Posts by clolson
Old Apr 30, 2007, 01:23 PM
ashvani is offline
aerobuddy
Joined Dec 2004
are they (carbon fiber ones) available for purchase .. ??
Old Apr 30, 2007, 01:54 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Olson is right! I've ripped the thing off twice in five flights.
Old Apr 30, 2007, 02:14 PM
ashvani is offline
aerobuddy
Joined Dec 2004
then i better use carbon fiber one.. thanks for the advice in time.. . i was just going to place the order for the EagleTree one.
Where can I get the carbon fiber one ??
Old Apr 30, 2007, 02:21 PM
clolson is offline
Minnesota
Joined Sep 2004
I see lots of carbon fiber tubes in my local hobby shop ...
Old Apr 30, 2007, 11:25 PM
ashvani is offline
aerobuddy
Joined Dec 2004
but then don't u need to calibrate it ??
Old May 01, 2007, 08:59 AM
clolson is offline
Minnesota
Joined Sep 2004
I don't have a lot of experience with pitot tubes. I've been told that in full scale airframes there is somewhat of an art involved with selecting the optimal location for the pitot tube. In our uav airframe, we extended the tube about 6" forward of the leading edge of the wing and far enough out that it wouldn't be affected by the prop wash. The resulting numbers from our sensor (Xbow MNAV) seemed very plausible. A coworker with much more UAV experience than I have indicated that the length of the pitot tube does not have an affect on the sensed pressure. I'm sure you would want to validate your own results in your own application.
Old May 03, 2007, 11:17 PM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
with the Xbow, you really don't have an option with the static pressure, since there isn't a connetor for the on the sensor. I just realized that the cooling scoop I put in the window may not be that great of an idea.
Unterhausen is offline Find More Posts by Unterhausen
Article Eagletree Systems MicroPower E-Logger Review with V2 Updates! frankswd Power Systems 38 Jul 05, 2009 07:57 PM
DIY Pitot tube kfong DIY Electronics 36 Nov 15, 2006 07:32 PM
Article Eagletree Systems MicroPower E-Logger Review frankswd Sailplane Talk 0 Feb 22, 2006 12:00 AM
Has anybody built a pitot tube? ElectroLawndart UAV - Unmanned Aerial Vehicles 5 Apr 23, 2005 04:11 PM
