Apr 29, 2007, 12:04 AM
Check the Bloq
Joined May 2002
April 28th 2007
Did some fitting of the engine cowl on the Mustang. The gear mounts have set for the Hawg, so I grabbed a photo op, hmmm curious about the nose gear, as I did not do the initial trial and fit, it appears the nose gear is not going to work its present location, additionally if I move the nose gear up higher on the bulk head, that will make the nose sit even lower than it is. I presume so that once all the gear and batteries are installed that will settle the main springs a bit.
Ray
