Old Jul 17, 2009, 04:36 PM
dniweerf is offline
Find More Posts by dniweerf
dniweerf's Avatar
Kampen, the Netherlands
Joined Nov 2008
Hi there MB & Airkid.....
Where in Germany are you guys jumping ? Why not come over to Holland and do a few jumps over here... Everything's mutch better over here...
Take the Puddle as well and we'll do quatro flying !
see ya .. Gert
dniweerf is offline Find More Posts by dniweerf
Old Jul 17, 2009, 04:39 PM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
actually we are quite close we are in Leer so to Groningen it`s only about 12mins flying... we are flying on all teh german frisian islands
meatbomber is offline Find More Posts by meatbomber
Old Jul 18, 2009, 01:17 AM
dniweerf is offline
dniweerf's Avatar
Joined Nov 2008
From Leer to Kampen takes only a couple of minutes more...and there's plenty of space to "jump"
And as you can see lots of water for the puddle's..
pherhaps one time....
enjoy you'r stay, and the nice weather..
see ya... Gert
Old Jul 20, 2009, 06:12 AM
dexterslab is offline
Find More Posts by dexterslab
Joined Mar 2008
puddle twin 100% info
Hi Meatbomber (and al other enthousiasts),
i have red pretty much of the puddle twin on here. i also saw a lot of pictures and movie of it. only thing i can say I LOVE IT!!! i downloaded the plans and started to build one my own. i love the slow flyers. so this is the one i want.
i have a question though. there is a lot written here about cells, props, motors and esc's. also a lot of model sizes 100%, 35%, 50%, 200% etc.
the thing is i can not understand what i need for the 100% version. i hope that you or someone else can help me out here.
i use a simple 35mhz transmitter. i have some scrap plane flying experience.
so my questions is if it is possible to get some sort of clear list of what to order at hobby kings or rc technics to power my puddle twin 100% version.
it would be nice if it is able to fly strait up so i need enough power. i love to fly long sessions and i love it to fly it slow too so low total weight ( a little difficult i think because i want it from both ends)
can you or someone else give me a few good combinations of motor,prop, esc and cells?
i understand that some of you fly with double esc and those are able to act seperately? can i use some mixer then or just a y connection so i can also add ailerons?
please help me out here.
greetings dexter
dexterslab is offline Find More Posts by dexterslab
Old Jul 20, 2009, 07:45 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Get 2ea KV1500 24g Motors, 2ea 8A ESCs and 2S 800mAh Lipo. That`s what`s driving my Acro Puddle and it goes straight up. I have the same Power combo in my Marlin scale flying boat and it flies a good 15mins at low power.
I use the Cherry 4 blade props on both but i`m not entirely satisfied as they are toomuch pitch for acroflight... the motors and ESCs get hot when you fly with a lot of power.
You can use a Y connector for the ESCs but then you use the possibility of differential power for water handling... that`s ok if you leave either the water rudder on or increase teh rudder size a bit. my Acro Puddle uses no water rudder and turns fine on water with rudder only, the rudder was increased in size about 20%
Old Jul 20, 2009, 07:56 AM
dniweerf is offline
dniweerf's Avatar
Joined Nov 2008
Hi there Dexter....
I fly the Puddle Twin II XL, and this is my configuration:
Motor: 2 x Emax 2822
Esc: 2 x turnigy 25 amp
prop's: 8x3,8
Receiver: Multiplex 7ch Synth-IPD
Lipo's: 2200 mAh 30 C
I can fly more then 30minutes...
gr. Gert
Old Jul 20, 2009, 12:16 PM
Joined Mar 2008
more info
meatbomber,
thanks for the quick reply. but there are still some things i do not get.
-what you mean by ea?
-where can i find the cherry props? i looked on hobbyking and rctechnics but i can not find them. and is there just one kind or do i need more info like 7X3 or something?
-did you mistyped in your former post about the esc? when i use a y i think i will not have the possibility of differential power for water handling am i right? i think you ment that and that is why i need the 20 % increase of the rudder or leave the water rudder.
i want to keep 1 channel for the ailerons so only one left for the throttle.
- what is the difference about a lipo 15c or 20c? what is best to take?
thanks again
greetings dexter
ps Gert also thanks for your reply but i think your puddle twin is a big one. i will make myself a plane with 83 cm wingspan. by the way i am also from the netherlands
Old Jul 20, 2009, 12:51 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Originally Posted by dniweerf
Hi there Dexter....
prop's: 8x3,8
gr. Gert
The GWS 9050HD prop is a great prop for those motors. You'll get more thrust from the larger diameter, and less drag because it's an HD prop instead of SF. If you want speed, try the 8060HD... "Super Puddle"
warhead_71 is offline Find More Posts by warhead_71
Old Jul 20, 2009, 03:15 PM
Joined Mar 2008
i found some stuff
Meatbomber,
i found this on hobbyking / hobby city:
hexTronik 24gram Brushless Outrunner 1500kv
Brushless Outrunner Motor.
Kv - 1500
Load Current 9A
For more specifications, please click on the 2nd image.
Kv - 1500rpm/v
Max Load: 7A
No Load Current: .5A
Suggested Lipo: 3 cell 11.1v
Thrust: 400g+
Suggested Prop: 8x3.8
price $8.59
is this right? the suggest 3 cell lipo. can i also run it with 2 then?
and can i add the props on this propsaver? or do i need to buy something else?
and i found a 10 amp esc of 8 grams for 12 euro. will this work?
Product: GX 10A Brushless ESC
i also found an other on hobbycity but this had also some negative ratings in between so it this ok to choose?
Hobbyking SS Series 8-10A ESC
The Hobbyking SS series comes with a limited range of programming functions and are designed to be plug-n-play.
A perfect ESC for those looking for something simple to use and economic.
Spec.
Weight: 6g
Cells: 2-3S (Auto Detect)
Max Current: 8A
Burst: 10A
BEC: 1A
sorry i ask so much but this stuff is kind of new for me
greetings eric
Old Jul 20, 2009, 04:11 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
eric just read up on the previous posts in this thread, there is all that allready covered several times.
ea = each
2cell will work just fine with the puddle and these motors
Old Jul 20, 2009, 07:37 PM
Joined Mar 2008
help me!!
meatbomber,
i spend all evening and half the night (it is half past 2 now and have to work tomorrow poor me) reading all along the tread here. i see a lot of talkng about the esc motors etc. but i still can not get clear what kind of props you have on the 100% scale pt. i saw the pics and it is a 4 bladed black prop. i see a link posted by you to the 4 bladed prop but i think this one is for the bit 200% pt. i don't think it is this one 4 Blade EP Propeller 10x8.25/254x209.6mm"" can you please give me a link to the propper propellors and then i am saved and complete.
thanks again and sorry for giving you such a hard time.
good news is. i started cutting my depron for the pt
greetings eric
Old Jul 21, 2009, 09:34 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
well problem is my 4 blade prop 7 x 3.2 is no longer in the hobbyking inventory or i would have sent you a link...
I still have a bunch so i didn`t have to think about a replacement yet... a 8 x 4 2 blade should work fine.. if the distance to the fuse is too small you can still trim the tips a buit.. just put the motor sticks on the outside of the middle rib instead of teh inside that will give you a few additional milimeters.
Old Jul 21, 2009, 11:15 AM
bobber is offline
Find More Posts by bobber
Flyin brick
bobber's Avatar
Joined Feb 2005
Eric, I'd advise you to ,use 2-blade props, they are more efficient than a tree- and way more than a 4-blade props. Except, ofcuz, if you going for the cool look The choice of the size depends entirely on your motor and your bettery (number of cells). Again, efficiency wise, I'd recommend a 3 cell battery, more volts means less amps and that's good
bobber is offline Find More Posts by bobber
Old Jul 22, 2009, 01:46 AM
Joined Mar 2008
Hi,
thanks for the help guys. yesterday i ordered all the stuff at hobbycity. so now we wait. and then we hope to fly a pt too.
yesterday a small disaster with an other plane. made a first flight with flycam on top. everything fine until a powerfailure. plane down in a narrow canal. after 10 minutes looking for it my dad found it. only he did not stopped the flycam by using the right button. so no saved flight movie then. so be warned. always shut them off in the right way
greetings eric
ps i will post some pics of the pt if there is something to show you
Old Jul 29, 2009, 01:22 PM
y001 is offline
Find More Posts by y001
Joined Oct 2006
Originally Posted by LucioleMC30
I've done a little video too, enjoy !
http://www.youtube.com/watch?v=Q45hGkxfiNY
nice flying
what do u Motor spec?
y001 is offline Find More Posts by y001
Question Puddle Twin XL Figure9 Waterplanes 296 Jul 10, 2015 06:36 PM
Video Depron Puddle TWIN Seaplane meatbomber Electric Plane Talk 20 Dec 04, 2011 06:29 PM
