Old Apr 26, 2007, 03:29 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Build Log
Depron Puddle Twin
Hello Guys!
Spring is here and my waterplane flying site, the "Swooping Pond" at Skydive PINK Klatovy (shameless plug ) just got enlarged! So Time to get started on a flying boat project i have eyed for some time now:
The Puddle TWIN
The Design is by Roland Merk from germany, Wingspan is about 80cm, All up weight (predicted about 250g or 8oz). i'll power it with 2 geared brushed motors very similar to GWS IPS-A drives i got here localy in the Czech Republic. The whole airplane is built from 3mm Depron and features a folded Wing (as in not only a flat plate but a full wing with ribs)
The plans can be fround here: Puddle Twin Plan it`s a free download.
I have so far printed the plans and cut paper templates for all the smaller parts.
Pics and progress to follow
Cheers
MB
meatbomber is offline Find More Posts by meatbomber
Old Apr 26, 2007, 12:15 PM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
MB, looks like a great plane! What scale are the plans?
Pete
peterv is offline Find More Posts by peterv
Old Apr 26, 2007, 01:18 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Theres a complete drawing that goes onto A1 Paper format and also a tiled version that goes onto A4 Paper format.. so drawings are 1:1 but you might have problems with the paper format when printing
As a bit of a build update i`ve completed cutting the Bits and pieces excluding the wing skin, so i`ll start building the fuselage tonight (maybe that depends on the amount of beer that comes with dinner )
Pics follow later tonight
Cheers
MB
Old Apr 26, 2007, 04:02 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Thanks MB, I have the file. Keep us informed and some pix when you start to assemble it please!
Pete
Old Apr 26, 2007, 06:16 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Ok, 5 beers later i`m not ready for sleeping witzhout at least starting a bit of the assemby
Here`s the pics
Old Apr 26, 2007, 06:33 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
fuse closed and weighted to cure overnight...
good night
Old Apr 26, 2007, 06:45 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Nice! Curious what type of glue you are using. And am anxious to see the motor mounting scheme you will use. Looks very good. Will you have a balsa rib where the wingtip floats attach or do you think the depron will hold. Great work! Now get some sleep!
Just got in from some float flying on my lake in some wicked fog.
Pete
Old Apr 27, 2007, 02:50 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
i use a combination of styro safe CA and contact glue... i try to use the CA only where i need to tack something down quick as it gets brittle and the contact glue (UHU Por for example) stays alwas a bit more flexible.
I Have Made the Ribs from 6mm Depron and thought about making a depron block with a short bit of silicone tube inside to hold the struts in the wing.. that should be plenty... the airplane is very light and if i touchdown bad enough to rip a tip float out i want to loose it without making damage to the wing. That gives you also the option of removing the floats for transport
Old Apr 27, 2007, 05:04 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
The fuse has now also the front and aft wing support formers in, and is basically complete. I have a bit of a twist in it... but as this won`t be a precision indoor aerobatic plane i guess it wont matter so much
The Fuselage is incredibly stiff !
The Elavator, Rudder and Water Rudder are next on the List
Old Apr 27, 2007, 05:29 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
ok, so empenage and water rudder completed... fuse is sanded and ready to paint
Old Apr 27, 2007, 05:48 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
i hadf to put a bit of paint on it i`ll make the paint scheme like the Sea Duck, orange and red.
Old Apr 27, 2007, 06:09 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Very nice MB!!
Pete
Old Apr 28, 2007, 07:54 PM
elyan.bra is offline
Find More Posts by elyan.bra
Brazil o/\o
Joined Apr 2006
Very nice!
elyan.bra is offline Find More Posts by elyan.bra
Brazil o/\o
Joined Apr 2006
Very good, sorry for my terrible english... I'm from Brazil
Old Apr 29, 2007, 06:20 AM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Neat work ............ and you wont loose this one in the reeds!
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Question Puddle Twin XL Figure9 Waterplanes 296 Jul 10, 2015 06:36 PM
Video Depron Puddle TWIN Seaplane meatbomber Electric Plane Talk 20 Dec 04, 2011 06:29 PM
