Old Apr 23, 2007, 02:49 PM
Andrew Mawson
Andrew Mawson
Guest
n/a Posts
Glue for expanded polystyrene ?
What do the 'team' suggest as a good glue for expanded polystyrene
sheet to stick to itself? I am making up some temporary formwork for
an epoxy fibreglass moulding and intend to make the structure from
expanded polystyrene. When it was popular to stick patterned
polystyrene to ceilings there was a special paste for it, but now it's
been banned as a fire risk I cannot find any.
AWEM
Old Apr 23, 2007, 02:58 PM
Tony Jeffree
Tony Jeffree
Guest
n/a Posts
Re: Glue for expanded polystyrene ?
On Mon, 23 Apr 2007 20:49:57 +0100, "Andrew Mawson"
PVA would probably do the job.
Regards,
Tony
Old Apr 23, 2007, 03:04 PM
Archie
Archie
Guest
n/a Posts
"Andrew Mawson" <andrew@no_spam_please_mawson.org.uk> wrote in message
news:VomdnVKw5b97kLDbnZ2dnUVZ8tGqnZ2d@bt.com...
> AWEM
How about Copydex? It is often used to stick veneer to EP for use in model
aircraft wings.
Archie
Old Apr 23, 2007, 03:48 PM
Andrew Mawson
Andrew Mawson
Guest
n/a Posts
"Archie" <archie@nospam.co.uk> wrote in message
news:7j8Xh.57097$aB1.55182@fe3.news.blueyonder.co. uk...
message
for
it's
> > AWEM
model
> aircraft wings.
> Archie
.....arg .... major snag ! The resin disolves polystyrene it seems
!!!!! Could use a barrier layer but I suspect it's going to be
plywood<G>
AWEM
Old Apr 23, 2007, 03:55 PM
willhaney is offline
Find More Posts by willhaney
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
Polyurethane glue works well. Light, strong and flexible:
Gorilla Glue, Probond, etc.
willhaney is offline Find More Posts by willhaney
Old Apr 23, 2007, 04:24 PM
Dragon
Dragon
Guest
n/a Posts
> AWEM
I don't think so Andrew.
Polyester resin dissolves polystyrene but epoxy doesn't.
Neither does Copydex.
Henry
Old Apr 23, 2007, 06:27 PM
Archie
Archie
Guest
n/a Posts
> plywood<G>
> AWEM
I seem to remember that Copydex can be thinned with water and no it doesn't
disolve foam. I know a guy who used it to glue the veneer to his foam wings.
Probably the best and easiest stuff to use is something called Gudy. It is a
thin film adhesive which once set, is stronger than the foam and can be hot
wire cut and sanded through the glue line with ease. This can be a problem
with the usual glues. Gudy will be too expensive if there is not much foam
to stick will repay itself in ease of use if there is a lot to do. This
article is old 1988 but the stuff seems to be still available from Neschen.
http://www.pssaonline.co.uk/designer...20Adhesive.htm
Archie
Old Apr 23, 2007, 10:12 PM
shane smith
shane smith
Guest
n/a Posts
thinned pva will work as a barrier between the and just about anything your
likely to put on it and it's cheap.
> AWEM
Old Apr 23, 2007, 11:23 PM
willhaney's Avatar
Joined Feb 2004
Has anyone else tried the polyurethane?
Old Apr 23, 2007, 11:36 PM
Stephen Howard
Stephen Howard
Guest
n/a Posts
I've been sticking thin sheets of polystyrene on the shed roof to cure
the condensation - best results I've had have been with using carpet
tile adhesive. It's icky, grippy and sticky - you'll need gloves.
Regards,
Stephen Howard - Woodwind repairs & period restorations
http://www.shwoodwind.co.uk
Emails to: showard{who is at}shwoodwind{dot}co{dot}uk
Old Apr 24, 2007, 01:36 AM
Peter Neill
Peter Neill
Guest
n/a Posts
On 23 Apr, 20:49, "Andrew Mawson"
> AWEM
Pop down to the local graphics supplies shop and get a can of 3M spray
mount, that should do the trick.
Peter
Old Apr 24, 2007, 01:43 AM
Chris Edwards
Chris Edwards
Guest
n/a Posts
>> plywood<G>
>> AWEM
.......is that that Icarus fella?
Chris Edwards (in deepest Dorset) "....there *must* be an easier way!"
Old Apr 24, 2007, 04:06 AM
Archie
Archie
Guest
n/a Posts
> way!"
No, he had feathers. Don't fancy sticking all these feathers on with Copydex
Archie
Old Apr 24, 2007, 06:44 AM
Peter Fairbrother
Peter Fairbrother
Guest
n/a Posts
PVA/acrylic, epoxy, some polyurethanes (eg gorilla glue, PU foams), some
spray adhesives (eg 3M type 77 or 78 and others). Or search ebay for
[polystyrene glue] if you only want a little.
Glues are now subject to some EU regulation or other which means that the
volatile organic solvents are being either minimised or done away with
altogether. It's (some of) these solvents which damage PS when it is glued.
I'm not up-to-date on this, but many glues have changed in the last few
years, so basically try anything you have handy on a piece of scrap, it
might work and save the cost and effort of buying something especially for
the job.
I use Wilko floor varnish ...
Peter Fairbrother
Old Apr 24, 2007, 06:58 AM
Tim Auton
Tim Auton
Guest
n/a Posts
If polystyrene glue is the same as polystyrene cement, that's exactly
what you *don't* want. It's designed to work on solid polystrene
(plastic models) and works by dissolving the plastic. It just 'melts'
straight through expanded polystyrene.
Tim
Glue for Polystyrene Flyguy55 Foamies (Kits) 2 Aug 09, 2003 03:37 PM
Glue for DAW EPP? JensJakob68 Electric Plane Talk 3 Dec 31, 2001 06:51 PM
Glue for Tiger moth fuse? AussieParkflyer Parkflyers 7 Dec 23, 2001 11:24 AM
Best glue for blue foam D-VII? Erinair Power Systems 7 Nov 10, 2001 09:26 PM
Best glue for Terry repairs? rob barham Foamies (Kits) 8 Aug 08, 2001 03:05 AM
