Old Apr 22, 2007, 11:59 AM
Rad Racer is offline
Find More Posts by Rad Racer
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
Simple 5V/5A regulator with voltage monitor
Here's a simple 5volt / 5amp, LDO regulator circuit with a twist.
Before we start.....I do know linear regulators are not as effiecent as switching type regulators.....but I decided to go linear anyway, and keep the design simple. Heck, you will get plenty of flights in between charges
This regulator circuit was designed to use 2 or 3 cell lipo packs to power the receiver/servos. It's integrated voltage monitor circuit, provides real-time feedback (LED's) giving you the charge status of your pack, so you know when it's time to recharge, hopefully preventing you from over discharging your LiPo.
I use one in my "electrified" H9 P47 warplane.....it works great!
Here's how it works:
Basically, the LM1084 regulator provides a clean 5 volts to your receiver, servos and PIC voltage monitor circuit. A PIC microcontroller (via voltage divider) measures the level of the pack and displays the results on 1 of 4 status LED's. The software is designed to "auto detect" the cells in your Lipo pack, so no needed to worry about manual switch settings. On powerup, the software will confirm (via LED flash's) that it has detected your battery pack correctly.
The monitor has 3 green and 1 red LED's. The green LED's indicate Full, med, and low charge. The red triggers at 9v for a 3-cell pack and 6.6v for a 2-cell pack.
Using surface mount components, mine comes in at 7 grams. For ease of construction, you can use thru-hole components...they don't add much weight.
Enjoy
Wayne
Rad Racer is offline Find More Posts by Rad Racer
Old Apr 22, 2007, 12:26 PM
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
Here's the schematic and board layout for anyone that might be interested in building one for themselves. Sorry about the napkin drawing....hopefully it's clear enough for everyone.
Old Apr 22, 2007, 12:40 PM
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
The hex code for the voltage monitor circuit above. This is written for the PIC12F675 controller.
Old Apr 22, 2007, 10:27 PM
podavis is offline
Find More Posts by podavis
podavis's Avatar
Louisville KY
Joined Nov 2004
Any chance of posting an .asm file? I've been learning pic-speak and need the practice.
I like the drawings, simple is good.
podavis is offline Find More Posts by podavis
Old Apr 23, 2007, 01:33 PM
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
I had not planned on releasing the source code for this project, as it is part of a larger project currently in the works. I can certainly explain the project in more detail...perhaps that will help you get started with your pic programming.
If interested, I do have some PCB's and programmed pics.....either or both are available at a resonable cost.
Thanks for your interest in this project.
Wayne
Yippee! In-flight voltage monitor for Li cells Bill Glover Batteries and Chargers 14 Dec 16, 2003 03:09 AM
Need help with voltage divider dynodale Batteries and Chargers 10 Apr 14, 2003 05:16 PM
Yippee! A 2050mAh 7,2V with a voltage of 43,61...WEIRD? mini-ellipse Batteries and Chargers 1 Mar 21, 2003 09:26 PM
Problems with voltage levels on HeCells Biggles604 Batteries and Chargers 3 Feb 21, 2003 02:53 PM
GWS 5A ESC with brake DICKEYBIRD Parkflyers 3 Nov 12, 2002 06:04 PM
