Old Oct 20, 2002, 04:43 PM
speedo is offline
Find More Posts by speedo
U.S.A.
Joined Jun 2001
List your Cargo Plane mods.+pics.
I`m putting together the multiplex CARGO Plane soon.
I have read somethings to do,like down thrust to the motors.
But what other Mods. to this Cargo plane should be done when building??
TIPS?
**Also show your "pics." of your Cargo Plane and what you used to cover it,I`m looking for ideas!!**
speedo is offline Find More Posts by speedo
Old Oct 20, 2002, 05:13 PM
bozmonster is offline
Find More Posts by bozmonster
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
My advice would be to NOT add the downthrust, the plane will climb no matter what you do, I added too much and it climbs even worse. Balance it a little forward of the CG, and I just trim the elevator down a bit to keep the power climb under control. I used a HS-81 for the rudder/tailwheel and a HS-55 for the elevator, try to save some weight in the tail as it will be tail heavy. Carve out the nose so you can move the battery forward, you still may have to add more weight to get it to balance. I also ditched the stock plastic wheels for foamies and it made a huge differance, the plastic wheels tend to skid on asphalt, foamies stick like glue. I flew my cargo more than any other plane this year, I love flying it! In its B-17 conversion it really draws a crowd, and EVERYTHING stops when it flies. Guys get mad when they're flying and I dont tell them Im taking off. Dropping parachute guys is such a blast! I also drop small foam gliders, tissue paper/flour bombs and those little white "snapper' things that you throw on the ground and they "snap". Cluster munitions..gotta love it! Ive managed to even cause a minor car accident from the gawkers!
Check out this site for some great mods, mostly in French though....
http://bungymania.inexos.net/index.php
bozmonster is offline Find More Posts by bozmonster
Old Oct 20, 2002, 05:14 PM
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
Another....Parachute guys and glider, I can get 2 jumpers and a glider in the bay.....barely....
Old Oct 20, 2002, 05:18 PM
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
Last one.....enjoy your Cargo!
Chris
Old Oct 20, 2002, 05:23 PM
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
Oh, I forgot one thing, I ended up putting a CF tube inside of the plastic spar, mine started to snap right in the middle, it might be a good idea to look into that.......
Chris
Old Oct 20, 2002, 05:51 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
A friend of mine has one. We decided to try changing the incidence of the horizontal stab since the power vs. trim change was horrible.
He cut the stab off and shimmed the LE up about 1/8". The improvement is huge. It only takes a tiny bit of down under full power now and the elevator is still in trim under glide. I'd say they made a mistake that should have been corrected before molding. Oh well.
BTW, we fly his with CAM 6 x 3 folders and 15 x 2000 nimh. Climbs well and flies 8 minutes easily.
Steve C
Steve C is offline Find More Posts by Steve C
Old Oct 20, 2002, 10:37 PM
speedo is offline
U.S.A.
Joined Jun 2001
VERY NICE Cargo(B-17) "bozmonster".
The B-17 look seems to be the way to go!
What kind of paint did you use?
What size batt. pack are you using,and how much foam did you move from the nose area to get the CG right?
It seems that this plane needs to be very nose heavy,right??
Also, what did you use for motor covers and what you used to install them?
Thanks all.
*Keep posting your Mods. and Pics. please!!*
Old Oct 20, 2002, 11:43 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Here's mine. Made a bunch of vacuum formed parts, a little sanding, everything else is stock. Flies great.
Steve
U812 is offline Find More Posts by U812
Old Oct 20, 2002, 11:48 PM
U812 is offline
Joined Sep 2002
another
Old Oct 21, 2002, 12:49 AM
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
Thanks speedo! I used Testors spray paint for the whole thing. Olive Drab, Red, Ghost Grey for the bottom, 2 coats, and a little thinned light spackle on the rough parts where I had to carve. Turrets are shaped from balsa, with toothpick gun barrels. The cowls are from some juice/water bottle bottoms, just glued them in place. As far as batteries go Im using a 8 cell cp1700 pack which is a bit small, but was all I could afford, I got a great deal on them. I have tried 2400's and 3000 Nimh and got some decent flight times. Cp1700's get pretty hot as you can imagine powering 4 motors, I get about 4 min flight time. Great Planes 50 amp esc with standard Gunther props painted. I had to carve out as much foam as possible in the nose to get it to balance. She does like to be a little nose heavy.
Oh yea...one more piece of advice.....dont hit any dumpsters......
Chris
Old Oct 21, 2002, 12:24 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Mods discussed here also inc flight video:
http://www.rcgroups.com/forums/showt...o&pagenumber=1
Herb is offline Find More Posts by Herb
Old Oct 21, 2002, 05:52 PM
speedo is offline
U.S.A.
Joined Jun 2001
Thanks for the info.!
Sorry to hear about your Cargo "bozmonster",
you going to try to repair it??
Who else has to make the Cargo more nose heavy and what size batt. pack are you using?
**** MORE PIC`s. of your Cargo`s! ****
Old Oct 21, 2002, 06:10 PM
Commando is offline
Find More Posts by Commando
Ft. Collins, Colorado
Joined Aug 2002
Cargo conversion
Are the four motors wired in series? Does one BEC control all four motors?
Commando is offline Find More Posts by Commando
Old Oct 21, 2002, 06:47 PM
Hopperfly22 is offline
Find More Posts by Hopperfly22
Oxford, MS
Joined Apr 2002
Those are both really cool looking Cargo's. I think the stock one's look pretty fruity. Or at least the one on the box with the balloons and bright decals.
Of course I've heard a few people complain about it wanting to climb so much, but when you consider it's designed to be able to carry up to 1 lb of cargo then empty it should want to climb a lot.
Hopperfly22 is offline Find More Posts by Hopperfly22
Old Oct 21, 2002, 07:11 PM
701 Super Jet is offline
Find More Posts by 701 Super Jet
Elk Grove,Ca.
Joined Mar 2002
Here's mine
701 Super Jet is offline Find More Posts by 701 Super Jet
Alert show your airhogs dominator mods (pics and tips welcome) brent_da1man Parkflyers 2 Feb 04, 2013 10:00 PM
Mini-Review List your custom Aero Ace Bi-Plane Mods duceduc Micro Ready-to-Fly 7 Jul 20, 2006 03:54 PM
List your first rc plane you ever flew? p-51 vertical Foamies (Kits) 136 Jul 29, 2004 04:01 PM
List your E-starter mods! here!!!!! bboydeezturb Parkflyers 38 Apr 30, 2004 05:44 PM
F/S-> B-17 Cargo Plane RTF *NICE* "PICS." (will ship) speedo Aircraft - Electric - Airplanes (FS/W) 6 Apr 13, 2003 09:06 PM
