Old Apr 21, 2007, 11:46 PM
Kai_Shiden is offline
Find More Posts by Kai_Shiden
Crazy Heli Technogeek
Kai_Shiden's Avatar
USA, WA, Seattle
Joined Sep 2004
Video
Profile SU-37 park acrobatics
This is just a little vid of my Depron profile SU-37 Rev5 in a nearby park, it's not a conventional depron jet, it's kind of an odd 3D hybrid (it has the control surfaces extended into the prop wash for post stall maneuvering).
-Kai
Profile SU-37 Depron Rev5 at the park (5 min 46 sec)
Kai_Shiden is offline Find More Posts by Kai_Shiden
Last edited by Kai_Shiden; May 06, 2007 at 04:59 AM. Reason: Removed Attachment to clear space, and replaced with youtube vid
Old Apr 24, 2007, 07:16 AM
ToxicToast is offline
Find More Posts by ToxicToast
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Awesome flight, Kai! Have you thought about making one with a LE turned down to increase stability at high AOA? I notice you get classic wing rock when the planes attitude gets up at slow speeds.
I think JetSet mentioned one time that toggling spoilerons on will help keep airflow over the wing surface when at these high AOAs. This could help too if you have a computer radio.
Very cool stuff, 3mm depron?
ToxicToast is offline Find More Posts by ToxicToast
Old Apr 24, 2007, 09:27 AM
Kai_Shiden's Avatar
USA, WA, Seattle
Joined Sep 2004
Thanks ToxicToast,
The problem with having LE droop is that it wouldn't be able to harrier inverted (I have a symetrical slat design that I just didn't get around to making on this version). This plane already has "spoilerons" in a way, the ailerons and elevons are tied together (elevons go up, and the ailerons go up at a reduced mix ratio).
This one is actually made of 6mm depron, spans 25" and with a TP1320 3s is 9oz AUW (I fly it both outdoors and indoors).
Here's a vid of the control surfaces I made a while back:
Profile SU-37 Rev5 control demo (1 min 3 sec)
-Kai
P.S. Not that it makes much difference to a plane like this, but I've switched to a DX7/AR6100 recently, so the flight vid is on the new radio.
Build Log Sukhoi Su-37 Super Flanker Park Jet jetset44 Pusher Prop Jet Models 3733 Mar 30, 2016 09:18 PM
Video Su-37 Park Jet Thrust Vectoring Demo jetset44 Electric Plane Talk 21 Mar 06, 2012 09:03 AM
Build Log Profile SU-37 Design/Build Thread Kai_Shiden Pusher Prop Jet Models 377 Nov 14, 2007 02:26 AM
FFF profile SU-25 rict Foamies (Kits) 1 Nov 10, 2003 10:49 AM
LF profile su-27 for edf50 bistek2003ny Foamies (Kits) 13 Aug 08, 2003 05:24 PM
