Old Sep 11, 2007, 07:13 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
It's just so CUTE !!!!
gpw is offline Find More Posts by gpw
Old Sep 11, 2007, 08:42 AM
Roger_war is offline
Find More Posts by Roger_war
Joined Sep 2007
Brazilian configurations:
spread of 19,68 counts
length of 14,51 counts
engine hexTronik 24gram Brushless Outrunner 1400kv 2730 heli 6x4 or Speed 2000kv heli 5x5
deprom 6 mm
batery 3s 860 mah or speed 1300 mah
consumption with 6x4 4amp
rx JR 660 72mhz or Corona sintetizado
TX 8103 JR or SX 600 converte for 2.4 ghz
Perfect plane
Roger_war is offline Find More Posts by Roger_war
Old Sep 11, 2007, 08:45 AM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Originally Posted by Bobrez
Sounds good count me in. Gunna try slow first but ima gunna take it up a notch next I hope the wings hold on
https://www.unitedhobbies.com/UNITED...idProduct=5453
21 amps on 2 cell NICE!!! REZ
Bobrez... if you try to put 21A throught that motor you're gonna smoke it...
These things are most comfortable between 7 and 10 amps and you're really pushing it on 10a.
In the past I've only pushed this motor design (different KV) to 7 amps, but have started propping up to really take advantage of them and am flying pretty much most of the flight around 8-9 amps. They now come down warm to hot with the motor mount heatsink VERY hot (doing its job and well).
These websites are ridiculous with some of the claims of what the motors can do and you're really better off buying a 'good' wattmeter or wattsup, or whichver one you want and gauging your prop useage from there.
With that said... this motor is pretty darn cool and I had one show up on my doorstep a week ago... I'd start with a 4 or 5" prop and gauge the draw from that on 2S, but realistically, stay under 10amps and this motor will last for you.
Go to 21 amps and it probably won't last the first flight.
Good lucK!
-mike s.
msmith is offline Find More Posts by msmith
Old Oct 22, 2007, 10:16 AM
Texas Buzzard is offline
Find More Posts by Texas Buzzard
Texas Buzzard
Texas Buzzard's Avatar
McAllen,Texas
Joined Mar 2004
TomCore CG=?
One more time.
Tom Core, Where is the Center of gravity, and what prop is best for you?
Texas Buzzard is offline Find More Posts by Texas Buzzard
Old Oct 22, 2007, 10:38 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
I have not posted to this thread in awhile the trick to getting this plane to fly correct it a perfect CG to far forward and (Ask me how I know you get a plane that will not pull out of a power dive) to far back and you get a plane the looks like its trying to fly up hill just right and she floats around at 1/2 throttle and at full speed is a nice little jet.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Oct 22, 2007, 08:44 PM
slickster is offline
Find More Posts by slickster
Joined Jul 2007
Bumping this thread.
This wing flies just too nice not to get recognition.
22.5" MiniCutlass
slickster is offline Find More Posts by slickster
Old Oct 22, 2007, 09:14 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
slickster, very nice! What's your set-up?
I've been thinking about building this. I just finished up the EPP F22 and have gotten about a half dozen flights on it.
I was wondering if anyone knew how the Cutlass compares to it?
rmgmag is offline Find More Posts by rmgmag
Old Oct 22, 2007, 09:53 PM
Joined Jul 2007
Brushless Emax CF2805 motor
MultiPlex MultiCont BL-17 ESC
APC 6X4E prop
EFlight 7.4V 800mAh 2-Cell LiPo (waiting for new 3s from LHS before cutting foam)
Spektrum Ar6000 reciever
It's faster and more agile wing compared to the F22 with same power setup.
The F22 is why I ordered a bigger battery. It might be to much for this wing. I'll find out this week when it comes in.
I stole the power train from the F22 to try out the Mini Cutlass. I haven't put it back yet. I REALLY like it.
Flies similar to a HyperFlea. Also seems to handle wind better.
For the $5.00 in foam, Definitely one of my best investments
Old Oct 22, 2007, 10:25 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Sound like fun. I guess I'll have to give it a try. I'm starting to run low on foam. Guess I'd better stock up for the winter.
Old Oct 23, 2007, 02:49 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Like it Slick, still on my favorite shapes list, After seeing Firetrappes video, I would build the full size one. The little one is too manic for me!
That why I like the F22, It suits my slower style of flying.
dekan is offline Find More Posts by dekan
Old Oct 23, 2007, 07:41 AM
Joined Jul 2007
I wanted to build the full size but didn't have enough foam and figured I'd give the mini a try.
I coudn't fly like Firetrappes video either, Id wet myself.
With the throws turned down, It flies slow and manageable.
I think I built my F22 way too heavy, needing more battery.
I'm ordering more foam from sloper. Building new light F22 and a SuperSlo 28.
Old Oct 26, 2007, 04:48 PM
tomcor is online now
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
COG is 11 1/4" from tip of nose. This is for the 30" model though. If you have the 24" version you need to adapt. Just try moving the battery forward or backward till it flys right. I will be flying my original 30" today.
tomcor is online now Find More Posts by tomcor
Old Oct 30, 2007, 03:22 PM
mj147 is offline
Find More Posts by mj147
mj147's Avatar
MS
Joined Jul 2005
Wow just happend to stumble across the SB foamy section (usually hang out in mini helis) and I'm already hooked. Placed an order for some EPP and quickly knew I had to build this guy.
Gonna build the mini. I have a 26g 28-05
is this too heavy for the mini? I prefer slow flight and currently still learning about prop size/pitch.
I will post pics and questions as I progress on build, thx for the posted free plans
mj147
mj147 is offline Find More Posts by mj147
Old Oct 30, 2007, 03:33 PM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
No it should be ok, check Slicksters posts 111/116
Old Nov 06, 2007, 04:09 AM
47UNE is offline
Find More Posts by 47UNE
Joined Nov 2007
Hi all,
I am wondering if this (http://www.wattsuprc.com.au/product_...sp?pid=EW-M001) 1500kv motor running on a 7.4v battery with an 8x3.8 prop would have enough guts to run the normal size (30inch) cutless? It says it will have 365 GNMS of thrust. Please help because I want to order my motor and batteries for the weekend.
47UNE is offline Find More Posts by 47UNE
Video EPP Cutlass Park Flyer tomcor Electric Plane Talk 2 Jun 23, 2008 05:58 PM
Discussion Which EPP park flyer query??? alfabeta Parkflyers 9 Dec 18, 2006 05:27 PM
Park Flyer buyer info sheet, Lets create one. Ray Brooks Electric Plane Talk 5 May 30, 2001 12:00 AM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 02:35 AM
Manufacturer of Czech "Champion" park flyer Neil Stainton Electric Plane Talk 4 May 14, 2001 06:22 PM
