Old Aug 06, 2007, 11:24 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Great Little Plane
I stumbled across this thread a couple days ago and once I saw her fly and downloaded the (FREE Plans) I had to build one
(I will post some pictures next post)
I used 9mm EPP Foam to cut out all the parts get yourself 2 sheets of foam 18x36 and you will have a bunch of foam left over to play with.
I have built some EPP kits before (SLOFLY28) and others so I know all the little tricks to build.
Make sure you have a bunch of New X-acto knife blades some strapping tape,I like to use hot glue with epp I know it adds a little weight but if used correct not much.
I went with a UH1300 kc cdrom type motor a gws 8040hd prop 10-12 amp brushless esc, a gws 4 channel receiver, 2 9 gram servos Im going to use a 3 cell 620 dualsky 11.1 volt lipo
My total AUW is about 8oz
Some great tips for the new and maybe first time builder.
1. when cutting out EPP foam any part of the plane that has a straight line example the 2 fuselage half's trace the top and the bottom half on one of the 4 sides of the EPP foam sheet that way you get a perfect square edge when you go to connect them, do the same for the wing half's
2. use a can spray mounting to do large surface example the 3 fuselage parts.
3. when using hot glue (here is a real super trick) when putting to parts together lets say the wing half's put some small toothpicks into one side of the foam and then poke holes into the other side of the foam piece to be joined push them together all the way to make sure you have a good fit, then once our happy with the result only pull them apart enough to put hot glue on one side of the foam then press together make for a perfect joint and its always straight.
this step makes putting the top and the bottom fuselage half's on straight every time a snap
4.when doing linkage for your servos always use dubro type ez-connectors
5. Did I say always use new sharp x-acto knife blades
6. I use my dreamel to cut a grove for my carbon rods (fast and easy) a soldering iron works well but if you need to do this make sure you have a well vented area.
7. ALLWAYS make sure your CG is correct before flying.
8. Remember this is a pusher plane turn the prop around.
9. If you dont have a computer radio a x-tail mixer is required.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old Aug 06, 2007, 12:31 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Tom, Whats with the 45 degree CG check dive, not heard of that one before.
Lets hope this thread gets as much interest as the Sumo, Si.
I hope it doesn't fade out before I have built mine!
As I need all the help I can get...
dekan is offline Find More Posts by dekan
Old Aug 06, 2007, 07:02 PM
onewoo is offline
Find More Posts by onewoo
Joined Apr 2005
Originally Posted by firetrappe
Denile, Here are the plans I modified to build the 22" version out of 9mm EPP. It's scaled down to 75% of the original size, the slots in the verticals have been increased to 9mm and the 'under wing doublers' have been changed to allow for a 9mm fuselage.
Is there any chance you could post a tiled pdf of the 22" version? When I printed the one you posted, the WS was 30". Doesn't look like it scaled down. Maybe I am doing something wrong.
thanks
onewoo is offline Find More Posts by onewoo
Old Aug 06, 2007, 08:04 PM
firetrappe is offline
Find More Posts by firetrappe
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Onewoo, Well spotted, it appears that I uploaded the wrong version of the Mini plans . My apologies to any of you that have printed or built using them. I've replaced the tiled plans in post #57 with the correct ones.
TF, thanks for posting your tips and photos, i'm sure they'll be really helpful to prospective Cutlass builders
Dek, I wouldn't worry about the thread dying before you build yours, i'll probably still be getting reminded of posting the wrong plans in 12 months time .
Note to self : triple check plans before posting!
FT.
firetrappe is offline Find More Posts by firetrappe
Old Aug 07, 2007, 01:41 AM
tallflyer's Avatar
Joined Jul 2002
A little sharpie work
I decided to make a thunder bird kind of look
Old Aug 07, 2007, 12:49 PM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Si, I have found a source of 3mm x 1.7mm carbon tube for the wing. What is the recommended dremel and attachment required to cut the groove. What glue do you use to glue the spar
Old Aug 07, 2007, 01:10 PM
tallflyer's Avatar
Joined Jul 2002
I use the Dremel 561 MultiPurpose Cutting Bit.
To glue rods
5 minute epoxy
foam safe CA + Kicker
hot glue gun
Old Aug 07, 2007, 01:26 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Dek, see post #35 for demel attachment and cutting bit links . As for an actual dremel, i'd just go for a cheap and cheerful Black & Decker copy (has the same thread fitting as a genuine dremel).
I use Household Welder for all my EPP gluing (from Slofly), but i've used UHU por in the past and it works just as well although it's thinner than Welder so you have to use more as the EPP seems to absorb it.
TF, yours is looking good, nice sharpie work . If you've not tried waterslides before, take your time and use a damp cloth (not a wet cloth) to avoid water seeping under the transfer and smudging the ink. From feedback, this seems to be the most common problem with people trying inkjet decals.
BTW, for any of you thinking of building a Mini Cutlass, it might be worth trying one of these motors : https://www.unitedhobbies.com/UNITED...idProduct=5432 . It looks to be suspiciously similar to the ELE C20 which is a great motor and is 5g lighter than the Blue Wonder equivalent.
Si.
Old Aug 07, 2007, 04:13 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
wow this is really nice
it looks like a mini stryker
could these do harriers at low speed or parform well past 80 mph?
brian94066 is offline Find More Posts by brian94066
Old Aug 07, 2007, 05:39 PM
tallflyer's Avatar
Joined Jul 2002
Ok a few more touches
Ok The Sharpie thing just looked bad when the light hit it so I decided to paint it over with a light coat of Delta CeramCoat Acrylic paint, It looks much better now!
I added a few water slide decals I will be adding a couple more.
Old Aug 07, 2007, 06:18 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Tallflyer,
Looks really sharp! Looking forward to a flight report and if possible, video!
leadfeather is online now Find More Posts by leadfeather
Old Aug 08, 2007, 06:25 PM
tallflyer's Avatar
Joined Jul 2002
Final Touches
OK I'm ready to Fly my EPP Cutlass ASAP I just added the last few little Decals I wanted to ADD (SEE How I promote the RC Groups) a little free advertisement goes a long way!
Old Aug 08, 2007, 07:44 PM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Didn't realize it but the Cutlass is 30" span that I made from the tiled plans, I am glad, because the smaller one would not have worked out as well for me.
Thanks for the plans; it is half painted now, when done I'll post a picture.
Len
edit: I removed some from the bottom of the fins, may take off more from the back of the fins. I think they are bigger than they need to be for flight, and the extra weight makes getting the CG right harder. Don't want to take off too much though. It has a great profile.
LenBFP is offline Find More Posts by LenBFP
Video EPP Cutlass Park Flyer tomcor Electric Plane Talk 2 Jun 23, 2008 04:58 PM
Discussion Which EPP park flyer query??? alfabeta Parkflyers 9 Dec 18, 2006 04:27 PM
Park Flyer buyer info sheet, Lets create one. Ray Brooks Electric Plane Talk 5 May 29, 2001 11:00 PM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 01:35 AM
Manufacturer of Czech "Champion" park flyer Neil Stainton Electric Plane Talk 4 May 14, 2001 05:22 PM
