Old Jan 31, 2012, 03:19 PM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
POWER SET UP ??????????
Building Cutliss --V2 -- 30 wing.
Building out of 3/4 in Blue foam. Assume will be some heaver then most builds
Have these power items ON THE BENCH.
Motor. a 1800kv Micro motor or 1300kv Bell Motor. Not sure which. From Hobby King.
ESC Hobby King 18A -- HK-HW20
Lipo 3S 2100
Prop -- several 6X 5.5 // 5X3 // 8X4 // 6X4 What do you suggest
SARG5 is offline Find More Posts by SARG5
Old Jan 31, 2012, 03:26 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
SARG5 BUILD
Building the Cutlass V2 -- 30 in wing
Build out of 3/4 in. BLUE FOAM
Have on the bench
Motors 1800kv Micro moto or it is a 1300 Bell motor, cannot tell which
ESC Hobby King 18A
Batt. -- lipo 3S 2100
PROPS -- 6 X5.5 / 5X3/ / 8X4/ 6X4E
This is my first build for this bird.
SARG5
Old Jan 31, 2012, 03:28 PM
hardlock is offline
Find More Posts by hardlock
hardlock's Avatar
United States, OR, Springfield
Joined Aug 2000
Here's some specs on the micro if its the same as yours?
http://www.toysonics.com/emax-bl1812...ess-motor.html
On the bell motor, there's some test results posted by users here:
http://www.hobbyking.com/hobbyking/s...idProduct=5427
Looks like the 8x4 would do it on the bell, but would be pushing the micro with 3S.
hardlock is offline Find More Posts by hardlock
Old Jan 31, 2012, 06:24 PM
xpilot1974 is offline
Find More Posts by xpilot1974
xpilot1974's Avatar
United States, IN, La Crosse
Joined Aug 2011
I powered mine with a 2200kv motor spinning a 6X4 Prop (tried 6 X 5.5 prop,esc went up in a big puff of smoke) connected to a 30 amp ecs and a 2200 3 cell lipo. It flies fast, rolls fast and lands a little fast.With it a little on chunky side weighing close to 1 1/2 pounds the Cutlass handle some strong winds . I had to paint the wing tips red. A Grey plane with Grey skies makes interesting flying.
xpilot1974 is offline Find More Posts by xpilot1974
Old Jan 31, 2012, 06:25 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
My moter looks like 1300 Bell. But can not tell about the 1800 , which is an
AX 2308N Micro motor.
In the hobby king www. site they look the same. NOTHING PRINTED ON THEM
SARG5
Old Feb 06, 2012, 08:36 AM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
I am working on Cutlass V3 40 in. wing. Build is out of 3/4 in. BLUE FOAM.
NEED SUGGESTIONS FOR POWER SET UP.
THANKS IN ADVANCE
SARG5
Old Feb 06, 2012, 04:23 PM
hardlock is offline
hardlock's Avatar
Joined Aug 2000
This one?
http://www.hobbyking.com/hobbyking/s...idProduct=5429
Scroll down for what users are saying about it and what to run it with.
Old Feb 06, 2012, 06:47 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
Thank you for the input.
That was the one that I was looking at.
SARG5
Old Feb 08, 2012, 08:08 AM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
FOR MY CUTLASS [40 in.] Build.-- our of 3/4 in. Blue foam. ??? Wonder how heavy and how much drag with that 3/4 in. stuff???
This is what www.headsuprc.com suggested for the above. I sent him pictures, etc.
POWERUP 400 Zoom Motor
HURC 40A ESC
EMP 6X4E prop
11.1v 2200 30C battery
Will give very nice speed and about 29 oz. of thrust
or
3536 - 16 motor
Emax 50A Budget ESC
APC 8x6E prop. if you have room
11.1v 2200 40C Lipo battery
This will give you about 45 oz of thrust,
SARG5
Old Feb 15, 2012, 01:19 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
Curtass v-2
This is my 30in and 40 in. Used 3/4 in blue foam. Why so thick.
Found a simi load of it at the RV mfg. plant in Chanute, Ks. when I went there for repair on the RV.
All Electronics are from HURC. Jeff is great to work with.
Description:
Description:
Description:
Old Oct 03, 2012, 05:11 AM
Lnk47 is offline
Find More Posts by Lnk47
from France
Lnk47's Avatar
Joined Oct 2010
Hi all,
I just wanted to thank you for this wonderfull scratch plane !
It flies very well, slow passes and high manoeuvrability with a good top-speed with my setup !
I've made few mods (smaller elevons, "depron" foam --> EPP airframe was too much soft with my 1st version)
AUW : 205 gr
Motor : Turnigy 3020 1800kv
ESC : 30 A
Lipo : 3S 1100mA 35C
Prop : 6x4 E
Servo's : 2x 5gr Hextronik
Cheers from France !
Lnk47 is offline Find More Posts by Lnk47
Old Oct 03, 2012, 08:12 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Couple more versions of the Cutlass. The little weeny one is made from $ store foam. It's 18 in. wingspan and weighs 1.8 oz. WO batt. Batt. is 3 cell 360 ma. Radio is the HK 4 channel orange rcvr with 1.7 gram servos. Motor is a Turnigy 5 gram turning a 5-3 prop. Flies like charm but to quick for indoors. Bigger one is unfinished (started about 10 yrs ago)33 in. WS with a 70mm ducted fan. Made from blue foam, all cut with a hot wire. Fuse. was cut in three sections. Wing is covered with Doculam, a stickyback plastic film. It has 1/4 in. balsa spars. Must finish it someday.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 17, 2012, 02:33 PM
Marty Slater is offline
Find More Posts by Marty Slater
Ceder Rapids,Ia
Joined Jan 2007
this one in 30''
Marty Slater is offline Find More Posts by Marty Slater
Old Nov 25, 2013, 01:58 AM
CHATCHAIAPI is offline
Find More Posts by CHATCHAIAPI
CHATCHAIAPI's Avatar
Thailand, Samut Prakan, Sam Rong Klang
Joined May 2013
My first cutless 30" wing span
-2212-1200kv
-8x6 prop
-40a esc
-3s 2200mah
Very stable, Great for both slow and fast flight. a lots of fun with this model.
Next, cutless will be 22" wingspan version.
CHATCHAIAPI is offline Find More Posts by CHATCHAIAPI
Old Nov 25, 2013, 06:16 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Looks great. What are you using for power??
Gord.
Video EPP Cutlass Park Flyer tomcor Electric Plane Talk 2 Jun 23, 2008 04:58 PM
Discussion Which EPP park flyer query??? alfabeta Parkflyers 9 Dec 18, 2006 04:27 PM
Park Flyer buyer info sheet, Lets create one. Ray Brooks Electric Plane Talk 5 May 29, 2001 11:00 PM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 01:35 AM
Manufacturer of Czech "Champion" park flyer Neil Stainton Electric Plane Talk 4 May 14, 2001 05:22 PM
