Very nice jobe DanT! I´ll build this project for me. I have to buy some stuffs in HobbyCity, and will also buy the motor to put here, what do you think on this one below: http://www.hobbycity.com/hobbycity/s...trunner_1300kv Or http://www.hobbycity.com/hobbycity/s...-drive_2205/22 Or the motor you are using in your plane Dant, is better? I would like to buy a good and cheaper motor . Could you please also show me the links of esc, I have two lipos 2s Thunder power 1320 to use on it. If í´m not asking you so much ... Thanks in advance, Luis Quote:
This is the motor I'm using at this time.http://www.hobbycity.com/hobbycity/s...trunner_1500kv
I would also get the motor mount for it.http://www.hobbycity.com/hobbycity/s...idProduct=5217 For one, it will take more amps then your first motor. Your second motor is heavy and to high of a kv motor IMO and will only make about 12 oz. of thrust . The little motor I'm using in this setup, can make 20 oz. of thrust with a GWS 8x4 prop!I do run it higher on amps full throttle it will see over 10 amps. But it will make about 560g of thrust !! At the price of this little motor, I don't care if it dies a little to soon! On this plane I don't need thrust because it's not,,, a 3D plane! So,, I'm playing with speed just for the fun of it , to see how fast I can make this little motor and plane go.. Next,, I do use a TP 1320 3 cell ! Not a 2 cell battery. That is how I get this kind of speed out of this little cheap motor. Next,, I use a CC thunder bird 18 esc . I know it's way more then this little motor needs, but I use these ESC and batteries in many different planes I have.. Some of my planes and motors pull 18 amps. As you know by readying my post in the past,, I for one don't care about weight! A little more weight in a windy place is a good thing. |
Dan,
I don't own a 2 cell I have been using those 24 gram motors from hobby city in my mini slinger. I had the same motor in a 3000 KV version and put it on a mini slinger. WOW, big performance boost, you need to try one of them! You will need to run a smaller prop and at least a 20 amp esc. I am using a zaggy 5x5 prop with this motor, on a 3 cell. I was wondering... what is the dimension of your cutlass from the firewall to the nose? Thanks! |
To rcar4
Oh, I have tried the 3000kv and the small prop and like these motor MUCH better. For one when using a small prop, and your coming in for a HOT landing, it takes TO LONG for it to make thrust and get you back up to flying speed. Next the same thing happens when you throw your plane. We have a lot of wind here ,so you have to have good fast thrust on hand for corrections . I don't have a ( mini slinger) but I can see why you would need a small prop on the stock setup, no room for a bigger prop in between the elevons. I set my fins out more( 8 1/2" inside) incase I want to run bigger props also.
Update , still working on paint scheme !
But it's coming along, I now have about 6 = 13 minutes flights on it and the CG is now just right. Also it seems pretty fast for a small BW 1500kv motor with a TP 1320 pro-lite 3 cell running a APC 7x5 prop. Still waiting for next prop to come in .
Flew my Cutlass Sunday and again this morning. It flys great at half throttle, but I am getting wing flutter at any higher speed. The thing floats in real well, but I think I have to much wing area. I will keep flying this one, but will try a double layer of foam for the wing on the next one.
rcar4,
Glade your having fun. One thing you might try on this bird, is supporting your elevon push rods in the center of travel .That might help with flutter ? And on your next bird? Move the wing brace more toward the back . Also,,it looks like your using very small lite servos? These can have a lot of play in them. I use stronger ones in my faster planes . Some use Hi Tec 56 servos. They have carbon gears and BB.
Dan,
Will defiantly move the spar back. A friend told me to CA the wooden dowel to stiffen it. Wish I had the money for better servos, I am using these, servos Wish you would come up with a pdf file of your plans, but that is easier said. I know I don't have the skills to do it. Everyone at the club thought it was pretty neat, and several asked about the plans. I am sure I will get it there, I will keep you posted. I have to build an ALF mig 15 for a friend, before I can get back to the Cutlass. Talk to you later, Ron |
rcar4
Ron,you can down load the pdf file for the mini cutlass . Then all you have to do is extend the wing 1 1/2 " on both sides . Put a ruler on the leading edge of stock mini planes keeping the same leading edge angle and draw it 1 1/2" longer on both sides. Next do the same for the nose add 1 1/4" and then draw new lines on sides. Now the cabin is my own design . And so are the elevons and width between the fins for bigger props. I use Hobby Lobby poster board with the paper off. And 1/2" poster board for the cabin sides with notches cut inside to make it easer to bend on a curve and make it lite. I also change the cabin high on the back next to the motor to help make it less tail heavy design. Have fun. DanT |
| Thread Tools | |
| Video EPP Cutlass Park Flyer | tomcor | Electric Plane Talk | 2 | Jun 23, 2008 04:58 PM |
| Discussion Which EPP park flyer query??? | alfabeta | Parkflyers | 9 | Dec 18, 2006 04:27 PM |
| Park Flyer buyer info sheet, Lets create one. | Ray Brooks | Electric Plane Talk | 5 | May 29, 2001 11:00 PM |
| Need help with 400 for park flyer | Cpietro | Electric Plane Talk | 2 | May 21, 2001 01:35 AM |
| Manufacturer of Czech "Champion" park flyer | Neil Stainton | Electric Plane Talk | 4 | May 14, 2001 05:22 PM |
