Old Apr 21, 2007, 08:18 PM
Chophop is offline
Find More Posts by Chophop
A jewel in the junkpile !
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
My nimh's didn't come back after winter
I have 6 nimh 8 cell batteries that were working fine Feb, they sat due to weather, now in April, I am lucky to get off the ground. Any way to bring them back ?
CH
Chophop is offline Find More Posts by Chophop
Old Apr 21, 2007, 08:40 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Try a couple of cycles charging at C/10 for 12 to 14 hours. They ought to come back OK.
Bill
ebill3 is offline Find More Posts by ebill3
Old Apr 21, 2007, 08:41 PM
Cubber is offline
Find More Posts by Cubber
Naturally altered
Joined Feb 2005
What brand are they?
Very slow charge followed by regular discharge, do it twice. After chargiing once again, any packs with less than 8 x 1.3 volts has dead cells in them. Put to regular use. If performance is not back after a few high discharge cycles (flying them), they are pretty much toast.
Cubber is offline Find More Posts by Cubber
Old Apr 21, 2007, 09:03 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
Thanx for the replies. Some are Eflite, some Walkera. All act the same. I tried several charge/discharge cycles, but charged at 0.7C . Will try C/10 .
CH
Old Apr 21, 2007, 10:08 PM
Raydee is offline
Find More Posts by Raydee
RC Addict
Raydee's Avatar
United States, NY, Niagara Falls
Joined Jun 2002
Funny I ran by this topic because I ran my Nimh cells for the first time today since last fall and they were very weak feeling. I slow charged them on 500mah and I will see if they do any better tomorrow......if not I will be getting lipo's sooner than I planned
Raydee is offline Find More Posts by Raydee
Old Apr 22, 2007, 08:30 AM
SilverFoxCPF is offline
Find More Posts by SilverFoxCPF
Bellingham WA
Joined Jan 2005
Hello Chophop,
When you stored you packs were they charged or empty?
Tom
SilverFoxCPF is offline Find More Posts by SilverFoxCPF
Old Apr 30, 2007, 03:24 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I stored them charged. After about 6 cycles they came back to life, and from 2.5 to 7 minutes flight time, about normal. I charged them full and used them straight off the charger, which is what seemed to bring them back. Funny, I just got some lipos that blow the nimh away.
CH
Old Apr 30, 2007, 09:12 PM
Jim Carr is offline
Find More Posts by Jim Carr
Endicott,N.Y.
Joined Nov 2005
I've raced R/C cars for 15+ years. We use the same batteries for the cars, in 6 cell packs,as you're using in your airplanes. However,ours are matched by voltage and run time for optimum performance. They are charged @6 amps and discharged @35 amps when they are matched. We routinely charge @ 6 or 7 amps when we race them. After a race they are discharged @ 35 amps until the pack voltage reaches .9 volts per cell (5.4 in a 6 cell pack). If the pack is to be stored for more than a week we put 10min. of charge back in the pack @ 6amps. If they will be used sooner, we leave them @ 5.4volts. Before charging, we discharge the pack to 5.4 volts and start charging again @ 6 amps. We never trickle charge.
NiMi batteries like to be warm. We use a peak charger that has adjustable peak detect drop back voltage, usually set at .03 volts. The pack will be around 100* when it comes off the charger. In the winter we even use a heating pad to warm the pack up before charging.The difference is quite noticable between a freshly charged pack and one that has sat for a while. Fly with a pack charged at home and then with a pack charged at the field and see if you can feel the difference.
Jim Carr is offline Find More Posts by Jim Carr
Old May 01, 2007, 02:11 AM
tb47 is offline
Find More Posts by tb47
Joined May 2006
That depends on your priorities. NiMH performs better when warm, but lifetime is reduced. If you prefer your batteries to last long rather than give optimum performance then try to not get them too warm.
tb47 is offline Find More Posts by tb47
Old May 01, 2007, 09:43 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
When forming (or reforming after a long rest like over winter) charge at 0.1C for 16 hours, any less may not do the job although you can sometimes get by with a 14 hour charge at this rate. Any less time does not bring all cells up to their proper voltage.
Rodney is offline Find More Posts by Rodney
my nimh's are dead flybike Batteries and Chargers 5 Sep 26, 2004 01:57 PM
Help! What's up with my Nimh's ?? Orion_V Batteries and Chargers 16 Sep 24, 2004 03:29 PM
Why can't I charge my NIMH's?? Buzz Batteries and Chargers 10 Aug 13, 2003 10:29 AM
My switchback's GWS 300C motor died after 3 flights Biggles604 Power Systems 21 Feb 12, 2003 12:10 PM
My Hot Cat didn't deserve to die this way...(sniff..sniff) Sal C Foamies (Kits) 9 Jun 20, 2001 12:23 AM
