Old Apr 21, 2007, 12:28 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
4" Haoye EDF test flight video
Here is a test flight video of the Haoye fan using a Hacker A40-10S on 8S 4600 ma LiPo Extreme pack. Pulls 67 AMPs at 1850 WATTs. Jet weight is at 7.5 lbs.
Bob
bruff is online now Find More Posts by bruff
Last edited by bruff; Jan 31, 2009 at 03:42 PM. Reason: spelling and correct Amp draw
Old Apr 21, 2007, 09:15 PM
darren jakel is offline
Find More Posts by darren jakel
darren jakel's Avatar
Maricopa, AZ
Joined Jan 2004
Looks good and sounds great! Good job.
Darren
darren jakel is offline Find More Posts by darren jakel
Old Apr 22, 2007, 12:02 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Nice work Bob, looked good in flight.
Eric B.
AirX is offline Find More Posts by AirX
Old Apr 22, 2007, 06:41 AM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
It's faster than the piper cub anyway.
Doug Bateman is offline Find More Posts by Doug Bateman
Old Apr 22, 2007, 09:17 AM
Mark is offline
Find More Posts by Mark
My dremel tool has no fear
Mark's Avatar
Reston, VA
Joined Dec 1999
the fan sounds good, nice jet sound. You say 8s 4600's but on the video it sounds like you say 10s, which was it? Also doesn't look like you have an inlet ring.
Mark is offline Find More Posts by Mark
Old Apr 22, 2007, 09:27 AM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
The 10S comment was concerning another plane that I fly. There is an inlet ring on the fan. It is a black plastic one that comes with the old HOB F-86 kit for use on the Kress RK-20 fan. That fan is 4" dia also.
Bob
Old Apr 22, 2007, 10:48 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Bob,
I ran the doppler on the flight, fast pass arround 89mph, the rpms of the fast passes were arround 23,000rpm.
Eric B.
Old Jan 30, 2009, 07:12 PM
randynsaudi is offline
Find More Posts by randynsaudi
randynsaudi's Avatar
United States, LA, Blanchard
Joined Jan 2006
looks good
looks and sounds good.. looking forward to your other motor test this weekend..
randynsaudi is offline Find More Posts by randynsaudi
Old Jan 31, 2009, 03:59 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Here are numbers from the test today. We used new broken in batteries.
Hacker Electric Turbine A40-10L:
8S Thunder Power Pro Power 30C
110 AMPs at 3540 WATTs giving 27,000 RPM
Motor temp was 140 degrees
6S Thunder Power 5000ma Extreme Ver 2, X-70 SB Pro ESC. 68 AMPs at 1556 WATTs giving 22,000 RPM. Motor temp was 103 Degrees.
So for almost doubling the AMP draw you only get 5000 more RPM.
I'm going with two of these in my Citation model. On 6S it will save some weight over 8S and performance should be very good 260 Watts/lb.
Bob
Old Feb 01, 2009, 11:37 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Here are some pictures of my BobCat using 4" Haoye and a Hacker A40-10S motor.
Bob
Old Feb 02, 2009, 05:59 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
wow bob thats what?4 volts from those cells at 110 amps? that's not too shabby!haha
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Feb 03, 2009, 08:21 PM
Joined Jan 2006
4" Haoye
Were did you get the inlet ring for the 4" Haoye.? in the Bobcat
Old Feb 03, 2009, 08:25 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
The inlet ring is for a Kress RK-20 fan unit. They came with the Royal Cessna Citation kit, also kress models sold them. I think EJF has a vacum form plastic version. E-mail them.
Bob
Old Sep 19, 2009, 07:23 AM
bozonghare is offline
Find More Posts by bozonghare
bozonghare's Avatar
Joined Sep 2008
Originally Posted by bruff
here are numbers from the test today. We used new broken in batteries.
Hacker electric turbine a40-10l:
8s thunder power pro power 30c
110 amps at 3540 watts giving 27,000 rpm
motor temp was 140 degrees
6s thunder power 5000ma extreme ver 2, x-70 sb pro esc. 68 amps at 1556 watts giving 22,000 rpm. Motor temp was 103 degrees.
So for almost doubling the amp draw you only get 5000 more rpm.
I'm going with two of these in my citation model. On 6s it will save some weight over 8s and performance should be very good 260 watts/lb.
Bob
congratulate
bozonghare is offline Find More Posts by bozonghare
New Product BT-CP and BT-Tail Rotor Test Flight Video Part King Electric Heli Talk 46 Mar 13, 2006 08:56 PM
GWS Zero Test flight Video..... lavneet_gyani GWS (Grand Wing Servo) 4 Jun 20, 2005 10:16 PM
Tiny X2 test flight! Video included Martin Hunter Parkflyers 7 May 17, 2003 03:30 PM
Woooo! Meridian 400 test flight. Video coming! Martin Hunter Parkflyers 18 Apr 03, 2003 06:43 PM
