Old Apr 21, 2007, 10:14 AM
infopimp is offline
Find More Posts by infopimp
PNF
infopimp's Avatar
Los Gatos, CA
Joined May 2005
Why not mega beefy layups for leadsled wings?
Planning my layup for the twisty-Jart, I have this sick (?) idea for the layup... something like:
0.75 oz veil (45 degree)
4.1 oz unicarbon (90)
8.95 oz glass (45?)
foam
Curious, is there a downside to making wing super beefy like this? It seems most people don't go this far... but I already have a 51 oz EPP Jart and am fine going heavier considering the local slopes. This layup would add... what... 6 oz to the wing weight?
Crazy? Downsides other than weight?
-s
infopimp is offline Find More Posts by infopimp
Old Apr 21, 2007, 10:29 AM
AndreasMergner is offline
Find More Posts by AndreasMergner
fun is the goal
AndreasMergner's Avatar
USA, NY, Albany
Joined Dec 2003
It will never fly that way.
I have a new 60" plane that has 45 oz wings.
If you think about it, a plank or flying wing has a really heavy wing for the weight of its fuselage and they do fine.
AndreasMergner is offline Find More Posts by AndreasMergner
Old Apr 21, 2007, 10:55 AM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
There are a lot of Fermin Sleds built heavier than this that fly well. Go for it!
T
timmig is offline Find More Posts by timmig
Old Apr 21, 2007, 11:03 AM
Sensiblenick is offline
Find More Posts by Sensiblenick
Tearing the Skies a new one...
Sensiblenick's Avatar
Sweden: Ystad
It makes perfect sense actually.. You WANT weight, so shove it in the wings and get strength as an added Bonus.
Not only that... but the wings will support thier own mass... reducing the stresses in the airframe by spreading the mass thoughout the plane
Sensiblenick is offline Find More Posts by Sensiblenick
Old Apr 21, 2007, 11:07 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
does it make a difference to roll rate?
just curious.......
satinet is offline Find More Posts by satinet
Old Apr 21, 2007, 11:12 AM
BeeDee is offline
Find More Posts by BeeDee
Der Haifisch!! R.I.P.
BeeDee's Avatar
Fallbrook, California, United States
Joined Jul 2003
yeah, the roll rate will suffer if you have the mass towards the tips... also tip stalls are more pronounced with weight in the tips.. oh and can you say "Snap Roll" ??
BD
BeeDee is offline Find More Posts by BeeDee
Old Apr 21, 2007, 11:13 AM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
i see. I was imagining that you would get a high roll rate with a lot of weight in the middle and not much on the outside.
Old Apr 21, 2007, 11:17 AM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
All good points here. The heavier the wing the more inertia you get out where you ordinarily don't want it - BUT, if this is to be a lead sled timmig has it right: plenty of sleds are built with heavier layups than the one you describe, Steve. In fact, I'm working on a double carbon (2x5.7oz) wing right now. For big, smooth, ballistic halfpipes, your layup will be fine.
Reed is offline Find More Posts by Reed
Old Apr 21, 2007, 11:27 AM
RMD72377 is offline
Find More Posts by RMD72377
United States, CA, Hermosa Beach
Joined Feb 2004
Your best bet is to layoff so much glass and build your wing with sheeting and a hardwood LE. In my first sled wing layups with Bluffman and Slopeiron we found that regardless of how heavy you layup glass over a bare foam core (even with carbon) once the LE is comprimised it wont be long before cracks and delam start growing towards the TE. We tried to compensate for this with more glass but it still didnt help. One wng we did was 3 layers of 8 ounce cloth. Now we build are wings with plywood sheeting and hardwood LE then we bag them to seal them up and provide a nice surface for painting. I have detailed the process as best I can here http://www.rcgroups.com/forums/showthread.php?t=649145
RMD72377 is offline Find More Posts by RMD72377
Old Apr 21, 2007, 11:48 AM
timmig is offline
timmig's Avatar
Southern California
Joined Sep 2003
Robert's right--- the "conventional" build with glass over that is far stronger than foam/glass/carbon!
FWIW
Tim
Old Apr 21, 2007, 12:16 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
My R3 wing will come in at about 31 to 32 oz. My layup was a layer of 5 oz S glass and a layer of 3 oz e glass. I used way to much epoxy which added at least 3 oz extra weight to the wing.
davidjensen is offline Find More Posts by davidjensen
Old Apr 21, 2007, 12:30 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
FWIW
Tim
True in my experience as well. Ply has great properties and it's cheap! Chunky LE's help as well. I still go for the all-composite experience most of the time because I don't have rocks and I don't fly much heavy formation.
Old Apr 21, 2007, 01:17 PM
ENGINETORQUE is offline
Find More Posts by ENGINETORQUE
ENGINETORQUE's Avatar
United Kingdom
Joined Feb 2005
your roll rate will be, as they say 'adequate' - the heavy lay up makes for a heavy aeroplane which flies faster and rolls like a bag full of rolly things
ENGINETORQUE is offline Find More Posts by ENGINETORQUE
Old Apr 21, 2007, 01:48 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
I wasn't suggesting it was a bad ideal because of slow roll rate. I was just wondering how the physics work out in the real world. I'm afraid I don't have anything in that category. Yet!
Old Apr 21, 2007, 02:50 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Yep, your intuition is correct. Better flying characteristics all around.
Any particular reason why people chose mega motors for their wings? ScYcS Flying Wings 23 Dec 19, 2007 07:19 PM
Why not use RJ45 connectors for servos? Riserflier The Builders Workshop 11 Sep 30, 2005 10:12 AM
Why Not More 4s Setups for Micros? rscamp Mini Helis 8 Nov 01, 2004 05:53 PM
After flying rc for a while why not go to a real airplane? j_z_123 Life, The Universe, and Politics 17 Dec 28, 2002 10:37 PM
OK the mega 22/30/3s not available, which hacker for 22-24 cp1700s in a midi fan birdseed Electric Ducted Fan Jet Talk 3 Aug 27, 2002 11:38 AM
