Old Apr 20, 2007, 01:38 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
looking for DIY receiver designs
I did a small search yesterday and didn't come up with anything, I'll look around more this weekend, but I'm looking for a DIY receiver design. Mostly need the MCU and code so that I can use an existing RF board. If you know of any, please link them or maybe suggest some good keywords for another search. Thanks.
village_idiot is offline Find More Posts by village_idiot
Old Apr 20, 2007, 03:45 PM
HLGNut is offline
Find More Posts by HLGNut
Beaverton, OR
Joined Apr 2002
Here's something that might help.
Try: http://www.mstar2k.com/
and look at the "Pulsestar" description AND downloads.
- Bob -
HLGNut is offline Find More Posts by HLGNut
Old Apr 20, 2007, 05:13 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
http://home.nordnet.fr/~fthobois/
Steve
slipstick is online now Find More Posts by slipstick
Old Apr 20, 2007, 08:06 PM
Inciting Riots
Joined Dec 2006
The PulseStar is close to what I'm looking for, and Gordon might be able to help me get where I need to be. But I'll take any other suggestions
Old Apr 21, 2007, 01:12 AM
macquen is offline
Find More Posts by macquen
Micro-Scale-Modeler
macquen's Avatar
Charlotte, North Carolina USA
Joined Nov 2004
I am using the detected, mixed superhet output of existing Corona, Microjoule, and Blue Arrow servo output rcvrs, and modifying them for actuator use by simply replacing the stock 8-pin PIC12F508 with a PIC12F629 programed for actuator use. I understand that you have an rf deck, but need a decoder. After I program the 12F629 with YAPP.hex I next mount piggy back style a quad op-amp (LM324 etc.) to function as a low resistance (30 to 70 ohms) actuator driver as shown in the attached drawing. I have attached photos of rcvrs I have modifyed. If you are looking to drive servos the op-amp is not required how ever you must program the PIC12F629 with a different serial to parallel program. In the case of actuators the 12F629 outputs to two actuators, and one IRLMN2506 N-channel mosfet motor driver - In the case of servos the 12F629 outputs to four servos, three for flying surfaces, and one for a esc. I am attacing all the above information along with photos. The photo without explanation shows a modified Corona next to a JMP combo rcvr for size comparison.
Cheers - Steve - WB2TMR
macquen is offline Find More Posts by macquen
Old Apr 21, 2007, 11:09 AM
Inciting Riots
Joined Dec 2006
Very COOL. Thanks, I'll give this a read. This is all working towards an open source 900Mhz or 2.4Ghz system, so there will be a different choice than taking the RF section from an existing receiver for you to use. Not sure if it will be small and light enough for you though. The 900Mhz has a very small low power RF module that might work, and may be what I buy at first to get going. I haven't fully decided on whether I start with 900Mhz or 2.4Ghz, but it will be PPM to start and move towards some other kind of serial protocol in the future, probably using a MicroStar radio for the serial version. If you haven't checked out the MicroStar, you can find it at the link above for the PulseStar. I have a kit on order, and hoping it comes in soon!
Do you have the source code (in C) for the above MCU?
Still open to other suggestions.
Old May 14, 2007, 06:00 AM
Gura is offline
Find More Posts by Gura
Gura's Avatar
Joined May 2004
Help!
What is it? What face values of these details?Thanks!
Gura is offline Find More Posts by Gura
Old May 14, 2007, 05:55 PM
darkith is online now
Find More Posts by darkith
Canada, NB, Fredericton
Joined May 2002
DIY 900 mhz system:
http://darkith.dyndns.org/~darkith/html/diyuhf.shtml
Have a version 2 that is a bit improved, and with decent PCBs. Haven't posted it though, didn't seem like there was much interest.
D.
darkith is online now Find More Posts by darkith
Old May 14, 2007, 08:09 PM
Inciting Riots
Joined Dec 2006
Actually, there is a thread in the radios section that started on a DIY 2.4Ghz and 900Mhz system. If I knew how to program a PIC or AVR I'd probably have a prototype done now.
Old May 15, 2007, 08:44 PM
andrewm1973 is offline
Find More Posts by andrewm1973
Brisbane
Joined Aug 2006
Village Idiot,
Just jump straight in and start programming pics or AVRs (of course I recomend AVRs)
Its all pretty easy when you get into the swing of it.
andrewm1973 is offline Find More Posts by andrewm1973
Old Jun 07, 2007, 07:29 PM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Try Koichi Tanaka's PIC/AVR page. I have made tx's and rx's for both servos and actuators using his code.
Dave
david_dewit is offline Find More Posts by david_dewit
Old Jun 08, 2007, 09:03 AM
Gordito Volador is offline
Find More Posts by Gordito Volador
Flying Fatboy
Gordito Volador's Avatar
United States, FL, Sun City Center
Joined Apr 2003
Dave
Great stuff, it helps to be able to read Kanji though.
Gordito Volador is offline Find More Posts by Gordito Volador
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
Wanted Looking for a Plantraco receiver himeros Aircraft - General - Radio Equipment (FS/W) 1 Jul 04, 2005 05:27 PM
looking for DIY 12 volt power supply instructions super_nova DIY Electronics 4 May 09, 2005 11:06 AM
Looking for a good receiver jakeg1999 Micro Helis 5 Jan 02, 2005 03:30 PM
Looking for Micro Receiver on 75 Mhz Keennon Scratchbuilt Indoor and Micro Models 5 Apr 27, 2004 01:09 PM
