Old Oct 19, 2002, 12:28 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
30 Mins vs. 5 Mins epoxy
Apart from price and drying/curing time, what is the difference between 30 minutes and 5 minutes epoxy? Which one do I use when?
Up&Away is offline Find More Posts by Up&Away
Old Oct 19, 2002, 01:10 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
30 min soaks into the wood better. giving a stronger bond.....
gregg f is offline Find More Posts by gregg f
Old Oct 19, 2002, 02:37 PM
GForceStress is offline
Find More Posts by GForceStress
Oxymoron: Rap Music
GForceStress's Avatar
Upstate NY
Joined Sep 2002
the 5 min will set much quicker but the 30 min will be much stronger if u give it the extra time to harden.
GForce
GForceStress is offline Find More Posts by GForceStress
Old Oct 19, 2002, 03:01 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
GForce
If you give it extra time to harden? You have to let it harden longer due to the slower reaction time.
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Oct 19, 2002, 04:42 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Thanks guys!
But at what point do I say "for this I can use 5Mins, and for that I must use 30 Mins"?
RW
Old Oct 19, 2002, 05:11 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
joining wings, other high stress areas
Old Oct 19, 2002, 05:14 PM
Oxymoron: Rap Music
Upstate NY
Joined Sep 2002
Fuselages will go fine with 5 min but wings and high stress things might need 30 min.
GForce
Old Oct 19, 2002, 05:28 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Right
Got it
Old Oct 20, 2002, 04:01 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Use the 5min for small jobs, no more than thumbnail size batches and smaller.(control horns, servos mounts, etc.)
30min stuff for bigger jobs where your going to need the time to spread it out.(wing joints, wing spars, etc.)
William A is offline Find More Posts by William A
Old Oct 20, 2002, 06:35 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Up,
I've found that the strength is pretty irrelevant; all adhesives seem to be stronger than the materials that they're bonding.
It's the working time time that matters; no good using quick epoxy when you need several minutes to glass-skin a wing joint.
tim
tim hooper is offline Find More Posts by tim hooper
Discussion Esky Lama v3 Fries after 5 mins Mr Joshua Coaxial Helicopters 8 Sep 05, 2006 06:52 AM
830 mah 3s1p lipo barely hovers after 5 mins Ynksrock510 Batteries and Chargers 41 Dec 27, 2004 11:00 PM
What Can i use to thin 5 min epoxy? kushal_22 Electric Plane Talk 24 Mar 25, 2003 09:14 PM
HELP!! Need to ween myself from 5-minute epoxy!! mefly2 Electric Plane Talk 15 Jun 04, 2002 08:28 AM
5 minute epoxy? so many types... T-Bo Electric Plane Talk 12 May 08, 2002 09:26 AM
