Old Apr 17, 2007, 07:37 PM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Would NiMH be better if they had more voltage?
Do they have single cells that put out as much voltage as 1 lipo cell?
The thing i find good about lipos is since there are only 2 cells its easier to hook a few wires to them so that each cell can be charged independantly.
If a NiMH was in a single cell format and had the same voltage as 1 lipo cell would they be better? more durable? more stamina?
BowerR64 is offline Find More Posts by BowerR64
Old Apr 17, 2007, 08:08 PM
adamg is offline
Find More Posts by adamg
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
The 'problem' with NiMH cells, in motor vehicle use (especially airplanes and helicopters), is their gravimetric energy density. An airplane needs a certain amount of energy to fly for a decent amount of time. To get that energy with NiMH cells ends up adding a huge amount of weight to the vehicle. To overcome that weight you have to equip a larger motor, larger ESC, and more cells. The final result of this is poor aircraft performance relative to LiPo power.
adamg is offline Find More Posts by adamg
Old Apr 17, 2007, 08:16 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Voltage is determined by cell chemistry, so there is no way to get Lipo voltage from NiMh
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Apr 18, 2007, 02:36 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The perceived wisdom is that LiPo battery packs need to have their cells balanced to avoid overcharging one or other of the cells, which in turn will reduce the life of that cell or, at worst, cause it to vent and flame
Most other mainstream types of battery are more tolerant of over charging, and are less prone to vent-and-flame type failure. So generally speaking they don't need balancing leads Having said that, I've installed a balancing lead halfway through a couple of my 12-cell NiMh packs because I read somewhere that the risk of cell imbalance in an Nixx pack increases significantly once you get above a certain number of cells. So from time to time I can check the voltage of each 6-cell half, and cycle them as 6-cell packs if necessary. Can't say I've noticed any difference in performance or life though
As Pat MacKenzie has said, it's the cell chemistry that determines the voltage of each cell. If you make the cell larger, all that does is increase the capacity of the cell and, probably, the amount of amps that it can deliver.
abenn is offline Find More Posts by abenn
What would Walkera call this if they were to copy it? gordthebiker Micro Helis 7 Sep 25, 2005 05:46 PM
If you had a Mega 16/15/2 handy, what would you do with it? Hankstone Power Systems 6 Apr 10, 2003 10:34 AM
Which Would Be Better? CB435 Parkflyers 6 Nov 20, 2002 08:03 AM
It would be nice if ... MM Mounts & Zagi 500x Captain Carlton Foamies (Kits) 0 Jul 07, 2002 04:10 AM
Which would be better?!? cwlutterloh Sport Planes 2 Feb 20, 2002 01:03 PM
