Old Apr 17, 2001, 05:11 AM
huey is offline
Find More Posts by huey
Paris, France
Joined Mar 2001
Futaba FF7 & CCPM ?
Is the Futaba FF7 radio CCPM capable ?
I have noticed 2 different helicopter modes:
Heli1 and Heli2. What are they for (the manual only says that the Heli2 mode uses 2 servos)?
Thanks.
regards
huey
huey is offline Find More Posts by huey
Old Apr 19, 2001, 01:08 AM
RJ is offline
RJ
Find More Posts by RJ
RJ
RJ's Avatar
San Francisco Peninsula, CA
Joined Jan 2001
I contacted Futaba regarding my FP-T7UHF Super (which I believe is the same as the FF7) about the HELI1 and HELI2 modes as well. I did not get a clear answer about the difference between HELI1&2, but they did say that it is NOT CCPM capable. So I will also need to buy another transmitter.
Rick
RJ is offline Find More Posts by RJ
Old Apr 19, 2001, 01:39 AM
injunnut is offline
Find More Posts by injunnut
Cocoa, Florida
Joined Mar 2001
What does CCPM mean. I just bought a new Futaba Super 8 and did not read anythig about CCPM. Do I have it? Is it catching? Grin!
injunnut is offline Find More Posts by injunnut
Old Apr 19, 2001, 02:35 AM
huey is offline
Paris, France
Joined Mar 2001
Thanks for your comments guys. My transmitter is an FP-T7UPS. The only difference that I could notice in the manual between heli1 and heli2 is that heli2 is a "2 servo mode" while heli1 is "1 servo mode" (!). But 1 or 2 servos to do what ???
injunnut here is an explanation of CCPM and I think that the FF8 is CCPM capable.
CCPM : "Cyclic-Collective-Pitch-Mixing, CCPM mounts the servo's pushrods directly to the swash plate at 120 degree increments, like an equilateral triangle. With these three servo's the swash plate can be tilted in any direction, and when they all mo ve in the same direction the swash plate can be raised and lowered. All the mixing is done electronically by the transmitter, which means you MUST have a ccpm compatible transmitter " found on http://www.net-express.com/nexus/glossary.html
[This message has been edited by huey (edited 04-19-2001).]
Old Apr 19, 2001, 02:49 AM
injunnut is offline
Cocoa, Florida
Joined Mar 2001
Thanks Huey, I learned something today, I think?
[This message has been edited by injunnut (edited 04-19-2001).]
Old Apr 19, 2001, 02:51 AM
huey is offline
Paris, France
Joined Mar 2001
Sorry for the bad link. Remove the parenthesis in the address.
Old Apr 19, 2001, 02:58 AM
injunnut is offline
Cocoa, Florida
Joined Mar 2001
Huey, you can go back and edit your postings. Just put your cursor on the little gizmo at top of page that looks like a hand held water sprinkler (3rd gizmo over to the right) and click. This will bring up your post so you can change it any way you like or even delete it. I wish you would go back and correct the URL so when anyone clicks it, then it will work!
Old Apr 19, 2001, 03:20 AM
huey is offline
Paris, France
Joined Mar 2001
I learned something too! Thanks.
Old Apr 19, 2001, 10:58 PM
sbygren is offline
Find More Posts by sbygren
Colorado Springs, CO, USA
Joined Feb 2001
I used to fly a FF7 (Super 7 in the USA), and here is what I know...
1 servo mode is for use when a single servo is used to control collective, ala Raptor, Hawk, Ergo 60 Sport, etc.
2 servo mode is for use when two servos are used for collective/cyclic (and a third servo for the othre cyclic channel). This is sort of a pseudo-CCPM, but is NOT the 120 degree CCPM that is becoming popular in the USA.
If you want to user 120 degree CCPM, your options are to replace your radio, OR purchase a nifty little gadget from Quick UK that performs the electronic mixing to convert your radio's standard 3 servo (aileron/elevator/collective) output to 120 degree or 90 degree CCPM. Mine cost me somewhere around $65.
I hope this helps.
Steve Bygren
sbygren is offline Find More Posts by sbygren
Old Apr 20, 2001, 12:58 AM
wiley is offline
Find More Posts by wiley
wiley's Avatar
owosso, mich
Joined Mar 1999
greetings, i had an eco and a futaba 7 heli super radio years ago. the radio will mix channel 2 and 6 so it will work at a hover. as soon as you start adding collective you will run out of pitch/roll. so it will do it, but not right. the heli 1 and 2 servos are for say an x cell, use one servo if you have a sliding servo for collective, and use 2 servos for roll and collective together.
wiley is offline Find More Posts by wiley
Old Apr 20, 2001, 03:09 AM
huey is offline
Paris, France
Joined Mar 2001
Thanks a lot guys. It's becoming clearer now.
regards
huey
Old May 30, 2004, 11:28 AM
johnuk88888 is offline
Find More Posts by johnuk88888
Joined May 2004
ff7
heli1 and heli 2 one is 90 degrees the other is 120 degrees
if your swash plate is flat you have the correct mode if it is tillted change the mode so becomes flat
johnuk88888 is offline Find More Posts by johnuk88888
Futaba T6XAS ccpm?? Sammy B Radios 0 Aug 26, 2004 08:51 PM
Question Futaba Ff7 pino360 Radios 6 Jun 26, 2004 07:04 PM
Futaba FF7 failsafe funfly3 Radios 11 Feb 01, 2004 02:49 PM
