Old Apr 16, 2007, 08:40 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
APC prop w/ high power motor and 3mm prop saver?
3 mm shaft and a prop saver with a fairly beefy motor I got. I have an APC prop but the prop extends almost as far as the fairly short screws and there isn't enough "substance" in the screw ends or length in them to prevent the o-ring from flying off when under full throttle. Due to something I did with the motor, I have to mount these props on the smooth 3mm shaft and can't find a way yet to do it. GWS props fit because they have a much smaller focal point, but then they're also not as well suited to my motor as an APC.
Thanks!
JWilliams2 is offline Find More Posts by JWilliams2
Old Apr 17, 2007, 07:46 AM
JWilliams2's Avatar
NY State
Joined Jan 2007
Good morning
Old Apr 17, 2007, 08:04 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You could use longer screws, though balancing will be critical - but I'd be concerned about this "high power" motor and a propsaver anyway - I don't like prop savers at >100W.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 17, 2007, 10:33 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Can you just add a 3mm prop adaptor? I agree with Dr Kiwi on the prop saver limitations, I don't feel comfortable with an "O" ring or rubber band holding on a prop at over 100W.
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Apr 17, 2007, 10:56 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
By the time you've put three O-rings on to hold the prop safely, it will no longer function as a prop saver anyway.
Old Apr 17, 2007, 11:02 AM
JWilliams2's Avatar
NY State
Joined Jan 2007
I don't think it offers any benefit, either, since the grip required to keep the prop in place would offer no give on impact, but since I carelessly stripped the threads on the end of the bell (is that the spider-plate?), the included prop adapter absolutely will not stay on the motor, so I'm forced to go with the shaft
Old Apr 17, 2007, 11:39 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
get a 3mm adapter and have done with it.
Plenty to be had. I like MPjet ones, but YMMV.
Old Apr 17, 2007, 12:23 PM
JWilliams2's Avatar
NY State
Joined Jan 2007
Will this fit over a 3mm shaft? Remember, I have no way to connect anything to the motor except a smooth 3mm shaft.
Old Apr 17, 2007, 12:55 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Of course. MPJet, being European, make 3mm collet adapters, not 3.2mm (1/8")
(I think they do 3.2mm as well).
You just Dremel off the shaft to about 12mm and slip the collet adaptor over it.
M5 shaft to the prop. Normally means you have to ream the APC ring a little.
Question LSPJ w/prop saver?? APC Props?? spadbat Power Systems 1 Jul 27, 2007 12:48 PM
Question High power motor 16 HP + EnVeeTee Power Systems 10 Feb 08, 2006 01:13 PM
EDF - High power motor/combination. m10langman Electric Ducted Fan Jet Talk 10 Feb 24, 2005 12:23 AM
Quick DIY prop saver on CD-rom motor frankyfly Power Systems 1 Nov 06, 2004 03:56 PM
broke prop,saver and shaft on SS/motor options? richphoto Parkflyers 9 May 10, 2003 03:49 PM
