Old Apr 16, 2007, 06:34 PM
mcharles13 is offline
Find More Posts by mcharles13
Jaded Flyer
mcharles13's Avatar
United States, FL, Clearwater
Joined Aug 2004
Question
CG Balancer for big planes??
Where do i get a balancer for big planes that won't damage the wings?
I saw a guy with a nice wooden one once at the field but i dont know what kind it was or where to get it. It had nice long arms with the center pivot where you place the cg mark. And those bubble liquid tube thingies that you see on a level.
I'd love to know where to buy that. Any help would be much appreciated.
,mike
mcharles13 is offline Find More Posts by mcharles13
Old Apr 16, 2007, 06:40 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
broomsticks, 2X4's and make padded wing cradles for the broomstick's rounded ends.
Or, you can put each wheel on a scale, and using a bit of HS geometry, you can find the CG (and even how much weight is needed in which wingtip to correct lateral ballance)
Or.. you can hang the plane using cord tied to the prop and the tail of the plane. Tie those 2 lines together and hang from a single line to a hook. Hang a plumb bob from the same hook. The plumb bob will point at the CG.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Apr 16, 2007, 07:05 PM
RyanPSU21 is offline
Find More Posts by RyanPSU21
RyanPSU21's Avatar
USA, MI, Harrison Township
Joined Sep 2000
I've always been a fan of 2 index fingers where the CG should be, usually 90% of the time on the wingspar. If the plane is low wing you do it holding the plane upside down.
RyanPSU21 is offline Find More Posts by RyanPSU21
Old Apr 17, 2007, 02:13 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Use the Great Planes cg machine. It costs $23 and can handle planes up to 40 pounds. It is immensely more accurate then the two finger method, although that does work for some people to get a general check of CG. broom stick are fine, but not very precise without adding some ruler type devices to the setup.
The Great Planes CG machine has foam pads that the wings rest on over the pivot points of the machine.
http://www2.towerhobbies.com/cgi-bin...&I=LXK259&P=ML
kahloq is offline Find More Posts by kahloq
Old Apr 17, 2007, 07:49 AM
Rob Schaffer is offline
Find More Posts by Rob Schaffer
Scale Builder, RCAPA #29
Rob Schaffer's Avatar
Lansdale, PA
Joined Jan 2002
Easy solution, safe one too....
I used a CG Sling, made of some nylon rope, a plumb bob, and some spare wood. This allows me to hang the plane from the ceiling, move things as necessary, and see the CG accurately. Nice part, it's always supported by the rope so I don't have to worry about it slipping off the stand.
Here's a link to how to build and use one. I used Figure 'F' for balancing my Corsair.
CG Sling for Model Planes
Rob
Rob Schaffer is offline Find More Posts by Rob Schaffer
Old Apr 17, 2007, 08:05 AM
Jaded Flyer
mcharles13's Avatar
Joined Aug 2004
Thanks. I'll probably go with the great planes balancer.
The plumb bob method is a wee bit too long for ADD, that and I don't know what plumb bob is. Or it could be the fact that i'm incredibly sleepy.
I'm hoping to win a Tower Hobbies $20 gift certificate from another site so i'll use it for that. (my odds of winning are very high i think)
,mike
Old Apr 17, 2007, 09:41 AM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
The great planes balancer is not good for large planes, the plastic rulers break, and if the plane if off balance it will topple over the balancer.
Build these and you will be fine. This is what I use.
3/4 inch bases
1 inch sprinkler pipe.
3/4 inch dowel.
Drill out the hole in the base for the sprinkler pipe.
Glue with Gorilla Glue
Drill out one end of the dowel, insert a large furnature roller.
Slip the dowel into the sprinkler pipe.
Drill holes in each dowel equally and adjust height by slipping a large nail or screwdriver through the hole.
Make another device to hole the plane stable just in case it is really nose or tail heavy. Adjust weights using masking tape on top of the plane until you get it balanced.
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old Apr 17, 2007, 10:28 AM
Jaded Flyer
mcharles13's Avatar
Joined Aug 2004
now were talking.
i can build that.
Thanks Al
Old Apr 17, 2007, 02:09 PM
Joined Mar 2005
essentially the broom stick and 2X4 stand...
don't fprget to use a "protector" of some sort for each wing panel. If the end of the broomstick (or the above furniture roller) gets on unsupported covering with a larger model, its going to put a hole in the wing. The protector can be as simple as a 4 inch square of coroplast. (for up to 10 lbs... insert bamboo in a larger coroplast piece and you can support more weight. the idea is to spread the load and not ding the wing.)
CG has a recommended range because differnt taste in aircraft responsiveness will need different CG. The recommended range is typically a bit nose-heavy I usually end up 5% MAC behind the recommended range by the time I am happy with the way a plane flys.
Old Apr 18, 2007, 11:33 AM
bigbobed is offline
Find More Posts by bigbobed
Awsome 2.5D Pilot.
bigbobed's Avatar
United States, NC, Jackson Springs
Joined Nov 2003
Rob
Here's a link to another build instructions for the sling. They are a little clearer than the link you posted.
http://iflyrc.hypermart.net/CG%20Machine.htm
I have found that the dowell that the sling strings go around must be exactly parallel to the wing center line or errors will creep in. I use two plumb bobs, one on each side of the fuse to make sure it's correct. My main like of this sling is that you don't have to worry about the plane falling no matter how far off you are to start. Keeps both hands free to move things around.
bigbobed is offline Find More Posts by bigbobed
Old Apr 18, 2007, 01:21 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
Mike,
If you take a look at my stand, you will see the original bottoms. I was afraid that it might topple over so I screwed and glued the original bottom to a larger piece. Since then, I had to cut down one side of the larger bottom so that the stands could be pushed closer to the fuse.
Also, be sure you make some kind of tail or nose stand to support the bird until you get it balanced. It's hard to hold a big plane once you have it on the balancing stand, and move weights at the same time.
I forgot one other step to finishing the stands, I ground down flat spots on each furnature roller and glued on some packing foam to make the side softer where it supports the wing. No balsa breaks or cracks with these stands.
Al
Old Apr 18, 2007, 02:45 PM
Jaded Flyer
mcharles13's Avatar
Joined Aug 2004
yeah i noticed that. and i can always lengthen the surface the plane is gonna lay on if i need to as well. For now i'll just file it down and foam it.
,mike
Old Apr 18, 2007, 03:18 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Great info guys!
Here’s another hint:
After you have the plane balanced; remove its wing and see where the fuselage alone balances!
Mark this spot, so next time you don’t need to put the wing on to check the balance! Note: its not likely to be at the CG.
This is particularly useful when trying to nail down the final position of the battery pack.
Its also useful when you 1st planning out your equipment positioning.
For example I assemble the plane and wing w/o any equipment installed; and then hang a weight up front to get it balanced.
Mark the fuselage and check it as you add things; might need to move the servos aft to get the pack to be centered very near the CG – this help when you change pack type, sizes etc.!
For my Cub I use a dowel rod in the window frames, and a line level on the wing saddle.
My Mustang works with a wire spanning the fuselage at the wing saddle doubler.
BOL
Jim
jrb is offline Find More Posts by jrb
Old Apr 18, 2007, 03:20 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
But this works too!
Old May 21, 2007, 11:33 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I saw a CG sling long ago that was made primarily of dowel rods and lines; gave it a try but wound up hanging it in the corner of the basement.
The sling ideas posted above got me to thinking about giving it another try.
I like the wooden post with the dowel rod shown; so I did a bit differently with a piece of PVC I had laying around.
Only needed to drill a few holes; even made the “line locks” as part of the pipe.
Alert 20% Off and Free Shipping on Big Packs for Big Planes mikekomm Glow to Electric Conversions 3 Apr 09, 2006 10:07 PM
F/s Big Servos For Big Planes RGHCOWNER Aircraft - Fuel - Airplanes (FS/W) 0 Mar 16, 2005 08:15 AM
Who makes power systems for big planes? Cheetah R/C Power Systems 24 Feb 23, 2005 03:47 PM
Question Big motors for big planes Walt Thyng Power Systems 6 Sep 22, 2004 12:17 PM
Li-Polys for big planes? ED209 Batteries and Chargers 21 Feb 02, 2003 12:23 PM
