Old Apr 16, 2007, 03:42 PM
Jkirch86 is offline
Find More Posts by Jkirch86
Joined Jan 2006
Question
Any advice on an ESC?
I just ordered an E-Flite Hacker E-series 3700kv brushless motor for my blade cp, I was wondering if anyone would recommend an ESC to use with it.
The specs say to use at least a 12a, and I want to go as light as possible.
Everything will be stock but the motor and esc.
Also, I am guessing that an 8T pinion will work best, will any pinion work for the blade cp gears?
Jkirch86 is offline Find More Posts by Jkirch86
Old Apr 16, 2007, 09:20 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I am very happy with the Phoenix series. I use a Phoenix 10 on my 4200kv CP2 with 3S lipos.
Gino CP is offline Find More Posts by Gino CP
Old Apr 16, 2007, 09:29 PM
Xptical is offline
Find More Posts by Xptical
Your user title is suggestive,
Xptical's Avatar
Warner Robins, GA
Joined Apr 2006
Phoenix is good. I have a Thunderbird 25A and I don't think I'll get another. You need an external programming box and the end points are kind of a pain to set.
Xptical is offline Find More Posts by Xptical
Old Apr 16, 2007, 09:57 PM
Jkirch86 is offline
Joined Jan 2006
Yea, I've been looking at Phoenix, seems like everyone likes them.
I just got my new 4 in 1 in and I want to go ahead and upgrade to brushless so it doesn't burn up like the last two. I really don't want to have to buy a programing box along with the esc I chose.
Gino, do you think that the Phoenix 10 would be enough for this motor.
if not does phoenix make a 12a esc?
http://www.spektrumrc.com/ProdInfo/F...structions.pdf
Old Apr 16, 2007, 10:33 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
The Phoenix 10 should work well. It is also quite easy to program with just a transmitter. 8T is a very efficient setup. Using light lipos also go a long way in reducing amps.
any advice on how to keep your esc reiceiver plug soldered up good to the p.c. board? airborn express Power Systems 5 Oct 08, 2003 04:59 PM
before i fly, any advice on the K&A mig15 ? terje s Electric Ducted Fan Jet Talk 4 Mar 22, 2002 11:23 AM
Any advice on desiging a slow fly wing? slowflyer Foamies (Kits) 7 Mar 08, 2002 04:46 PM
How good is governer mode on an ESC? HankF Electric Heli Talk 12 Jan 24, 2002 06:49 PM
First aileron plane, any advice on setup? slowflyer Beginner Training Area (Aircraft-Electric) 4 Apr 30, 2001 10:37 PM
