Old Apr 13, 2007, 03:03 PM
Bundy_90 is offline
Find More Posts by Bundy_90
Newbie
Norway, Oslo..
Joined Mar 2007
Build in lipo alarm on honey bee cp2?
Is there some sort of warning when the lipo is getting empty on honey bee cp2?
Bundy_90 is offline Find More Posts by Bundy_90
Old Apr 13, 2007, 04:11 PM
sdmaker is offline
Find More Posts by sdmaker
Joined Feb 2007
No there isn't
sdmaker is offline Find More Posts by sdmaker
Old Apr 13, 2007, 07:53 PM
dingosrun is offline
Find More Posts by dingosrun
learning nose in hover
dingosrun's Avatar
perth western australia
Joined Sep 2006
is there a way of making one
dingosrun is offline Find More Posts by dingosrun
Old Apr 13, 2007, 08:17 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
On a new 11.1v 1000mah 10C pack, you can safely fly 15 min. When the pack is old, reduce your flight times. Well, it is old and worn so who cares hehe.
To check flightime, fly until heli can't punch hard anymore. Then note time. Knockoff 1-2 min from that. That will be your safe flying time. Ideally you should just use 80% of capacity.
Even with the best of care, they only last 80-100 flights before runtime is reduced considerably. But the pack is still usable.
Do a Search on lipo alarms. There are designs and ready made units out there.
Gino CP is offline Find More Posts by Gino CP
Old Apr 14, 2007, 12:28 AM
Linker33 is offline
Find More Posts by Linker33
Linker33's Avatar
Boise, ID
Joined Mar 2007
If I run the lipo low enough, the red light on the 4in1 starts flashing. There is then about a minute of hovering left at that point. I measured the voltage at that point, and it's around 10.5, which I think is still safe (please correct me, if I'm wrong).
However, I can tell right when cyclic control begins to diminish, and when I punch the throttle, the climb rate is definatly less than it should be. I quit flying as soon as I notice this change, and the voltage when measured is 11.25V. From what I've been reading this is ok, but please, someone let me know if this is not right.
Linker33 is offline Find More Posts by Linker33
Old Apr 14, 2007, 01:49 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
The red led is not warning indicator. It means you are on full throttle. Use lipo alarm or time your flights. If you fly until you feel anything, it is too late. So time you flight until you feel anything. Then knock off a few minutes from that. That is your safe flying time.
Measuring voltage from a static pack is not a good indicator of pack in-use voltage. A pack without load has higher voltage.
Old Apr 14, 2007, 06:46 AM
Bundy_90 is offline
Newbie
Norway, Oslo..
Joined Mar 2007
Thanks for the help guys
Discussion HS-55 Servos with Stock Radio on a Honey Bee CP2 jgb2000 Micro Helis 15 Feb 24, 2007 07:00 PM
Question Will Blade CP symmetrical blades work on a Honey Bee CP2 ? Al P Micro Helis 2 Jun 30, 2006 01:18 PM
For Sale Best price on Esky lama and honey bee cp2 parts - all in stock jamesdu Aircraft - Electric - Helis (FS/W) 3 Jun 03, 2006 03:24 AM
Discussion Honey Bee King motor on Honey Bee cp2??? DanT Micro Helis 4 Feb 28, 2006 10:36 PM
Going seperates on a Honey Bee CP2. edessa Micro Helis 0 Sep 13, 2005 08:41 PM
