Old Apr 13, 2007, 12:19 AM
sfsjkid is offline
Find More Posts by sfsjkid
Japan, Mie Prefecture, Ise
Joined Aug 2004
Top Flite Spitfire Mods for better cockpit details(???)
I realized that the world needs another one <NOT>. But I did want to document some of the modifications that I'm planning to incorporate. Mainly, I want to open up the cockpit area for more scale-like features. This will be the first time for me, not sure if my expectations will workout with reality, but hopefully you guys will keep me motivated and have some pointers.
First some background. For whatever reason British WWII fighters are my favorites, specifically the Spitfire, Hurricane and Mosquito. Once this Spit is done I have plans for a 70" Hurricane and plan to do the Brian Taylor 81" Mossie. Lately I've seen a flurry of Spit's at our field, starting out with New2rc's electric one, a WM one, and a GP. Still haven't seen a H9, though like most ARF's versions does not look quite right. New2rc's is probably the best one I've seen personally by a fellow club member http://www.rcgroups.com/forums/showp...&postcount=581 He put in a lot of work into getting scale retracts working and in the right position! Tower offering the Spit on the Easy Pay plan tipped the scales, and had to have one!
Before I get on with the build thread, here are a bunch from the net, for those thinking about starting one.
http://www.rcscalebuilder.com/forum/...s.asp?TID=5270
http://www.rcscalebuilder.com/forum/...s.asp?TID=8732
http://www.rcscalebuilder.com/forum/...s.asp?TID=6183
http://www.rcscalebuilder.com/forum/...s.asp?TID=6692
http://www.rcscalebuilder.com/forum/...ts.asp?TID=583
http://www.rcscalebuilder.com/forum/...s.asp?TID=4192
You'll have to log on to see the above.
http://www.rcuniverse.com/forum/m_39...tm.htm#3910045
http://www.rcuniverse.com/forum/m_18...tm.htm#1801931
http://www.rcuniverse.com/forum/m_14...tm.htm#1403165
As for motivation part, see my RCG blog for links to other stuff I'm into. I'm fickle, work from project to project and eventually something gets done!
sfsjkid is offline Find More Posts by sfsjkid
Old Apr 13, 2007, 01:02 AM
sfsjkid is offline
Joined Aug 2004
Ok, on to the work. I think it was Dave Platt who said the cockit area was no man's land for r/c stuff. I was some what disappointed to see that TF did not take this into account, but purchased the thing anyways realizing that the overall the kit would be an easy build. Started with the intent of hiding all of control horns as some have done in the above threads, but as I got into things figured it would take me forever and limited myself to the cockpit and exterior panels (I hope!)
I've built the rudder and elevator according to the instructions, and though the wing is the next step, skipped to the fuselage. First change was with the cockpit "floor". I chopped off the rear, since it not present in the real Spit. I used the remaining piece to help position the formers between the shelf behind the pilot's head and the instrument panel.
Old Apr 13, 2007, 03:08 PM
new2rc is offline
Find More Posts by new2rc
Warbird crazy!
new2rc's Avatar
United States, CA, San Mateo
Joined Sep 2004
Hi Frank
So cool, you doing a build thread on your Spitfire!
I will be following every step .
John and Christo
new2rc is offline Find More Posts by new2rc
Old Apr 13, 2007, 03:33 PM
sfsjkid is offline
Joined Aug 2004
Hey John, well don't expect much and I should learn to proof read my stuff hey? Hopefully you'll all help me keep on track and maybe this will be finished this year????
I've attached a 3-view pdf with full size dimensions I'm finding usefull.
Old Apr 14, 2007, 02:28 AM
sfsjkid is offline
Joined Aug 2004
Stock, the kit only has a 12oz. tank. Since I'm planning to put in a .91 four-stroke, felt this was not enough. My .91 Saito has a 16 ounce tank good for about 8~10 minutes at full throttle. I decided to extend the fuel tank area about an inch. The kit's pieces for this area are on the sides of the fuse, the ones I remade are already installed. If you look real carefully and use a bit of imagination, you'll see that TF supplies one very long motor mount. Have to make a new top cover for this area.
Servo tray should have been glued in at this point but only present currently to space everything out correctly.
Old Apr 18, 2007, 12:33 PM
TheSaint is offline
Find More Posts by TheSaint
Deported Village Idiot
TheSaint's Avatar
A roamin' in the gloamin again
Joined Jun 2006
Let's swap notes.
I'm about to restart on mine at the weekend. I'll have some tips on wing building to share....
TheSaint is offline Find More Posts by TheSaint
Old Apr 18, 2007, 03:45 PM
sfsjkid is offline
Joined Aug 2004
Sounds good Saint.
Remember though, as mentioned earlier, IMHO felt the TF Spitfire has almost been done to death on-line, so I'm only planning to post areas were I've modified the bird to make it more scale looking, at least in my eyes. I've already done the fins, came across problems others have experienced, but haven't mentioned them just because it was old news, for example. So what I'm trying to say is this thread probably won't be the best place to look for problem areas with the kit. Feel free to ask any questions though.
About the only modification I'm planning to do with the wing was done by one of the guys over at RC Scalebuilder. He put the air tank for the retracts in the center of the wing. Hope he doesn't mind, but I've blatantly borrowed one his shots for post here.
Sorry I haven't posted anything additional. Just other stuff getting in the way. I have sheeted the fuse, but thought that some of the lines were wrong and thinking about ways to get around that. I do have a couple of more pictures, I'll get them up soon.
So, how much more do you have to go Saint?
Old Apr 18, 2007, 04:11 PM
TheSaint is offline
TheSaint's Avatar
Joined Jun 2006
Lots to do.
Basically all i got done before being distracted by life the universe and everything was to get the fin stab and elevators made.
Old Apr 18, 2007, 11:21 PM
sfsjkid is offline
Joined Aug 2004
IC, but that is still 3 steps closer in from the edge of the universe and the project is in motion
Old Apr 18, 2007, 11:29 PM
sfsjkid is offline
Joined Aug 2004
For those not familiar with the model, the fuse has 2, c-channel stringers which are pinned to the building board first, to which the formers are glued. A smaller stringer is glued into the channel to form a shelf for the sheeting. If you look at the manual in the background you'll be able to see the setup further, along with the pictures uploaded previously.
Unfortunately, this c-channel is much too thick and prominent for a scale cockpit. Decided to omit this, and replaced the smaller balsa stringer with a spruce one. I needed to build up some courage since it would weaken the fuse and would have to build it back later.
Old Apr 19, 2007, 12:21 AM
new2rc is offline
Warbird crazy!
new2rc's Avatar
Joined Sep 2004
Frank, looking good!
You are doing the full scale retract treatment .
That will be so awesome. Looks like you will have a nice forward rake on the gear which should mitigate the wonderful nose over fun.
John and Christo
Old Apr 19, 2007, 12:24 AM
sfsjkid is offline
Joined Aug 2004
First pic shows the plywood piece I cut out of the fuse on top. This would have made a nice arm rest for the pilot so it had to go. This shot also shows a reinforcement piece that needs to be cut off at the bottom. This is to help compensate for the plywood, but also act as a stiffner for the top and bottom formers. Other shots for illustration, pushrods and antenna tube are installed and will be hidden by sheeting.
Old Apr 19, 2007, 10:48 AM
sfsjkid is offline
Joined Aug 2004
John and Christo
Yup, as you probably remember, not having retracts in the "scale" position are detracts for me, enough so for me to build one. TF cheats a little by having them a forward and out from scale but I'm sure you'll agree that this is much better from an r/c standpoint
See ya!
Old Apr 23, 2007, 12:40 AM
sfsjkid is offline
Joined Aug 2004
Disaster strikes. Well, sort of. Using the info in the previous pdf, and a couple of Mk1 models I have as a guide, I tried re-shaping the area behind the cockpit to a more realistic profile. Unfortunately this resulted in going through the sheeting. Since this part of the fuse bothered me a lot, well, I decided to go further and thin this portion down. I realize this is a sport scale model, but this portion bugged me a lot. Left side is stock and the right side the modified shape. Last picture shows rework start on left side and the new stringers for the right side. Basically sanded down to shape past the stock stringers then added new stringers to the re-shaped formers then sheeting added.
Old Apr 23, 2007, 02:43 PM
sfsjkid is offline
Joined Aug 2004
The guy in the following link is making a full size Spitfire cockpit for a flight simulator, it includes a lot of nice details shots, so I've added it here.
http://www.simhardware.org/index.html
Discussion Top Flite Spitfire rupert the bear Electric Warbirds 2 Jul 05, 2007 07:46 PM
Question Top Flite Spitfire - weight issue Michael in Toronto Scale Fuel Planes 2 Sep 20, 2006 02:56 PM
Question Question - Top Flite Spitfire - weight issue Michael in Toronto Scale Kit/Scratch Built 4 Sep 05, 2006 08:04 PM
Top flite Spitfire IC conversion AndersO Scale Kit/Scratch Built 1 Apr 23, 2005 04:11 PM
Top Flite Phasoar electric sailplane kit for sale smsgill Aircraft - Electric - Airplanes (FS/W) 2 May 01, 2002 10:57 AM
