Old Apr 28, 2007, 05:26 PM
rhondaward is offline
Find More Posts by rhondaward
Im stupider than you!
Pekin Illinois
Joined Aug 2006
My bug would be done,if I could figure out the tx programming JR XF421EX,Has Delta tail,V-tail mixing,which one do I use? Anyone familiar with this radio?
rhondaward is offline Find More Posts by rhondaward
Old Apr 28, 2007, 05:47 PM
1987tc is offline
Find More Posts by 1987tc
Come fly with us in Henryetta
United States, OK, Weleetka
Joined Dec 2000
I have a Dx6 and I used the Delta mix. Works for me!
1987tc is offline Find More Posts by 1987tc
Old Apr 28, 2007, 11:41 PM
Pekin Illinois
Joined Aug 2006
Well,Im missing something,I can get mix to work,I dont know how to adjust the mix,been trying travel adjust which has some effect,HELP!!!!!!!!!
Old Apr 29, 2007, 02:09 AM
wrugen is offline
Find More Posts by wrugen
Joined Feb 2006
Originally Posted by IFO FLYER
Wrugen
Where did you get the 9mm epp foam ? I have a bug and just ordered a second one. I would like to make a 1.5 x bug but I do not know where I can get the foam.
thanks
ifoflyer
Epp can be purchased at www.slofly.com
wrugen is offline Find More Posts by wrugen
Old Apr 29, 2007, 05:55 AM
Scott_S. is offline
Find More Posts by Scott_S.
Joined Feb 2007
rhonda, with the DX6 you just turn "on" the Delta mix. V-tail is turned "off".
I would ask this down in the "radio" forum too. Or start doing some web searches on your model number and the words delta mix, you might get lucky.
Scott_S. is offline Find More Posts by Scott_S.
Old Apr 29, 2007, 05:57 AM
Scott_S. is offline
Joined Feb 2007
To make it easy, set travel at 100%, then work on expo.
Old Apr 30, 2007, 11:02 AM
CitaFly is offline
Find More Posts by CitaFly
Joined Feb 2007
Here's a video I shot this AM:
Bug Video
This was with LOW rates - I still have to graduate to high rates!
CitaFly is offline Find More Posts by CitaFly
Old Apr 30, 2007, 10:58 PM
Pekin Illinois
Joined Aug 2006
I figured out how to turn on delta,but how do I adjust the mix? Is it all or nothing? Also cant figure out how to adjust travel on the mixed channels.I found the owners manual on the web,but it just shows how to activate delta,no info on adjustment.Man I hope Im not going to have to buy a fancier tx yet too.This one dosent have expo. either,I was hopeing to "wing it" by limiting travels.I fly helis without expo.????????
Old Apr 30, 2007, 11:13 PM
1987tc is offline
Joined Dec 2000
I have a dx6 not a Jr. But If I am n ot mistaken a lot of the Dx6 is jr.
So anyway on my radio I can still adjust the elevator and aileron functions just as before.
I have my ailerons function at 125% on high rates. But will LOTS of expo!
Wes
Old Apr 30, 2007, 11:22 PM
Pekin Illinois
Joined Aug 2006
Can you just tell me what channels on the Corona rx,go to which servos? I have 2 switched wrong,Right stick left and right makes the elevators work and up and down makes the aielerons work I have tried every combination and cant get it right ch1 is throttle,ch2 goes to the right hand elevon servo,ch3 other elevon servo,ch4 rudder.Whats wrong with this picture? Sorry,this is my first elevon plane and first time useing this tx.
Old May 01, 2007, 12:24 AM
Pekin Illinois
Joined Aug 2006
I got it!,,Maiden tomorrow
Old May 01, 2007, 12:40 AM
OnTheMoment is offline
Find More Posts by OnTheMoment
Joined Dec 2006
hey Ronda, I got the same Rx but didn't even ask for a crystal. What crystal are you using? will a berg work? has anybody else tried?
OnTheMoment is offline Find More Posts by OnTheMoment
Old May 01, 2007, 01:48 AM
Pekin Illinois
Joined Aug 2006
Same here,I got a GWS,Yes I think the berg micro crystal will work,shift dosent matter.I believe its called a UM3 size.
Old May 01, 2007, 01:55 AM
Pekin Illinois
Joined Aug 2006
Mine is ready I guess. I have the rates cranked way down,Im useing a 3s 340mah,Man oh Man Im kinda sckeered of it! Other than helis and 1/4 scale high and mid wings Im a total noob Never flown anything like this before.Any and all advice welcome.Should I hand launch over tall grass,or attempt rog,over pavement? Ill probably cartwheel it within 3 feet! It seems a little tricky to keep straight taxiing,but seems like it will take off in about 2 feet! Not shure what Ive gotten myself into here. EDIT I almost forgot,I do have another concern,I got one servo that dosent center and is slow,Tried it on different channels and its defenitly the servo,they seem to be $10 servos LOL,I was expecting QUALITY D** IT!
Old May 01, 2007, 08:36 AM
CitaFly is offline
Joined Feb 2007
First, make sure that when the system is powered that all the control surfaces are absolutely flat, especially the ailerons. Do whatever you have to as this is critical.
I always hand launch - I would not maiden over pavement, grass is much more forgiving. Don't spin it up to full throttle - hold it and advance the throttle until you feel a good tug on the Bug, then a nice level toss should do it. I normally launch at about 60% throtttle.
Do not over-control! Small movements on the stick. Get the Bug up to about 50 feet, then throttle back a bit to keep it level and trim as needed - a few clicks should do it.
For your first flight, just practice keeping it level and go back and forth in wide elliptical orbits.
Landing is a snap, throttle back and let it float down slowly - when about a foot off the ground, cut the throttle and pull up - it should plop down to land.
Sold Lightflite BUG ready to fly. Back up for sale. 1987tc Aircraft - Electric - Airplanes (FS/W) 14 Jun 30, 2007 10:34 PM
Sold Lightflite Bug ready to fly! $135.00 Shipped with 2 lipos. 1987tc Aircraft - Electric - Airplanes (FS/W) 12 May 04, 2007 02:54 PM
Discussion Lightflite Bug "heavy duty" landing gear. Scott_S. Foamies (Kits) 11 Apr 18, 2007 01:09 PM
Discussion Plane Review: The Lightflite Bug CitaFly Electric Plane Talk 1 Apr 11, 2007 09:25 AM
