Old Apr 17, 2007, 05:46 PM
Dave Smith is offline
Find More Posts by Dave Smith
Severna Park, MD
Joined Jan 2006
Originally Posted by CitaFly
Curious about ... the rudder - can you elaborate?
My bug turns much tighter turns with the rudder than with elevons-only. AND it's easy to taxi on the ground with rudder control - tough without a rudder. With the rudder I can make a nice soft landing, taxi around and take off easily in the cul-de-sac without having to approach the plane.
Dave Smith is offline Find More Posts by Dave Smith
Old Apr 17, 2007, 06:49 PM
CitaFly is offline
Find More Posts by CitaFly
Joined Feb 2007
I always hand launch so not an issue for me - turning with the rudder should almost get you to turn the Bug on its axis!
CitaFly is offline Find More Posts by CitaFly
Old Apr 18, 2007, 05:56 AM
lammy1000 is offline
Find More Posts by lammy1000
Joined Jan 2005
Rudder adds another dimension to control. Do not think you can get the most from your plane or become a good pilot without it.
lammy1000 is offline Find More Posts by lammy1000
Old Apr 18, 2007, 06:51 AM
Scott_S. is offline
Find More Posts by Scott_S.
Joined Feb 2007
Curious about your comments on the rudder - can you elaborate?
I really should learn to fly before I open my mouth. I made the "no rudder" comment because the planes I like are planes like the Modelaero Aerosport, HL Firebird, Aerocat, Stryker, etc......these planes have no rudder.
I just had a thought on the no rudder as being a good "elevon" trainer.
I have used the rudder on take off, I just wish my flights were longer than
3 seconds
I have my Bug ready to go now, just waiting for the wind to die down and
be off work.
Scott_S. is offline Find More Posts by Scott_S.
Old Apr 18, 2007, 08:36 AM
CitaFly is offline
Joined Feb 2007
I would agree with that - I do flat spins with left rudder and right ailerons. I'm just scratching the surface on what's possible.
Old Apr 19, 2007, 10:08 PM
rhondaward is offline
Find More Posts by rhondaward
Im stupider than you!
Pekin Illinois
Joined Aug 2006
Hopeing mine gets delievered tomorrow.
rhondaward is offline Find More Posts by rhondaward
Old Apr 20, 2007, 01:10 AM
Scott_S. is offline
Joined Feb 2007
Have fun!
Old Apr 20, 2007, 10:59 PM
Pekin Illinois
Joined Aug 2006
Mine arrived today.Ron is quite helpfull.Mine arrived with a wing malformation.But hes gonna have a replacement out tommorrow! Nice to be able to contact a distributor/maker directly!! My only "small" gripe is,,I understood I was ordering the newest version of the kit,with had prebeveled surfaces,Mine dosent.No biggie though,Its just that this EPP is a pita to cut.
Old Apr 21, 2007, 07:56 AM
IFO FLYER is offline
Find More Posts by IFO FLYER
IFO FLYER's Avatar
Joined Mar 2004
I flew my bug for the first time this morning. I flew for a few minutes and landed it softly on the ground infield of a ball diamond. I could not believe it. The landing gear rod broke where it is tied to the front crossrod. It was a very soft landing. It seems to fly easier than the IFO'S I fly ( I have 8 flying ). Left and right circles are smooth and level. I did not try much since the rod broke. I will replace the rod and try again. So far I like the bug and will probably get a second one. It might be a good plane to teach my grandson to fly.
IFO FLYER is offline Find More Posts by IFO FLYER
Old Apr 21, 2007, 09:06 AM
CitaFly is offline
Joined Feb 2007
It's just that this EPP is a pita to cut.
A hint: I used two metal rulers above and below where you want to bevel - use a new razor blade and cut with a sawing motion - quick and a nice cut.
Old Apr 21, 2007, 09:12 AM
CitaFly is offline
Joined Feb 2007
I finally broke my landing gear - I was thinking about this mod so I did it. Basically it's a piece of cf rod bent around the prop in the vertical axis. This eliminates the LG while protecting the motor from impact. You should reinforce the sides of the body to limit side forces.
If I had to do it over again, I'd use thin cf strap instead - cf rod under a bend like this will splinter but strap will not - next time!
Old Apr 21, 2007, 06:21 PM
Scott_S. is offline
Joined Feb 2007
I just got my GWS 2 5/8" Ultra Lights (shock absorbing), they look to be about perfect for the bug, the wheels actually bend in a little with any pressure so it ought to take some shock off the carbon fiber LG, we'll see.
Old Apr 21, 2007, 06:29 PM
Scott_S. is offline
Joined Feb 2007
That original CF rod is .050, see this link for the next step-up in strength,
http://www.rcgroups.com/forums/showthread.php?t=671884
I went with a 1.5 mm cf rod which measures .062, I'm not concerned with any extra weight and marked off the 3.5 inches from the front edge for the CG where Ron recommends for beginners. Hope to try it out early Monday morning. I can't wait to actually be able to fly this thing
Old Apr 21, 2007, 07:08 PM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Scott, those are the wheels I use. Work great! Used standard wheel collars.
Pete
peterv is offline Find More Posts by peterv
Old Apr 22, 2007, 05:47 PM
Pekin Illinois
Joined Aug 2006
So,it looks like alot of you are substituting c/f band for the main frame,should I?
Sold Lightflite BUG ready to fly. Back up for sale. 1987tc Aircraft - Electric - Airplanes (FS/W) 14 Jun 30, 2007 10:34 PM
Sold Lightflite Bug ready to fly! $135.00 Shipped with 2 lipos. 1987tc Aircraft - Electric - Airplanes (FS/W) 12 May 04, 2007 02:54 PM
Discussion Lightflite Bug "heavy duty" landing gear. Scott_S. Foamies (Kits) 11 Apr 18, 2007 01:09 PM
Discussion Plane Review: The Lightflite Bug CitaFly Electric Plane Talk 1 Apr 11, 2007 09:25 AM
