Old Apr 12, 2007, 01:00 PM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
Strong launcher set up (storm launcher upgraded to brushless)
I'm trying to decide what to order for this. I'm planning on ordering the motors from here:
http://www.strongrcmotors.com/Motors.htm
but not sure weather to get the 2500's or the 2900's. I would like it to pull vertical (something my stock SL is lacking), and have decent flight time. So what have you guys done? This is I would like to know your setups...
battery used (also the weight)
motors used
props
flight time
does it pull vertical?
also I plan on running on water to, what did you guys do to water proof things? which parts need air flow?
yzguy is offline Find More Posts by yzguy
Old Apr 15, 2007, 10:45 PM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
anyone?? I know some used the 2500's, but not sure what battery or props they used.
Old Apr 16, 2007, 01:10 AM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
>here< is c/f thread on his upgrade. He used the 2500's but he has to use 3S packs. You will have to read through to see his reasons.
I personally like the 2900's. Cause you can fly 2S, which is like stock power, but longer flight times , Or 3S which gives ballistic power, which is what I like.
Fact, My home made motors from Strong RC Are about 3200 kv and the SL flys like a rocket on 3S!
Props used are basically what Strong RC list on his web site.
Any of the 3S battery options are going to pull vertical.
Flight times will highly depend on the battery you chose, final weight , and the way you fly it.
Corrosion X is the best thing to use for water proofing.
Air flow is not to much of a concern with the speed controls because you are not even close to using the capacity that they are capable of handling.
UAVPilot is offline Find More Posts by UAVPilot
Old Apr 16, 2007, 09:11 PM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
arn't the stock bateries 2S? could you use those with the 2900's? (likely with shorter flight times)
I was just worried about drawing to many amps from the smaller batteries. like this one:
http://www.bphobbies.com/view.asp?id...8&pid=A3467968
lists "For 9A Continuous, 12A Peak Discharge" and the strong motors page lists "2900 Kv motor, GWS 4x2.5 prop, 10.5 V, 6.3 A" So is that 6.3 amps each or total? Is that going to pul to much from the battery? (I'm new to lipo's and don't want to melt it.)
Old Apr 16, 2007, 11:37 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
That would be 6.3 amps each , so 12.6 total. Those battery's won't really cut it.
The stock battery's are 740 mah 2S, but they can handle up to 14amps continuous. You can use those with the 2900's with a 4x4 prop. the flight should be close to stock power with slightly more flight time.
Some of the better battery's to use that work well are the Dualsky 730 mAh 11.1V 20C . With that battery and the 4x2.5 props , you will have a great setup with plenty of vertical power.
Old Apr 17, 2007, 12:06 AM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
ok, just ordered the 2900's and the new battery
Old Jan 19, 2010, 11:41 AM
HeliFanatic is offline
Find More Posts by HeliFanatic
Wish I could fly for real
United States, HI, Waimea
Joined Jan 2009
delete
post cancelled. no response. no reason to keep this message.
HeliFanatic is offline Find More Posts by HeliFanatic
Discussion Most common Brushless/ESC Set-Up for Storm Launcher HandEyeGuy Foamies (Kits) 18 Oct 05, 2007 04:03 PM
Video Brushless Storm Launcher 2 Dick Rankin Electric Plane Talk 6 Jul 26, 2007 01:37 PM
Video Brushless Storm Launcher video MichaelConnally Electric Plane Talk 5 Mar 15, 2007 04:42 PM
Discussion can i put brushless motors on my storm launcher? Gear Head Foamies (Kits) 26 Nov 21, 2006 02:03 AM
Question set up for astro 010 brushless Blytheflier 3D Flying 8 Feb 06, 2004 01:32 AM
