Old Apr 10, 2007, 04:49 PM
bouncy-boy is offline
Find More Posts by bouncy-boy
in my shop...
Joined Apr 2005
Question
Any tips on biulding a 1/6 scale piper cub kit?
Hi all, I am going to be building a great planes piper cub and i have built smaller kits before, but before i get started does anyone have any tips?
bouncy-boy is offline Find More Posts by bouncy-boy
Old Apr 10, 2007, 07:29 PM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
Tips? Only general ones.
I've built a Great Planes kit or several, and they are quite nice, but the wood can be very heavy in places. After all, they are designed for glow engine vibration. Many of the ones I built had a lot of solid balsa blocks in them--unacceptable for electric conversion. Either hollow out the blocks or remake the part from formers and balsa sheeting.
Keep the plane as light as possible. Always think in terms of adding minimal weight when you make your glue, covering, accessories, and equipment choices.
Substitute lighter or thinner wood for heavy solid sheet stock, solid blocks, or plywood if you even think it may be too heavy. Electric airframes don't need the heavy plywood and beefy solid structures that glow does. You'd be surprised at what you can get away with insofar as removing excess wood goes.
Look through other build threads for others who have done similar Cub conversion projects. You will find many Cub conversions, with many choices for motors and battery setups from cheap Chinese motors to expensive ones. I recently did a 72" Graupner/Blackhorse Cub ARF using this motor on a 4S2P 4200 mah pack. Flies great.
Rick
ElectRick is offline Find More Posts by ElectRick
Old Apr 10, 2007, 08:34 PM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Bouncy, If you're looking for "Scale Flight", KEEP IT LIGHT!
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Apr 11, 2007, 02:51 PM
in my shop...
Joined Apr 2005
alright im gonna get into this and ill try to keep you guys updated.
Sold 1/4 Scale Piper Cub Cockpit Kit FlyingWingNut Aircraft - General - Miscellaneous (FS/W) 1 Jan 05, 2007 08:26 PM
FS: 1/6 scale Fleet biplane kit, NIB BrianRickman Aircraft - Electric - Airplanes (FS/W) 2 May 19, 2004 08:52 PM
What is the "best 1/4 scale" Cub kit ? Warren Jones Scale Kit/Scratch Built 15 May 05, 2003 11:44 AM
Sig 1/5 scale Piper Cub Michael in Toronto Scale Kit/Scratch Built 5 Oct 04, 2002 11:30 AM
1/6 scale SIG CUB...will it fly? Graeme Fuel Plane Talk 3 Jul 11, 2002 03:48 PM
