Up close and it's ugly ... at least when I was done with it ;-)
This is the main LG, I attached the supplied fairing and glassed over it with scraps I had lying around (pretty heavy weight cloth too, iirc 4oz cloth), hence the sloppy look. I've had a rx inteference crash which tore off a large chunk of of the foam where the glass is applied, a little epoxy and you can't tell the difference. |
Tail wheel's basically copied from the Zero, parts are already there, all you need is music wire to bend into shape. Look just below the rudder control horn, you will see the L-bend that steers the wheel, epoxied on. The stock tail wheel should be fine, but it seems to skip/slide around for me, used a Sullivan tail wheel I had in the junk box. Still it's tricky to stear around on the ground.
I don't know the exact model, but it was a Sony MiniDV camcoder .... should be an older one as it only does 640x480 in still mode. |
| Thread Tools | |
| Yet another BF-110 in-flight video | Bomberguy | Aerial Photography | 7 | Jul 09, 2005 07:51 PM |
| in flight pictures of home made thing (no name so far) | Philip Thulin | Parkflyers | 11 | Jul 23, 2002 04:33 PM |
| yet another Crazy Max maiden flight | HMX14 | Parkflyers | 2 | Jul 05, 2002 11:49 AM |
| Yet another "Zagi First Flight" topic.. | pfriedel | Foamies (Kits) | 11 | May 15, 2002 12:35 PM |
