Old Apr 09, 2007, 03:26 AM
marsman711 is offline
Find More Posts by marsman711
Joined Dec 2006
What optic 6 swash setting are you using for the trex450se?
What optic 6 swash setting are you using for the trex450se? Nothing in the instructions tells you!
marsman711 is offline Find More Posts by marsman711
Old Apr 09, 2007, 05:42 AM
mem is offline
mem
Find More Posts by mem
mem
mem's Avatar
London, UK
Joined Nov 2005
The curves will vary depending on flying style, motor, pinion, blades, weight, servos and linkages amongst other things.
FWIW, the Optic settings I used for my first flights with the SE in normal mode were:
Throttle: 0-50-85-90-100
Pitch: 40-50-60-80-100
This was with the version 1.5 SE: BL430L 3550KV motor with 12T pinion and 325PRO blades. The head speed in this configuration is a little over 2300, pitch range -2 to +10 and it works well for the relatively sedate flying I do.
mem is offline Find More Posts by mem
Old Apr 09, 2007, 07:36 AM
raynet11 is offline
Find More Posts by raynet11
Sponsored by Team Me
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
I'm sure someone will have the setting before I do but if they don't I'll PM them to you when I get home tonight. I assume your using a CCPM setup since it's an SE, it's pretty simple, you reverse the servo channels until the swash servo's are all moving in sync and then you adjust the swash percentage until the movements are in the correct direction . (Example -70 +70 -70)
cheers,
Ray
raynet11 is offline Find More Posts by raynet11
What charger's are you using for your hi performance packs? mauiguy99 High Performance 10 Sep 22, 2004 03:08 PM
FIREPROOF Container: what are you using for lipos? romans1015 Batteries and Chargers 57 Sep 07, 2004 08:43 AM
what are you using for high amp battery connectors? dhauch Electric Sailplanes 7 Mar 17, 2004 06:50 AM
Adriana - What are you using for battery pack ? MDM Electric Sailplanes 6 Dec 28, 2003 07:18 PM
