Old Apr 08, 2007, 09:12 AM
Harpia is offline
Find More Posts by Harpia
Harpia's Avatar
Brasil, PE, Gravatá
Joined Apr 2004
Looking for a DIY Powerbox
Hi
I searched but I did not find a DIY project of Powerbox. Somebody has a project of DIY Powerbox?
I found this here http://www.powerbox-systems.com/e/po...pert/start.php but I would like to make one
Edson
Harpia is offline Find More Posts by Harpia
Old Apr 09, 2007, 03:46 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Harpia
No special secrets about the "PowerBox" and clones ...
just a Schottky diodes coupler ( I didn't read about voltage regul ...) for the two batts. an electronic switch ( P mosfet ). a memo batt indicator . 4 servo signal amplifiers .
You just build that on a THICK copper PCB ( 70 or + µm ...) and that's all !!!
You will find all the sub-systems schemes on the net ... just assemble.
Alain
Acetronics is offline Find More Posts by Acetronics
Old Apr 09, 2007, 10:23 AM
Harpia is offline
Harpia's Avatar
Brasil, PE, Gravatá
Joined Apr 2004
Originally Posted by Acetronics
Hi, Harpia
Alain
Hi Alain
Thanks for explanation!
Edson
Old Aug 04, 2007, 01:53 PM
flashrc is offline
Find More Posts by flashrc
Joined Mar 2007
Hello,
I am starting designing "my" powerbox system (this is for my Discus 4.3m), not to gain money, just for the pleasure of doing it.
The regulation is known for me (I will use the MIC29302), what is unclear is the stage of "amplifier" they are using inside: from my understanding it is just a 5V amplifier for the signal, so may be using a saturated op amp at 5V out is enough, any experience on this area ?
Nobody has opened his box to see the components used ?
Each servo has already an amplifier, so what is the need of such stage ?
I understand it can also avoid feedback voltage from high torque servo.
Thanks for your comments.
Hervé
flashrc is offline Find More Posts by flashrc
Old Aug 06, 2007, 01:30 PM
Tomapowa is offline
Find More Posts by Tomapowa
R/C Electro-Gadgeteer
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Here's a project I really never finished...
http://www.diyrc.com/optoisolators.htm
It basically amplifies the R/C servo signal from your Rx (via inverter), passes it to an optoisolator, amplifies again (via another inverter) and then passes it onto the servo. Use highspeed inverters for better accuracy and minimal phase shift. The servo's power also comes off of a built-in regulator (7806 I beleive). I never developed a circuit diagram for this... beleive it or not... but did build a board, tested and still being used in my 1/4 scale Patty Wagstaff.
Tomapowa is offline Find More Posts by Tomapowa
Old Aug 07, 2007, 12:18 AM
flashrc is offline
Joined Mar 2007
Very interesting board. Opto isolation seems very interesting.
Any drawback known so far ?
I bookmarked your website
Old Aug 08, 2007, 11:10 AM
Tomapowa is offline
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Only drawback (or design difficiency) is that the amplification (inverters) can cause significant pulse reshaping... higher quality and high speed inverters make significant improvements though. If you are only looking to power your servos from another power source (i.e.no optoisolation), then simply connect the +V wires from each servo to another power source, such as a swithcing regulator capable of providing 3+ amps or whatever you require (typically higher when using many large digital servos). I built such a device that plugs into the Futaba 9 channel PCM receiver... provides regulated (+2 amps) from unboard regulator.
Old Aug 08, 2007, 03:41 PM
flashrc is offline
Joined Mar 2007
Looks like you have done many nice circuits !
Actually, I am really looking for doing both:
- Vreg for DUAL bat source (2 IC for the regulation)
- amplifier (your proposal with double inverter + opto isolation of the signals) for the servo signals.
- and add a PIC for LED display, LED error, ...
Actually reshaping signal for servo's is not so much a draw back but give more nice waves to them, regulated at 5V, isn't ?
Having a regulator instead of Diode for DUAL bat plays the same role, i.e. if one is in short circuit, the other one doesn't discharge into it: do you confirm ? because in some schematic, I saw a Vreg chip (like MIC29302) + a diode in serial.
Thank for your precious comment.
Old Aug 08, 2007, 03:56 PM
flashrc is offline
Joined Mar 2007
I forgot to ask you the value of the Resistors in serial between inverter-opto-inverter.
Thank you.
Old Aug 08, 2007, 10:00 PM
Tomapowa is offline
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Thank you.
Oh yeh... just noticed it is not listed on either drawing...
R1-R4 and R13-R16 (input amplifiers) are 220 ohm while R5-R12 (output amplifiers) are 1K ohms.
Re: your other questions... when I say the inverters cause "reshaping", I mean they alter the rise/decay of the servo pulses (no longer square in shape). This in fact changes (decreases) the pulse widths a little, causing slight servos positioning issues.
Ex. Using slow cheesy 4069 inverters, I think I was seeing 1420ms pulses where in fact the input was 1500ms... or something like that.
As for the battery redundancy feature, as long as both regulators have built-in "diodes" as you mentioned, you should be safe.
p.s. I also dug up a circuit diagram for one channel... instead, I used inverters vice "buffers" and used 2 DIP ICs that house 4 opto-couplers each (saved board space)
Old Aug 08, 2007, 10:42 PM
Tomapowa is offline
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Here's a simpler optoisolator I dug up... don't know how well it works though as I never built/tested. No amps... just optocouplers.
http://www.toshiba.com/taec/componen...//207/4346.pdf
Old Aug 13, 2007, 01:49 AM
flashrc is offline
Joined Mar 2007
Thank you Tomapowa.
The solution with inverter-opto-inverter looks nice and should really cut all noise which can come from long wires (in sailplanes wings for instance). I intend to do a SMD version.
I still do not understand why you are loosing pulse width because when I look at the datasheet, the response time is far less than what you are loosing. It is stated to put a Cl o 50pF, have you tried ?
I saw an old review of powerbox system 40/24:
http://www.modellbau-deutsch.com/e/t...erpox_engl.pdf
it clearly shows the IC on each servo signal which is a SOI8 plus some resistor. I don't have any idea of what it is. On their latest design, they are speaking of push pull technology, I guess this is for fast response in bothe edge of signal.
Old Aug 13, 2007, 10:13 AM
Tomapowa is offline
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Thank you Tomapowa.
Hi flashrc,
After looking over the PowerBox and PCB, it appears they are not using optoisolators, even though they say their products "Isolates the receiver from possible RF noise". Without optos, you are not isolating signals from input to output (i.e. most likely still using common ground). Looks like they are only using pulse amplifiers (i.e. glorified non-inverting buffers in SMD form) for amplifying and reshaping signals. Other circuitry shown (2 other DIPs) are for the monitoring of each regulator output (could do with 2 cheap Volt Watch units). Not all too complex to be honest. Some other manufacturers do in fact sell "opto" versions of these... such as the Jomar (EMS) Glitch Buster (http://www2.towerhobbies.com/cgi-bin...&P=SM&I=LXPNU7)
Old Aug 13, 2007, 10:31 AM
flashrc is offline
Joined Mar 2007
I share your comment, so there is two approach: opto but drawback is reshaping, amplifier but drawback is noise immunity.
However even using Powerbox system, I suppose the ground and VCC is common, only the signal is "decoupled".
They are using SOI8 chip for each line (servo), I think I have found what they might use, or anyway, I might be interested in this: this is digital isolator
Si8440 from Silicon Labs (they do a quad version)
ISO721 from TI in SOi8
What do you think ?
Old Aug 13, 2007, 11:39 AM
Tomapowa is offline
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
What do you think ?
Cool...Pretty decent specs on those isolators too...
http://focus.ti.com/lit/ds/symlink/iso721.pdf
Just ordered a few samples to mess with...
Discussion looking for DIY receiver designs village_idiot DIY Electronics 11 Jun 08, 2007 09:03 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
Looking for CD / DIY motor info? ecologito Power Systems 9 Dec 20, 2005 02:40 PM
looking for DIY 12 volt power supply instructions super_nova DIY Electronics 4 May 09, 2005 11:06 AM
looking for a simple Tach DIY ? Franck Electric Plane Talk 0 Dec 29, 2003 02:52 PM
