Changing RX's from 72mhz to 75mhz
Hello all,
I was wondering if anyone knows where I can have a few older Futaba AM receivers on 72mhz converted to 75mhz? I have an old Ace Sub Commander radio and only one receiver for it and I'd like to equip a few more projects with RX's to match the Sub Commander. I have a newer radio on 75mhz FM but I still like the old Sub Commander and I'd like to use it more. Any suggestions would be appreciated. Thanks, Mike |
Latest blog entry: My Favorite of Favorites
Consider the following time line for rc frequencies in the US: 1973 - 5 chanels in 27 MHz. 7 channels in 72-75 MHz; 3 are shared (72.160, 72.320, 72.960); 4 are aircraft only (72.080, 72.240, 72.400, & 75.640) 1984 - 6 channels in 27 Mhz. 72-75 MHz aircraft only (12, 38, 40, 42, 44, 46, 48, 50, 52, 54, 56, 72.240, 72.400, 75.640). 72.160, 72.320, & 72.960 are still shared between surface & air. 75 MHz for surface models only (62, 64, 66, 68, 70, 74, 76, 78, 80, 82, 84) 1988 - 6 channels in 27 MHz. The shared 72-75 MHz channels become illegal to use. 11 new aircraft channels are added to the 11 channels created in 1984 (14, 16, 18, 20, 22, 24, 26, 28, 30, 32, & 34). 4 new surface only channels added (72, 86, 88, 90). 1990 - 27 Mhz stays the same. 28 new aircraft only channels added (odd numbered channels, 11, 13, etc., and 36, 58, & 60). 15 new surface frequencies added on odd channels (61, 63, etc.) 1998 - The older wideband gear is illegal to use. 2004 - 2.4 GHz radio gear introduced - great for airplanes and surface models; bad system for diving submarines. 2.4 GHz is too high a frequency to penetrate (however slight) the water. Back in the 1970's the Dumas resistor speed control was considered by many to be the state of the art. Electronic spped controls were $100 or more compared to the Dumas resistor costing around $25. Now that DUmas resistor is about $45, and some small waterproof ESC's are around $30. A standard servo cost about $25 back then, now you buy them for around $12. |
Seattle, Wa
Joined Aug 2006
Yeah I suggest you just simply buy a new one. Im guessing would probably cost just as much to have it converted. And its just not worth all the back and shipping. Which is a real pain. Unless you have an old 9 channel radio you want to use for one hell of a multi function boat and you dont want to buy one of those new ones that are like $500 then it might be a good idea. Yeah I dont know if Radio South still does it.
| Thread Tools | |
| Sold 2 new RX's from Corona RS410 and RS610 | rodair | Aircraft - General - Radio Equipment (FS/W) | 9 | Nov 26, 2006 12:19 PM |
| RX's from Maxx Products | LuckyArmpit | Radios | 6 | Apr 17, 2003 11:34 AM |
| changing Rx crystals | Foxtrot | Power Systems | 5 | Jul 29, 2001 07:28 AM |
| EDF's From Germany & Conversion Rates | AndrewK | Electric Ducted Fan Jet Talk | 23 | May 22, 2001 01:31 PM |
| Rpm's from "No Load" | stealthy | Power Systems | 3 | May 20, 2001 08:30 PM |
