Old Apr 07, 2007, 11:36 AM
kfong is offline
Find More Posts by kfong
Sterling Heights, Michigan, United States
Joined Nov 2003
CVS Camera Mods
My CVS USB connector
I decided I wanted a micro usb connector found in most digital cameras, so I made a small board for a micro usb connector that can be solder onto the existing pads of the camera board. The micro usb connector can be picked up at Digikey.com part number WM17115-ND $2.19
If anyone is interested in these bare boards, I can sell them for $3 each. Just send $3 with a self addressed stamped envelope to:
Remote camera sensor cable mod
http://www.rcgroups.com/forums/showt...ds#post7429545
Kin Fong
2517 Cobden Street
48310
Kin
http://www.embeddedtronics.com/
kfong is offline Find More Posts by kfong
Old Apr 07, 2007, 12:00 PM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Very neat! Look good too!
quailbird is offline Find More Posts by quailbird
Old Apr 07, 2007, 12:05 PM
ratb is offline
Find More Posts by ratb
ratb's Avatar
Joined Jan 2007
That's very cool.
I'm actually a bit more interested, though, in instructions on stripping the camera down and powering it from a receiver. Anybody seen a thread on that?
ratb is offline Find More Posts by ratb
Old Apr 07, 2007, 12:06 PM
kfong is offline
Joined Nov 2003
Some more details, I filed the back edge of the board with a file to get a more flush look with the camera enclosure. It presents a cleaner final appearance but not needed. For alignment, you can actually look down the through holes and see the camera board contacts that you will be filling with solder.
Those of you who have the Castle Creations PHX-Link already have the cable that plugs into this connector.
If you have more camera mods, please post them. Would like to see what others have done with this camera.
I have a second camera that I have done some intensive hacks on. I will be posting more on this later. I will also show how to install it on the plane using onboard power.
Kin
Old Apr 07, 2007, 02:52 PM
ratb is offline
ratb's Avatar
Joined Jan 2007
Excellent!
I'm using a 5-in-1 eDVR right now, which works pretty well. But I'll tell you, if I could get my CVS cam stripped down to board and wires, and then not have to lug up a pair of AA batteries, I'd never fly without it!
Old Apr 07, 2007, 08:27 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Originally Posted by ratb
Excellent!
I did that with mine and even made a camera mount using a old aptek camera for my slow stick.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old Apr 08, 2007, 12:22 AM
Fishbone4u is offline
Find More Posts by Fishbone4u
Fishbone4u's Avatar
Irving, TX
Joined Apr 2006
My mod.... The hot glue keeps everything tidy but will be easily removable if I end up doing your mod, Kin. Yours is the cleanest, best I've seen.
Kin, can you add in the connector to your $3 board offer? PM me please...thanks.
Chris
Fishbone4u is offline Find More Posts by Fishbone4u
Old Apr 08, 2007, 04:29 AM
ebayrcer is offline
Find More Posts by ebayrcer
Stop Resisting!
ebayrcer's Avatar
Horse Capital of the World, KY
Joined Nov 2005
That's very cool.
ratb, all you have to do is solder to the metal contacts inside the batt compartment of the cam. To make it easier, remove the small circuit board which has the batt contacts mounted to it, first. Just pop off the battery cover and remove the four rear screws (hidden under the white label which goes around the display on the backside), then pop off the rear half of the cover. Remove the two screws near the bottom of the cam board and carefully lift the cam board straight up and off of the four pin battery contact "socket". Be very careful with this step because it's easy to damage (bend) the four battery contact pins. After that, remove the little piece of PCB which the contacts are mounted to. For the wiring, either use a servo lead, or if you're desperate (like I was), you can even use the 2-pin header connector wires from an old PC power supply. Either works great, but if you decide to use a servo lead, be sure to either completely remove the signal wire, or at least clip it short so that you don't short out the circuit (it doesn't get soldered to anything). Pay attention to the polarity of each contact, then solder each wire on (Red to POS, Black or Brown [JR servo lead wires have a Brown wire instead of Black for -] to NEG) near the top so that when you put it all back together, the cam case can still close flush without putting any pressure on the wires. Remove the plastic servo lead connector from the end which will plug into the receiver (use a tiny flathead screwdriver - eyeglass screwdrivers work great for this), by carefully prying up on the tiny plastic retaining pins and pulling the wire ends free.
Pass them through the rectangular hole in the cam housing, just left of the dark gray plastic piece which locks the battery cover in place. You will also need to snip off the corresponding tab from the battery cover itself and file a small groove just large enough to pass the wires through without snagging or scraping. Once you've done that, push the plastic connector retaining pins down firmly, then slide the ends of the wires back in until you hear the 'click' sound of them locking back in place. Give the wire a firm, yet gentle tug to ensure that the wires are firmly locked in and will not pull free at a later time.
Reassemble the cam (exact reverse of removal), snap the battery cover back in place and plug it into your receiver. Power on your radio and then your receiver, and turn the CVS cam on with the power button (as you normally do). Hit Record and make sure everything's working perfectly.
Please note: others have pointed out that this method relies on the 3V input (2 AA's), and as such is incapable of handling 5V from the receiver. However, all of my CVS cam footage has been recorded using this exact same setup. Use at your own risk.
I'll post some pics of it all later on if you want, to help visualize exactly what I'm describing.
Have fun and let us know how it goes!
- ebayrcer -
ebayrcer is offline Find More Posts by ebayrcer
Old Apr 09, 2007, 04:19 PM
kfong is offline
Joined Nov 2003
There is a better method to what ebayrcer had just described. You can use 5volts, just tap it onto the usb connections. That is normally 5volts, this is what I will be doing. I still need to look into the current draw, since it might be too much for the esc to power, but a UBEC should work fine. I'll start posting pics and stuff once I have a camera flying around.
Kin
Old Apr 09, 2007, 06:26 PM
scb28 is offline
Find More Posts by scb28
scb28
scb28's Avatar
Rocklin, CA
Joined Jan 2006
My Pure Digital (cvs) camera mounted to Slow Stick
Hello all.
Thought I'd post some pics of my modified PD camera mounted to a Slow Stick. I basically cut the battery portion of the camera off and power it with 3 nmh rechargable batts in a Radio Shack holder. That gives me 3.6v nomial. Actually the voltage is about 4.2 on fully charged batteries. Everything works good so far. My videos leave something to be desired but I'll get better with practice.
The mounting is pretty basic, some packing foam and some rubberbands. Simple, cheap and it works okay.
About camera draw. I read on some forum, can't remember where, that the camcorder draws about 500mah when recording.
scb28
scb28 is offline Find More Posts by scb28
Old Apr 09, 2007, 06:55 PM
tallflyer's Avatar
Joined Jul 2002
scb28
Looks good make sure you play with the software that is online to get the most out of your camera.
Most of the cameras are set to either 30-60 minutes depending on the one you bought and if you run them on factory settings the video quality is pretty poor.
Old Apr 09, 2007, 07:10 PM
tallflyer's Avatar
Joined Jul 2002
Low quality video
http://video.yahoo.com/video/play?vid=368967
setting have video at about 256 resolution, everything looks fuzzy or like im flying in a haze.
My favorite setting for web based video is at 512 resolution video size can be any as high as 640 x 480 set your time to about 8 minutes and you get perfect quality video.
http://video.yahoo.com/video/play?vid=240998
Old Apr 09, 2007, 07:46 PM
tallflyer's Avatar
Joined Jul 2002
here is a small clip from the original video as a avi file
http://www.sdparkflyers.com/small.00.avi
Old Apr 09, 2007, 09:04 PM
scb28 is offline
scb28
scb28's Avatar
Rocklin, CA
Joined Jan 2006
Yeah, I'm still using the original settings. It has 20min of video space. The clarity of my vids are okay. I wish I could say the same about quality. It's been a bit windy around here and the old Slow Stick bounces around pretty good. I attached an edited down version of my second video, see for yourself. It's a little long and not alot to see.
http://video.google.com/videoplay?do...17642483187457
scb28
Discussion EZ Star CVS Camera Mod..look! Gary Morris Aerial Photography 41 Dec 17, 2006 08:05 PM
Discussion CVS camera video ariesmars Aerial Photography 2 Feb 09, 2006 09:07 PM
Discussion Brushless SS with CVS camera Ursine Aerial Photography 6 Jan 31, 2006 04:46 PM
HELP!!! w/cvs camera 3.7revision HELP!!! cerralvo78 Aerial Photography 3 Nov 18, 2005 10:25 AM
Help! cvs camera question CaptRon Aerial Photography 9 Sep 01, 2005 06:37 PM
