Old Apr 06, 2007, 08:50 PM
Will fly for food...
flyingvranch's Avatar
Huntsville, Texas USA
Joined Aug 2005
Can you help identify this plane?
I have aquired an old Graupner (I think) kit. It appears to be an ASW of some type. The wingspan is approx. 11foot 5 inches. I believe the kit to be somewhere around 20 years old. Any info would be much appreciated! Thanks!
flyingvranch is offline Find More Posts by flyingvranch
Old Apr 07, 2007, 12:29 AM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
I don't know but those are some OLD servo, Futaba F16s? F type connectors...At least 20 years old equipment. The plane could be a Discus. It is probably semi-scale. If it is 3.5m then it would not be a Graupner Discus. I know they had a 4m version.
Is this afiberglass fuse or some sort of plastic fuselage?
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Apr 07, 2007, 01:24 AM
May the Wind Always be Good
Webster, Minnesota
Joined Feb 2007
It is a Mini Nimbus one super nice airlpane and a good flyer here is mine
Mr. Kite is offline Find More Posts by Mr. Kite
Old Apr 07, 2007, 07:30 AM
Joined Aug 2005
Mini Nimbus huh? Your's looks exactly like mine too. If I may ask what are your wing joiner rods made of as mine are missing. Also I wonder where I can find a three-view drawing as I have to scratch build the tail surfaces.
Thanks again all!
Old Apr 07, 2007, 09:01 AM
Webster, Minnesota
Joined Feb 2007
The wing pins are 146mm long 2each 5mm and 2each 6mm music or spring steel also i have the plans so get you a copy to make a tail Thanks Mr. Kite
Old Apr 07, 2007, 03:27 PM
Joined Aug 2005
Mr. Kite,
You are very helpful! Thank You!
I do need the measurements of the stabilizer and rudder. I will send you a PM with my email address.
Thank you again!
Bud
Old Apr 07, 2007, 04:16 PM
daveosoar
hampshire
Joined Mar 2006
Wonderful to see these old Classics coming back to life. Whilst not up to modern standards in terms of aeros they all fly well in a scale style. I have just 'regenerated' a Robbe ASW 19 from 1973 - its a delight to fly providing you recognize its limits. As a semi-scale (as they all were) and the wire rod wing joiners, they are elegant , and with modern equipment, i.e. a servo in each wing, fly from flat field or slope exactly as the designer intended, plus the standard of construction makes all but the most expensive these days look like crap.
Daveosoar.
daveosoar is offline Find More Posts by daveosoar
Old Apr 08, 2007, 07:51 AM
Webster, Minnesota
Joined Feb 2007
Glad to help. Will like to see some photos when yours is ready to fly..Mr.Kite
Old Apr 08, 2007, 09:40 PM
Joined Aug 2005
Motor installed and carbon wing tubes in question. (Mr Kite I sent you a PM asking about this) How do I get the required dihedral with straight tubes?
Any suggestions?
Please help identify this plane dgoslee Vintage & Old-Timer Designs 12 Dec 31, 2004 08:26 AM
Can you help name this movie Mike C Life, The Universe, and Politics 3 Dec 09, 2003 11:23 PM
Help Identify This Plane sodekirk Parkflyers 4 Oct 30, 2003 12:29 PM
help identify this plane dalbert02 Electric Plane Talk 2 Jul 28, 2003 09:51 PM
Can you help identify this sailplane? Ian Easton Electric Sailplanes 12 Jan 14, 2003 02:47 PM
